My tribute to the Cracklebox by Michel Waisvisz and Geert Hamelberg.
Obviously this one's a little different because it uses a pair of PLL chips instead of an opamp, but in spite of different circuitry there are some commonalities:
(1) It abuses cheap and readily available ICs via the simplest and perhaps stupidest means possible: directly poking IC pins. (2) The LM709 has external frequency compensation pins and the CD4046 has its own sort of bandwidth limiting via resistors (or fingers in this case) at pins 11 and 12. (3) Like the original Cracklebox, this circuit is pretty much silent unless prodded. (4) It makes squeals and fart noises that are unique to each player.
There are only FOUR (4) components needed for the barebones version and it costs about one US dollar to make. With some additional circuitry, it can be the heart of a chaotic gesture-controlled synthesizer system. I hope that you enjoy it.
https://soundcloud.com/martin-freem/dua ... cracklebox
