Volca beats mod in to Euro power supply ?????
cynical
Post by cynical »
Hello people
I am trying to make my Volca powered from my Eurorack power supply , and here is what i have find out (and maybe wrong). I need a voltage regulator and a resistor to decrease the +12V to +9V but, since i am newbie here are some unresolved question that i have.
1st were i am going to put the regulator and resistor? ( a thought was on the + battery point on the PCB ).
2nd can i put a cable on the GND point of Volca to connect the GND of power supply there?
3rd Has anybody done something similar to this and ca give me guidelines ?
PWM
Post by PWM »
How many question marks does one need?
Google; 7809 connection. You'll find your answer there.
https://www.google.nl/search?q=7809+con ... 4UCh0qAQny
Don't forget the bypass caps connected between the input and ground, output and ground of the regulator. 100nF should work fine.
You could place a 10 Ohm resistor before the regulator. Like this;
+12V -///- voltage regulator input.
-///- being the resistor.
cynical
Post by cynical »
PWM wrote:How many question marks does one need?
Have you done something similar ? could that be a schematic ?
also i saw that the caps values should be 100nF not uF.
PWM
Post by PWM »
I have done, loads of times. Not for the Volca's, though.
That's why I said 100nF..?
What you've drawn should be fine. You could get rid of 1 of the caps at the output, and make those 100nF. (If they where 100uF they would be polarized)
Also, you've drawn your resistor to be a 10k, that should be a 10 Ohm.
jmagin
Post by jmagin »
You don't want the 10 ohm resistor. In the three-terminal regulator, the internal pass transistor is the circuit element that the voltage drop is developed across. With a series resistor on the input, you'll just mess up its ability to regulate effectively. See figure 6 in the datasheet:
https://www.fairchildsemi.com/datasheets/LM/LM7809.pdf
It is true that a maximum of 3V * 600mA = 1.8 watts may be dissipated in the regulator, so attach a heatsink of some sort. Well, the adapter they sell for the Volcas is rated 600mA, maybe it doesn't use that much typically.
flts
Post by flts »
mmagin wrote:It is true that a maximum of 3V * 600mA = 1.8 watts may be dissipated in the regulator, so attach a heatsink of some sort. Well, the adapter they sell for the Volcas is rated 600mA, maybe it doesn't use that much typically.
The peak consumption is around 80mA @ 9V: http://matthewzipkin.com/tvv/ ... So doesn't really draw that much current.
Never stop loving music
jmagin
Post by jmagin »
flts wrote: The peak consumption is around 80mA @ 9V: http://matthewzipkin.com/tvv/ ... So doesn't really draw that much current.
Cool. I was being pessimistic. That's a lot closer to what I would have expected!
nurbivore
Post by nurbivore »
It sounds like you want to do things even more DIY, but for the sake of future searchers, I just wired in one of these to power my Beats and Keys, and haven't had any problems. My only complaint is that the Volcas don't have real power switches, so I have to turn each one on individually in addition to the power.[/url]
