ORDER PAGE HERE
Usage
Due to the limitations of the Wasp design, it will respond to midi keys C2#-C5 only, anything outside of that range is ignored. Effectively, you get a little more range than the keyboard. Same is true for the CV.
BOM
Mouser Cart
Firmware
Current version is 0.09a.
Download: HERE
You need teensy loader: https://www.pjrc.com/teensy/loader.html
Simply open the app, load the hex file, set it to auto, and plug in the Jasperin interface via USB. The code will upload and the yellow LED will come on indicating that it is down. The jasperin is powered by the synth only, it does not power from the USB so it has to be plugged in to the LINK port
The Resonator:
This is much easier than it looks. Simply tin one pad, flux, flow and slide the part into position. Then simply touch the tip of your iron to the bottom next pad and touch the junction with solder. It will wick under the part (you will see solder at the top of the pad). There is metalization one the bottom and sides of the resonator so the solder wicks right up the part.
The 0805 LED:
There is a dot showing the orientation of the part, it matches the side of the LED with the line on one side, the correct orientation is below.
The TH LED:
The correct spot to bend the part is right behind the two little thicker parts on the LED leads.
Mounting Holes
Download: HERE
