We are discontinuing the Shaper KIT. We can't find some of the rare parts anymore and many are coming as fakes. These are the last kits we have.
download/file.php?mode=view&id=138183
[UPDATE] Please download rev2.0 zip files for the rev2.0 PCB set.
https://www.dropbox.com/s/vi713g5m4sq0h ... 0.zip?dl=0
[UPDATE}
We added the buffer which resolves the 5semitone glitch on the PCB rev2.0 There is no need to make the ugly correction anymore.
For those who have bought one of the kits, but still didn't built the PCB, you can buy only the REV2.0 Brd2 from the store.
FOR ORDERING AND PROJECT INFORMATIONS USE THE MAIN THREAD :
https://www.muffwiggler.com/forum/viewt ... p?t=169990
TWO59 SHAPER is the heart of the TWO59 project, being responsible for the unique timbres and modulations.
This Module works in conjunction with a pair of TWO59 VCOs, one working as a main oscillator and the other as a modulation source.
This complex oscillator is capable to create timbres based on frequency modulation, amplitude modulation, timbre modulation or any two or three processes
at the same time.
The connection between the modules is done using two 10 core ribbon cables.This is a highly complex build, so take your time studying this manual before building,
Some of the details may help a lot in the building process.
We tried to make the whole experience as easy as possible and give as much information as needed to avoid confusion.
We also provide additional documents like BOM lists (PDF and XLS), images with part values, and photos of the construction in various stages.
Feel free to download the whole pack and have fun.
Audio demos :
The sound clicks are from computer latency, not from the modules
Somehow I forgot to record the ramp wave. I will record it soon.
https://soundcloud.com/strat1/two59-square
https://soundcloud.com/strat1/two59-triangle
https://soundcloud.com/strat1/two59-sine
https://soundcloud.com/strat1/two59-shaper-basics
https://soundcloud.com/strat1/two59-shaper-modulations
https://soundcloud.com/strat1/two59-two59s-on-the-bread
This demo uses the power of 2 Full modules and one additional VCO (5VCO's in total)
-The starting bass line panned to the left speaker is a triangle wave passing to a jupiter8 filter module, to know how will sound affected by a VCF.
-The second line panned more to the right is the ouput of one shaper directly to a VCA. I turn the timbre slowly in various points of the song.
-For the other two lines I used some spring reverb.
-The ending is with pitch (fm) modulation ON.
-All the VCO's stayed in tune for a period of 3 hours until I closed the system.
