3x MIA – Mixer – Inverter – Attenuator
igorrr
Post by igorrr »
Here it is: 6 HP module with dual concentric knobs, each of them is attenuverter (zero at mid position). If nothing is plugged to A or B inputs – this channel gets normalled to +5 V, thus we have six variable DC sources to offset our signals. There are three groups, each of them has separate output. Switches give us possibility to mix group 1 to group 2 and group 2 to group 3, so we can get 2-2-2, 4-2, 6 channels mix configurations.
Depth – 3.5 cm
Current draw +- 80 mA from both lines.
MSRP – 100 USD.
https://www.modulargrid.net/e/happy-nerding-3x-mia
https://www.modulargrid.net/e/happy-ner ... -mia-black
http://www.analoguehaven.com/happynerding/3xmia/
https://www.schneidersladen.de/en/happy ... 3xmia.html
https://www.schneidersladen.de/en/happy ... black.html
https://escapefromnoise.com/modular/hap ... ing-3xmia/
http://www.midiamsterdam.nl/happy-nerding-3xmia.html
https://www.signalsounds.com/happy-nerd ... xer-module
https://www.signalsounds.com/happy-nerd ... dule-black
Suburban Bather
still insane
Post by Suburban Bather »
That's badass!
Hi5
Post by Hi5 »
Quite cool idea to take a utility item to the next level
tetno: https://soundcloud.com/richard-holhburn
Goiks: A eurorack setup is a contemporary folk instrument. Relatively accessible and portable. Largely by, of and for the people.
sparood
Post by sparood »
I need 2 extra mixers in my rack, this looks like an awesome addition.
Also, great layout, clean and solid. Guess it will also be available in Europe ?
chapelier fou
Post by chapelier fou »
So compact !
i love it !
DivKid
Post by DivKid »
Great idea!
Ras Thavas
Post by Ras Thavas »
Neat design, like the dual pots.
Question; do the attenuverters easily hit true zero at center? Do they have a center detente that helps with this?
I ask as my Triatt works pretty well in this regard, with my Shifting Inverting Signal Mixer it's really difficult to hit zero, and that makes it less useful for me.
dumbledog
Post by dumbledog »
Ras Thavas wrote:Neat design, like the dual pots.
It'd be cool with something like this if one pair were straight attenuators. Still this is exactly what I wanted in a rack I'm planning so yeah I'm in line.
Dcramer
Post by Dcramer »
Brilliant, this much power in 6hp means even vca-shunning noobs will buy one! :hihi:
enj_music
Post by enj_music »
I agree that it's hard to get the tactile click on the SISM to be exactly 0 every time, but it does have a detent. If anything, it will be easier to dial in 0 on these, since:
A. The knobs are bigger (not mini-pots like on the SISM)
B. There is (I assume) no detent, so you can do fine tuning instead
of just locking onto "zero" at a certain distance from the center
I do agree, though, that the Triatt does a really good job with this - being able to switch between attenuversion, attenuation, or both, is priceless.
YouTube: Rigatoni Modular
VCV Rack Modules: Rigatoni Modular
Current rack(s): Main case, 62HP Palette Case
phosfiend
Post by phosfiend »
Wow, super clever and the ergonomics look good to boot!
I made a videogame inspired by synths called FRACT OSC. It's like Myst meets Rez but inside a giant 8 voice synth - WWW.FRACTGAME.COM
Futuresound
Post by Futuresound »
dlabtot
Post by dlabtot »
Nice design.
enj_music
Post by enj_music »
I'm also curious about how one bolts two pot shafts to the faceplate, or if the inner one will be a little wiggly
dumbledog
Post by dumbledog »
I have a pair of Att-Off tiles by Pulp Logic with the same concentric-circle scheme, and the inner pot is perfectly steady.
limpmeat
Post by limpmeat »
I have the same 1u tiles and they are sturdier than most of my euro pots.
igorrr
Post by igorrr »
Regarding the “zero hit” at mid position: knobs response is curved from linear to expo like to make it easier to balance in this mid position. It is possible to get -60 dB of level reduction in there, but accuracy is required. Attenuverter is not suitable for half a second twist from full volume to zero, as ordinary attenuator does. And there is no center detent, which helps with middle position, but spoils the smooth transition “through zero”.
Design compromises are inevitable. As for example: with once section of 3x MIA the user can adjust the polarity and level of some LFO and smoothly shift it in both DC directions to nail the desired modulation, which cannot be made with attenuator and inversion switch.
It vastly expands modulation possibilities for all the modules with just CV inputs. And having all 3 sections at hand, can be used to easily control several different modules from one spot.
The pots are no way “wobbly” and overall constructions is very solid.
Bob Loblaw
Post by Bob Loblaw »
Yes! This is awesome. Been looking for a mixer like this. Very, very useful. Sign me up! :yay:
Confessions of a sinner - Bob Loblaw's God Blog
https://theconfessionsofasinner.blogspot.com/?m=1
Krater
Post by Krater »
Yes, very nice, will most likely get one. The new panning mixer looks promising as well!
DivKid
Post by DivKid »
Krater wrote:...The new panning mixer looks promising as well!
erm :hmm: where?
EDIT Nevermind I've found it - viewtopic.php?t=162150
Footkerchief
Post by Footkerchief »
It's hard to use a polarizing CV mixer without LEDs :confused:
Krater
Post by Krater »
yes, that´s what I thought as well. Please put some bipolar LEDs in there and it´s perfect. Maybe on the left-hand side in the corners of the squares, don´t know if this would be possible though.
igorrr
Post by igorrr »
LEDs will not give precise information anyway, and DC shifting is so straightforward - turn to the “+” side and it moves up, turn to the “-” side and it moves down.
dkbax
Post by dkbax »
I just friggin got a Befaco dual offset attenuverter, this would be ideal! Available in UK anytime?
DIY?
No, but seriously
Krater
Post by Krater »
true, I´m using a Mutable shades and got used to look at the LEDs, but maybe this just became a habit.
