Euro CV to expression pedal input
- subdo
I'm about to pull the trigger on a Strymon Big Sky and wondering about using eurorack CV (Maths, URA, etc.) to modulate values via the expression pedal input. Do I really need something like the ALM S.B.G? I realize there is a range issue i.e. Strymon takes +0/5v and Maths puts out +/-10v but it seems like that could be handled by a simple attenuverter. Can I do any real damage to the pedal experimenting?
- subdo
Thanks. So what do you do about the R in the TRS connection since euro patch cables are just TS. Going on this link the ring has the reference voltage?
http://www.strymon.net/strymon-tech-cor ... ion-pedal/
In electronic terms, this is most commonly accomplished with a TRS (tip / ring / sleeve) 1/4″ cable where the reference voltage is on the “ring,” the control voltage is fed back to the device on the “tip” and the “sleeve” is ground.
the sbg actually includes a floating ring cable for this exact use..
this one from expert sleepers should work too..
http://www.analoguehaven.com/expertslee ... torcables/
- subdo
Looks like the SBG is the best way to do this. Thanks again.jwm wrote:the sbg actually includes a floating ring cable for this exact use..
There is an amazing trick for doing this safely, and without an extra module (just using a regular linear VCA):
- patch a stackable in BOTH VCA input and VCA output (yes...)
- patch from your expression pedal input to either end of the stackable
- CV in the VCA is your CV control over the pedal
No idea how this even works, but it does. Works perfectly with my Eventide Space. It's safe because whatever CV you apply, the expression input will only go from 0% to 100% according to the pedal (i.e. no over voltage is possible)
- Paranormal Patroler
This. Umcorps even has a video showcasing this with a Space pedal.Artaos wrote:There is an amazing trick for doing this safely, and without an extra module (just using a regular linear VCA):
- ignatius
pretty sure ADDAC makes a few modules for this.
http://www.addacsystem.com/product/adda ... s/addac301
http://www.addacsystem.com/product/adda ... /addac301b
- Leverkusen
Looks like it's more the other way round, doesn't it?ignatius wrote:pretty sure ADDAC makes a few modules for this.
depends on what ADDAC means by "Invert switch for inverting the expression pedal action." ?Leverkusen wrote:Looks like it's more the other way round, doesn't it?ignatius wrote:pretty sure ADDAC makes a few modules for this.
- subdo
I'm trying to figure how this works.Artaos wrote:There is an amazing trick for doing this safely, and without an extra module (just using a regular linear VCA):
What do you do about the TRS issue? One of those floating ring cables?
- subdo
Yeah, I read the descriptions on these and they are expression pedal to euro CV. Still useful but not what I'm looking for here.Leverkusen wrote:Looks like it's more the other way round, doesn't it?ignatius wrote:pretty sure ADDAC makes a few modules for this.
I think you need to make a DIY Y-cable, from 2 x TS to 1 x TRS. Check Umcorpo's video and look for some other threads in the forum, this thing comes up every now and then.subdo wrote:What do you do about the TRS issue? One of those floating ring cables?
I plan on using a direct cable to the Deco input, which accepts 5V. Just use an attenuator and make sure it stays within range.
- subdo
I actually have one of those I got with the QuNexus. So if the CV signal is on the tip what do you plug the other cable into (i.e. the ring)?Paranormal Patroler wrote:I think you need to make a DIY Y-cable, from 2 x TS to 1 x TRS. Check Umcorpo's video and look for some other threads in the forum, this thing comes up every now and then.subdo wrote:What do you do about the TRS issue? One of those floating ring cables?
Nope, you got it wrong. The Y cable is for the VCA trick: TRS to pedal, TS to VCA Input, TS to VCA Output and CV controls how much your VCA opens (re: VCA CV control).subdo wrote:I actually have one of those I got with the QuNexus. So if the CV signal is on the tip what do you plug the other cable into (i.e. the ring)?Paranormal Patroler wrote:I think you need to make a DIY Y-cable, from 2 x TS to 1 x TRS. Check Umcorpo's video and look for some other threads in the forum, this thing comes up every now and then.subdo wrote:What do you do about the TRS issue? One of those floating ring cables?
If you want to use CV directly with the pedal I think you only need a TS to TS cable. I assume that's what people use but I haven't done it myself so do it at your own risk.
Haha, I stopped trying to figure out how it works. It works very well though, and seems very safe, you get CV only over the voltage the pedal accepts.subdo wrote:I'm trying to figure how this works.Artaos wrote:There is an amazing trick for doing this safely, and without an extra module (just using a regular linear VCA):
About the TRS issue, I just use a 1/4" TS cable to 3.5mm TS cable. It works just fine with my Eventide Space. It might depend on the pedal though. YMMV. If you really want to, you can use a floating ring cable, or a TRS to TS+TR splitter.
Re:
Hi. Sorry to necro. Did you ever do this with your Deco? How did it work out? I'm thinking of doing this with my Deco too.Paranormal Patroler wrote: ↑Wed Nov 23, 2016 7:47 amI think you need to make a DIY Y-cable, from 2 x TS to 1 x TRS. Check Umcorpo's video and look for some other threads in the forum, this thing comes up every now and then.subdo wrote:What do you do about the TRS issue? One of those floating ring cables?
Since this post, is there any gizmo that ensures one won't go over 5v?
- ersatzplanet
- Synthwerks Design
Re: Re:
I'm thinking of doing this for my Nord Modulars and using a Vactrol to make sure it doesn't get over voltage. The expression pedal jacks themselves provide the voltage that is modulated by the pot in the pedal. Just replace the pot in the schematic with a Vactrol (or FSR as an alternative) and it will never do over voltage. A simple transistor circuit will also work if you want faster response than the Vactrol will give. If you just modulate the voltage already provided by the expression jack, you will never blow up the piece being controlled (you may blow out the Vactrol or transistor of course).xidnpnlss wrote: ↑Mon Mar 01, 2021 10:39 amHi. Sorry to necro. Did you ever do this with your Deco? How did it work out? I'm thinking of doing this with my Deco too.Paranormal Patroler wrote: ↑Wed Nov 23, 2016 7:47 amI think you need to make a DIY Y-cable, from 2 x TS to 1 x TRS. Check Umcorpo's video and look for some other threads in the forum, this thing comes up every now and then.subdo wrote:What do you do about the TRS issue? One of those floating ring cables?
-James
