So, I've decided I need ratcheting in my sequence toolbox. From my understanding, this works by being able to multiply a gate or clock with CV. I'm looking to decide on a module to utilize for this. I've been looking at the Doepfer A-160-5 and the 4ms QCD as my primary options. Clearly, there is space allowance as a deciding factor between the two, but also I'm looking to hear how anyone uses these two for this style, I guess, of sequencing.
I am also interested in hear other options that people use.
And for reference, here is a link to a modulargrid with my plan (I have 6U looking to expand to 9U).
I remember seeing that when it came out. Very impressive, but I'm not super keen on menus. Though, DivKid's video make them seem pretty simple and comfortable to use.
Plus, having it free from my other sequencers would be nice. Thanks!
My personal suggestion (as an A-160-5 owner) is to pair it with a sequential or VC switch of some kind as it will allow for finer control over when you want the ratchet/multiplication to happen. Also, if you do decide on the Doepfer make sure you have a spare attenuator for the VC input as it's the key to taming it's sometimes extreme reactions.
basicbasic, thanks for the suggestions, I recently decided to grab the Doepfer A-150 dual switch for primarily gate uses to go with a RYO Paths. Additionally, is the knob on the A-160-5 not an attenuator at all? Or is that an offset for the CV in?
Frankly, I've pumped myself up about the Varigate 4, but I think I am going to grab that and the Doepfer for different uses.
Not to derail the thread, but I've seen the term "ratcheting sequencer" several times around the interwebs, but I am not 100% on what it means. Would anyone like to clarify?
Radical Ans wrote:Not to derail the thread, but I've seen the term "ratcheting sequencer" several times around the interwebs, but I am not 100% on what it means. Would anyone like to clarify?
I too was confused for a while about the term. So finally I did a bit of research after seeing the A-160-5 (retro version) pop up on Modular Grid.
I found a few videos referring to Tangerine Dream and the repeated steps / multiplications in the patterns. Those repeats being the "ratchets".
