[Build Thread] Jasper, an EDP Wasp Clone
jasonl
Post by jasonl »
25 January 2017 - 4th run PCBs - ready to ship
It's been too long. Anyway the 4th run PCBs are ready to be shipped.
Essentially the PCB is the same as the previous versions - but I wanted to update the silkscreen to match the current BOM.
A Mea Culpa - I was also tempted to adjust the 'phones out to enable the use of mono Cliff jack sockets as well as the stereo ones used. A very simple change to swap the speaker output to the centre pins on the socket. And I made a mistake here. :doh:
So when a stereo cable is plugged in, signal is only output on one channel, not both as intended. It still works, only affects the 'phones output.
A fix is easy, if you wish to do it. It's not obligatory as the amplified 'phones output is designed for older style high-impedance phones or equipment needing higher input levels. I've attached a note to this post describing the issue and fix. If you're not using the 3.5mm jacks then this is academic anyway.
It doesn't affect the operation of the rest of Jasper - which still sounds great. I built a PCB just using the silkscreen values, not referring to the BOM at all and everything works fine.
Update 31 August 2016
Finally an updated build guide attached below covering the second version PCBs!
Update 14 July 2016
For the second PCB run, an updated BOM taking in account the differences between the second version and Jasper from the first run.
Update 5 April 2016
Finally completed an initial version of a construction guide, and a FAQ document. The construction guide is quite large, and illustrates the construction of the PCB and panel set. Or at least it shows how I make up the PCB....
Here are some audio samples
Update 21 March 2016
PCBs have started shipping!
This is the build thread for the Jasper, EDP Wasp clone PCBs.
The original thread is here: viewtopic.php?t=151625
BOM, PCB and Panel measurements, Enhanced mode PCB construction guide are posted below.
Jasper Construction Guide, FAQs to follow.
Jasper 4th run PCB note.pdf
4th run PCB 'phones jack note
(672.35 KiB) Downloaded 250 times
Jasper2 Construction Guide.pdf
2nd version PCB construction guide with notes about the external trigger mod, new hold switch behaviour.
(8.22 MiB) Downloaded 662 times
Jasper v2 BOM.pdf
Jasper v2 BOM - July 2016
(133.82 KiB) Downloaded 947 times
Jasper FAQs.pdf
Some questions answered
(65.7 KiB) Downloaded 505 times
Jasper Construction Guide.pdf
Illustrated construction guide.
(8.31 MiB) Downloaded 706 times
Jasper Schematic.pdf
Jasper Schematic + circuit notes
(649.63 KiB) Downloaded 630 times
Jasper BOM.pdf
Jasper BOM - April 2016
(108.23 KiB) Downloaded 559 times
Jasper PCB and Panel Measurements.pdf
PCB and panel measurements to help constructing a case around the PCBs
(687.04 KiB) Downloaded 515 times
Jasper Enhanced Mode PCB.pdf
(366.98 KiB) Downloaded 547 times
dalhasumai
Post by dalhasumai »
yay !
LED-man
Post by LED-man »
how about a powersupply, any kind of 12V DC with 1000mA works ?
https://www.DSL-man.de
jasonl
Post by jasonl »
LED-man wrote:how about a powersupply, any kind of 12V DC with 1000mA works ?
Should do. Jasper uses less than 40mA using the line out, or less than 200mA if driving a speaker. Basically anything between 6V and 12V will do.
The MCP1702 I specify has a low dropout voltage of less than 650mA, but has a maximum input voltage of 13.2V. The 386 amplifier runs at the unregulated voltage - again a max voltage of about 12V is sensible.
I've tested using a 9V PP3 battery, linear bench power supply, small wall wart, large 3A 12V power brick....
Noisy (cheap?) switching supplies could affect the keyboard sensing circuit, but I've not had any problems with the supplies I've tried so far.
4floorsofwhores
Post by 4floorsofwhores »
I'm assuming negative leg of electrolytics is the yellow side. Can anyone clarify?
Careful now
jasonl
Post by jasonl »
4floorsofwhores wrote:I'm assuming negative leg of electrolytics is the yellow side. Can anyone clarify?
Yep. Long positive leg goes through square pad.
4floorsofwhores
Thanks Jason. That was quick
Careful now
duff
Post by duff »
PR140 appears to be 50K in the BOM and 100K on the board. Is there a preferred value?
jasonl
Post by jasonl »
duff wrote:PR140 appears to be 50K in the BOM and 100K on the board. Is there a preferred value?
It should be 100K. I'll correct the BOM. Thanks for pointing that out.
In the original Wasp service manual R140 is a sort of 'select on test' resistor for the keyboard sensitivity.
duff
Post by duff »
Ok my first one is up and running.
I had an initially comedy issue of no power - prodded and poked for a while before looking at the schematic and seeing that there should be a switch but couldn't remember installing one. Went over the board looking for where the switch went and couldn't find it. Eventually remembered the switched pots! Switched it on and had power. :oops:
I also initially wondered why I could see a trigger on the link header but my envelopes and VCA would not fire but I had missed LK1 out.
Now I just need to work out why I have permanent pitch modulation, but that can wait for tomorrow.
Edit: Oh and the pink stuff Tayda uses to pack ICs is the perfect height for lifting the alpha pots up to meet the panel.
jasonl
Post by jasonl »
duff wrote:Ok my first one is up and running.
Wow, that was quick! :yay: :sb:
Excellent idea to use the foam as spacers for the pots. I'm just completing the build I'll use to illustrate the builders guide so might suggest that as an alternative to the way I've been doing it.
Re the pitch mod - check that R62 is 470ohms - this sets the minimum gain for the LFO/pitch voltage when VR4 is counter-clockwise.
Again, well done for getting Jasper built so quickly!
jasonl
Post by jasonl »
I bought a 50k. Can I transform it into 100k? Thx
A 50K might work if you replace R140 with a larger value - try 68K to start with. PR140 is used to centre the point of the sensitivity pot at which the keyboard self-triggers.
duff
Post by duff »
jasonl wrote: Re the pitch mod - check that R62 is 470ohms - this sets the minimum gain for the LFO/pitch voltage when VR4 is counter-clockwise.
Turns out my pitch mod issue was a stray component lead offcut, so that was easily solved.
Thanks for the great project it was a nice straight forward build - although soldering 626 IC pins in one go was a bit of a slog! To be fair, I am not quite finished; My hold switch is a jumper, I am short a 9mm A50K pot for Osc 2 level (currently also a jumper), and I need to replace the sensitivity and tune trimmers - I used pots with standard length shafts as I had some to hand, but they are way too short. I also need to decide if this one is getting a speaker and/or batteries....
But for now :nana:
Paradigm X
Post by Paradigm X »
Amazing work duff. :yay: and jason of course, looks like an easy and satisfying build. def in on round two!
:hyper:
SmartBits
Post by SmartBits »
I would like to order most components from Mouser (and TME.eu) in order to avoid nooby mistakes, but the
Hold switch (hold mod SPST) from the BOM has no stock at Mouser. What alternatives can I use from either Mouser or TME?
LED-man
Post by LED-man »
SmartBits wrote:I would like to order most components from Mouser (and TME.eu) in order to avoid nooby mistakes, but the
TME: 25346N
jasonl
Post by jasonl »
TME: 25346N
That's for the power over Link switch (which could be left out if you're not using the 8pin link sockets, or replaced with 0.1" 3 pin jumper.
The hold switch is a sub-miniature toggle switch (either SPST or SPDT) - On-Off or On-On.
From TME, try: TSSM1022A1 or TSSM1022A2 - the latter may be better as it uses PCB pins that can be cropped closer to the switch. There's not a lot of room underneath the panel.
:guinness:
jasonl
Post by jasonl »
Double-post
SmartBits
Post by SmartBits »
Great, thanks!
SoundPool
Post by SoundPool »
nevermind. I apparently can't open a package correctly. :ripbanana:
jasonl
Post by jasonl »
SoundPool wrote:got mine today- board and panel look great! While I can get most of my basics from Tayda and it looks like almost all the rest from Musikding anyone have any other sources for the switched pots from Farnell? Looks like international shipping might be a real pain for them. Preferably somewhere that offers fair international shipping (to Norway), or ships in Germany since I'll be there and can pick stuff up in a month.
You should have got a set of switched pots with your PCBs. :hmm: PM sent.
Grumskiz
Post by Grumskiz »
Just sent out an order for most components, but forgot to add the LM386 :doh:
Is there a good substitution that I could already have in my part stash or does it have to be this part exactly?
4floorsofwhores
Noobie question again sorry. Can i leave out the link sockets? do i need to link anything? cheers
Careful now
jasonl
Post by jasonl »
Grumskiz wrote:Just sent out an order for most components, but forgot to add the LM386 :doh:
Any Lm386 or NJM386 should work - I tested with various -1 -3 and -4 variants and they all seemed to work OK. It's an audio amplifier, not a conventional single opamp, so a 741 or TL071 won't work.
However, if you just use the line output jack, you don't need the LM386 at all. 8-)
jasonl
Post by jasonl »
4floorsofwhores wrote:Noobie question again sorry. Can i leave out the link sockets? do i need to link anything? cheers
They're not obligatory... But in my opinion Link is part of the fun things with Wasp/Jasper, as it lets you connect more than one together, or use a sequencer like the Spider, or an external Midi-Wasp adapter. Whether you want to use the on-pcb sockets is up to you, and depends a bit on how you wish to enclose the PCB.
