disting mk3 firmware announcement thread
This thread is where new firmware for the disting mk3 will be announced.
Please post comments, requests etc. as new threads.
New album "Rolling Like A Bullet" out now:
https://andrew-ostler.bandcamp.com/albu ... e-a-bullet
10th December 2015 - version 3.1:
* Fixed menus not traversing correctly when turning the encoder.
* Pressing Z now cancels any menu.
* Prevented knob recorder playback from stopping immediately if the knob is being turned as it's released.
* Pressing Z in the Sample & Hold algorithm now triggers a manual sample.
* Added a tape length parameter to the Tape Delay algorithm.
* Added check for corrupt calibration data at startup.
* Added check for invalid calibration data before writing calibration to flash.
http://expert-sleepers.co.uk/distingfir ... dates.html
- phutureboy
- Ultra Wiggler
Installation went flawlessly. It might be an astute idea to add the link to firmware updates here:
http://www.expert-sleepers.co.uk/downloads.html
FS: EMS AKS | YAMAHA VL-1m | WTB : Syntech E951
the new firmware working great for me!
i used 3v out from a second disting's precision adder to calibrate it.
i did have to do the calibration about 4 or 5 times for it to calibrate correctly from some reason. the precision adder on the newly updated one output a voltage slightly above zero (just enough that it would change the pitch of an oscillator noticeably) when it was supposed to be zero, but i repeated the calibration process a couple more times and got it working good now.
soundcloud: https://soundcloud.com/brandon-logic
instagram: https://instagram.com/blogic12/
current eurorack: https://www.modulargrid.net/e/racks/view/438362
all time favorite songs playlist: https://open.spotify.com/playlist/0JcZq ... cbdb9f44f7
Good to hear, thanks.
- komprezzor
- captainhooke
I'm showing some new stuff at NAMM, to be released straight after.
- captainhooke
- captainhooke
***New features include
- a clockable ping pong delay effect.
- 10 envelope generator algorithms, including clockable envelopes, dual envelopes and combined envelopes/VCAs.
- quantised and unquantized random voltage generators.
- random trigger generators.
We’ll also be showing an experimental new firmware version that allows WAV file playback from the MicroSD card slot normally used for firmware updates.***
Yes yes yes!! Gimme now please!!
- orangehexagon
Probably still sleeping
modular explorations,patches and more: http://www.youtube.com/c/AuxarNetlabel/
Twitch.tv: https://www.twitch.tv/auxartv
soundcloud: http://soundcloud.com/auxar-netlabel
Instagram: https://www.instagram.com/auxar/
- giftculture
I found a bug while testing at NAMM, which I need to fix. Still expecting to release very soon.
Version 3.2 is released.
* Added clockable ping pong delays, envelope generators and shift register random algorithms.
* Fixed save/restore of parameters over a power cycle.
- captainhooke
- lessavyfav
- Ultra Wiggler
Got mine today! Gonna try upping to 3.2 tomorrow it shipped 3.1 apparently. I have one question/request- please add or help me hack the code to add a parameter to the pitch/envelope tracker to gain up the envelope. I can get good tracking from line level input signal but the envelope is so way low that it is unusable without preamping. I don't have a dedicated preamp and Clouds seems like an expensive gain stage. If this is not possible I'll get sdiy cracking for a small/decent line- modular system
Good suggestion - I'll put that on the list for addition.
