It is not actually white as it appears in the photo, it is weird lighting. it is silver aluminum metalphoto, as per usual
the sound is the same as the DIY version. it actually runs the same code, and detects the hardware to know what to do with interface changes.
differences:
more blinky lights,
momentary switches instead of latching
select effect by pressing sel, then the one you want rather than cycling through
CV control of the 3 main wave selectors and the mod wave selector.
4 layer modern PCB with SMD parts, slightly less noise.
reverse power protection on connector
more efficient regulator
you need a separate programmer (not very expensive, its just a USB jack and IC with abootloader that connects to a heade ron the back) to modify firmware, so DIY firmware tinkerers need to keep that in mind.
can be powered through programmer and synth power at the same time
words changed again (sorry!)
sound wize they are the same. the only thing "extra" are 2 different features in the drum effect because you no longer need "cv swapping" now those 2 buttons create a more gradual drum tail on their respective drum envelopes.
I have to say, I've been following the development of the Orgone Accumulator with great interest through each and every firmware update there's been.
It's moved from being what was a great oscillator to what I now consider to be the very best oscillator, noise machine, drum module all rolled into one.
I really can't wait for the retail version, but will also be keeping my original DIY version for twin Orgone action.
Kroaton wrote:Will you still be selling DIY kits through Thonk?
thonk and synthcube will still have diy. as long as they want them, ill keep reordering.
You mean the first version or this new version too?
I am not sure about the new version in a kit because the through hole op amps for the cv inputs might take up too much space. if i do it it will not be for a while because i am working on the hardware for another module.
Yay! I've been looking real hard at getting one of these but the DIY backlog is too long and time consuming I'd gladly pay to get a manufactured unit. Who's reselling in the EU? EFN I hope!
Summa wrote:Yay! I've been looking real hard at getting one of these but the DIY backlog is too long and time consuming I'd gladly pay to get a manufactured unit. Who's reselling in the EU? EFN I hope!
as far as i know, anyone who sells WMD can stock them.
had a chance to hear a DIY version of this module. It's glorious. Everything I wish my Shapeshifter had been. I'm looking at my VCO-2RM and wondering if i still need it...
The Book of Bad Ideas - A compendium of knowledge from Muffs. Download it here: http://bit.ly/1oz2zaI
Congratulations! This makes one of the most exciting, exotic modules in Eurorack accessible to dullards like myself who cannot be trusted with a soldering iron.
