We're writing on top of each other, so some of these points may be already answered, but:
stevebryson wrote:It needed about an extra 2.2K. Could that be because of a voltage offset due to not having the resistors to ground on the op amps, as described by kassu? (It's not like I understand what these words mean - I'm just free associating "voltage offset" with the fact that I had to reduce the gain to slightly below unity.)
No. The input buffer is functioning as a simple analog computer that adds and multiplies. Its output is a linear function of its input, looking something like Vout = Vin * A + B. In a perfect world, A would be exactly 1 and B would be a number that determines the tuning.
Mismatches among the gain-setting resistors could cause the number A to not really be exactly 1, and inaccuracy in the CZ-1's internal voltage measurement could cause you to
want it to not be exactly 1. The trimmer lets you adjust A to deal with these issues.
Offset in the op amp could add or subtract a small, but basically constant, amount from B. There is some offset built into the op amp because of imperfections in the manufacturing process - relatively little in the LT1013 compared to other op amps, which is why it costs more. There is also some offset that results from the bias current flowing into the input resistors. They make a big deal of this in the LT1013 data sheet because many people use the LT1013 in applications where they really want as small an offset as possible. But since the number B is routinely adjustable with the fine and coarse tuning knobs in your circuit anyway, offset within reason doesn't matter to you. The adjustments you're already doing to tune the oscillator in normal operation, will have the effect of compensating for the offset.
stevebryson wrote:The 0.1% resistors are more for temperature stability than precision. But they come in 95.3K, so I'll substitute that. Wow they're expensive, but I only need one per module.
1% metal film resistors with good temperature stability aren't terribly expensive, and I think your trimmer range is wide enough that those would work fine for you instead of the 0.1% kind.
But you could also use both sides of the trimpot, like this, and avoid the need for any precision resistance other than 100k:
On further thought, that's probably a better idea than looking for a 95.3k resistor.
Edit: sorry, I drew the ground connection in the wrong place there... to make it an inverting unity-gain buffer you want the ground into the positive op amp input and the circuit input where I drew the ground. I'm sure you get the idea.
stevebryson wrote:
mskala wrote:Is but if the capacitance is big enough to pass a signal for coupling, then it seems like it would also be big enough to dump that signal into the ground (which might be part of the reason you complain the output is "quiet"...).
Without C5, the output has the same amplitude, oscillating around about 2.5V, so that's not why it's quiet. Can you recommend a better way to get the AC output? Also, am I right to assume the low amplitude is because the chip can only swing from 0 to 5V?
If you're measuring it unloaded (for instance, with just a scope probe connected to the output) then the coupling cap won't eat much of the signal. With a load it might make some difference. I would use a bigger coupling cap, like 1uF; but this is probably not a big deal anyway. I think you're going to need some kind of amplifier on the output if you want more volts, because the CZ-1's output range is limited by its supply.
stevebryson wrote:But maybe I need them because the diode network clipped a -10V to 10V input to about -0.25V to 5.3V, which is within the chip specs of -0.5V to +5.5V, and the chip designer says should be OK with the 10K resistors R5 and R14.[Edit: while I was writing this the chip designer janost says R5 and R14 are redundant] Is that cutting it too close so maybe I should put a voltage divider after the 7805 so U4 never sees anything above 5V?
No! Not when there's already a worry that the chip is measuring inaccurate voltages because of its supply lines; you really don't need another source of inaccuracy. I'd keep R7 and R13, and remove R5 and R14. The designer said that's okay, and I'd expect it to be okay with any ordinary chip. The chip will have its own protection diodes already, the resistors R7 and R13 limit the current through those, and your added diodes D1 through D4 are "belt and suspenders" extra protection.
stevebryson wrote:I've never seen a non-inverting summing amp. Maybe I should actually try to learn about this stuff... But I don't mind adding another op amp if I want to amplify the output. I'm not sure I need that: at higher phase distortion index the high stuff really cuts through. On the other hand it wouldn't hurt... Is using a TL071 to amplify the output consistent with the quality of the rest of the circuit?
Honestly, you could use TL07x types throughout and you wouldn't notice the difference. The main selling point of those fancy LT1013s is their low offset, which you don't really need.
Here's a short article on summing amps, including non-inverting ones:
http://www.circuitstoday.com/summing-amplifier.
If you just connect two voltages through equal resistors to a single point (no amplifier), then the voltage at that point is the average of the inputs.. which is half the sum. So you build that, and then add a noninverting amplifier with a gain of 2, and the result is a noninverting circuit that produces the sum of the input voltages. With more voltages, you use a gain matching how many there are, to compensate the division built into the average. That's the basic theory.
