Remix/ReMangle" Challenge is Closed. Now to work on the file management, uploading, playlist, voting thread, etc. Thanks to all that participated. Get ready to vote!
Prizes generously donated by:
ADDAC System (Eurorack 3U)
Endorphin.es (Eurorack 3U)
Studio.h (Buchla-format 4U)
Challenge rules and format thread is here.
Doepfer - banana conversion
the bad producer
Post by the bad producer » Thu Mar 11, 2010 8:10 am
Just done a 'how-to-banana-jack-a-doepfer-module-picture-story' if anyone is interested, it is really easy, a module like this takes about ten minutes all in...
Charlie
Noah Vail
more vintage than you
Post by Noah Vail » Thu Mar 11, 2010 10:02 am
Wow! Great pix, too. You're inspirational.
Thee Loving Hand
Post by Thee Loving Hand » Thu Mar 11, 2010 10:44 am
you rule!
thanks for the step by step!
i
the bad producer
Post by the bad producer » Thu Mar 11, 2010 10:48 am
Thanks guys - I actually missed one pic out ( :doh: ) once you've pulled one side of the shit socket out, you bend it right back until you can get the iron under and against the two other legs of the shit socket, then it just pops out!
We need one of these:
:deadbanana: but with a cliffjack...
BananaPlug
Post by BananaPlug » Thu Mar 11, 2010 11:30 am
Getting the jacks out without lifting traces is the hardest part.
the bad producer
Post by the bad producer » Thu Mar 11, 2010 11:34 am
BananaPlug wrote:Getting the jacks out without lifting traces is the hardest part.
Yeah, they seem a bit thin, you can see I did that on that module, but there is always somewhere else to attach the cable, I've converted a few Plan B and never had that problem, it does seem to occur only with the single sided boards Doepfer use.
darenager
Bad Mother Fucker
Post by darenager » Thu Mar 11, 2010 12:10 pm
Nice job!
If you are not going to need the cliff jacks you could try using some small sharp sidecutters to snip the legs off flush to the board, then just use a solder sucker to clean out the holes, I have done this when removing stuff and it reduces the risk of lifting the pads. It does very much depend on the board and component being removed as to it being possible though, but could be worth a try.
Looks very nice with the bananas and serge style knobs :yay:
EDIT - The straws remind me of the old Humphrey milk ads :lol:
the bad producer
Post by the bad producer » Thu Mar 11, 2010 12:17 pm
I tried that, but it was a bummer, you need to melt the jack with the iron to get the cutters in close enough, this method seems to have a (roughly) 95% non-pad-lifting success rate!
Yeah, Burger King straws, stop the knobwobble a bit...
Gotta :love: the acid! I've watched quite a few of your clips - great stuff :tu:
DGTom
Post by DGTom » Thu Mar 11, 2010 7:01 pm
:yay:
All these older Doepfers are so simple & look so good with bananas.
I 50/50 cut them off & desolder, the plastic sockets are so pissweak you can just cut the face of them right off :hihi:
Then I bend the metal tabs up & remove the rest of the plastic, then each metal part just falls out when you heat the bottom. Totally minimizes the risk of lifting traces... its a little brutal / RSI inducing but kind of theraputic & means those shit sockets will never harm another module :goo:
the bad producer
Post by the bad producer » Sun Mar 14, 2010 8:40 pm
DGTom wrote: ...the plastic sockets are so pissweak you can just cut the face of them right off :hihi:
thats the way to do it!...
just checkin out your avatar Tom... mmm nice cliff jacks :hihi:
DGTom
Post by DGTom » Sun Mar 14, 2010 8:49 pm
:lol: :lol:
I should prob. change that now those modules have been fixed huh!
I just liked the pink & green LED lighting... now I have more modules in that case they don't shine thru so much... but the bananas do have a nice glow :goo:
mirri
Post by mirri » Mon Mar 15, 2010 4:01 am
Booohoooo, why didnt i bananafy my doepfers instead of selling...
M
Reality Checkpoint
Confused By Electricity
Post by Reality Checkpoint » Mon Mar 15, 2010 6:08 am
You are inspirational.
I am now seriously considering getting into learning how to build my own stuff. I have been considering this for some while now, but as I know jack shit about all of this, and I mean jack shit, I have always not had the confidence to start. Time to change that.
Cheers! :hail:
BananaPlug
Post by BananaPlug » Fri Jul 16, 2010 8:44 am
This thread looks like the closest thing we have to a generic how-to-bananafy Doepfer thread so I'm extending it.
Converting a skinny 4u A-148 dual S&H module
I have rather specific plans for this module and chose to leave a mini jack on one of the inputs. The banana jacks are deep and would hit some of the components so I used bushings on the jacks. Could have gotten away with thinner bushings but used what I had.
sog
Post by sog » Thu Jul 29, 2010 6:04 am
what are the benifits of putting in banana jacks? im a noob :confused:
BananaPlug
Post by BananaPlug » Thu Jul 29, 2010 7:00 am
sog wrote:what are the benifits of putting in banana jacks? im a noob :confused:
The patch cords can be stacked. No more mults! They are also way more reliable due to the huge contact area and sturdier, without being big and heavy like 1/4"jacks.
:nana:
sog
Post by sog » Thu Jul 29, 2010 8:16 am
o right now i understand. thanks! 8_)
Reese P. Dubin
Post by Reese P. Dubin » Thu Jul 29, 2010 3:28 pm
What modules present the switching jack conundrum? I know there is always a workaround, however these doepfers seem to keep free space at a premium. Always tons of this stuff getting dumped cheap by Serge lusters, might have to do some creative picking.
BananaPlug
Post by BananaPlug » Fri Jul 30, 2010 6:35 am
Right, there's no switching banana jacks but of all the jacks on a typical modular a minority have a switch function (RTFM) and of those, a good number are for things you can easily patch point to point with short banana patch cords. The ones you want to do something about are for things like internal/external clock. For those you drill a hole and add a switch. You might not be able to do that on a crowded 4HP module but otherwise there's usually room. Plenty of examples to be found on this forum.
FYI, stacking is electrically the same as using a non-buffered mult. For combining signals you still need a mixer.
:nana:
sog
Post by sog » Fri Jul 30, 2010 8:23 am
can i use a 15v system with banana plugs together with a eurorack system with banana plugs?
Luka
Post by Luka » Fri Jul 30, 2010 8:34 am
as long as the psus are connected by ground
boramx
lepidopteran orgasm
Post by boramx » Sat Nov 13, 2010 8:45 am
guys, this is killer, and i'm *partially* motivated to try it. though the price of all those jacks will add up.
have you guys converted the harvestman, mallekko, and make noise modules that have the PCBs mounted very close up to the faceplate, and parallel too?
seems trickier given the depth of bananas.
i'm sure it's possible. admittedly i'm a bit lazy about DIY. if i can knock out the whole project in two weeks i'll do it. if it drags on becuase i have to alter PCBs, perhaps not.....
anyone....?
BananaPlug
Post by BananaPlug » Sat Nov 13, 2010 9:43 am
the bad producer
Post by the bad producer » Sat Nov 13, 2010 10:18 am
Yes please!
:nana: :cloud: :cloud: :nana: :cloud: :nana: :nana: :nana: :cloud: :nana: :cloud: :cloud: :nana: :cloud: :nana: :nana: :nana:
:nana: :nana: :cloud: :nana: :cloud: :nana: :cloud: :nana: :cloud: :nana: :nana: :cloud: :nana: :cloud: :nana: :cloud: :nana:
:nana: :cloud: :nana: :nana: :cloud: :nana: :nana: :nana: :cloud: :nana: :cloud: :nana: :nana: :cloud: :nana: :nana: :nana:
:nana: :cloud: :cloud: :nana: :cloud: :nana: :cloud: :nana: :cloud: :nana: :cloud: :cloud: :nana: :cloud: :nana: :cloud: :nana:
solaris
Location: ̋͋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̏̏ ̏ ˳̊̊̊̊̊ ˳̥̥̥̥̥̊̊̊̊̊̊̊˳̥˯Ξ̿̿̿̿̿̿̿̿̿̿▂ ̋̋̋̋̋̋̋̋̋̋
Post by solaris » Sat Nov 13, 2010 10:24 am
At the risk of losing 10 points with the following n00b question, I'd like to ask: when converting input Jacks to Banana what happens to the earth wire?
(I did a quick search but couldn't find the answer...)
