Klangbau Köln Logistische Gleichung - any experiene ?
Hi
in search of an semi random module (mainly for cv modulation of parameters) i came across the "logistische Gleichung" --> http://www.klangbauköln.de/rnd-modul-lo ... gleichung/
do someone of you use this?
the info says it gives out random to repetetive sequences according to the clock input - adjustable by one distribution knob.
any videos demos?
thx
any videos demos?
thx
- flx
Sorry for reviving this old thread. I must have missed it back then! I've had the Log Equation module for a while.
Ringhausen posted a video demo of the Klangbau Logistische Gleichung in which it sequences the pitch of a VCO:
In this video I let the module ping my Twin Peak filter (which is awesome because the filter responds to the strength/amplitude of the pings so nicely):
Re: Klangbau Köln Logistische Gleichung - any experiene ?
I use and quite like the combo "Logistische Gleichung" and a trigger delay. There was a good article (in German) in "Synthesizer Magazin" no. 52 that can be bought (as pdf) here: http://synmag.1a-shops.eu/m:o wrote:Hi
any videos demos?
thx
Can't say I fully comprehend what is going on but you can often find interesting sequences.
- flx
Here is how I understand it (I'm not a math guy at all):101010oxo wrote: I use and quite like the combo "Logistische Gleichung" and a trigger delay. There was a good article (in German) in "Synthesizer Magazin" no. 52 that can be bought (as pdf) here: http://synmag.1a-shops.eu/
This is the typical distribution of the log equation output (the knob on the module increases the "chaos", going more towards the right of the graph):
So the CV basically always goes high, low, high, low etc. but in different amounts. You can hear that the patterns stay less chaotic when the knob is turned more to the left. The high/low points can even cross, but they always stay in a certain range, as depicted in the graph.
If you feed the CV into a CV Trigger Delay, the "high" CV will delay the trigger longer than the "low" CV, but because both usually alternate, you will get almost swinging patterns.
I'll see if I can film a demo video of it sometime.
Edit: Meanwhile, go to 1:09 in the above Ringhausen demo video or click here:
He starts with the knob at the left and turns it up. Like in the graph above, the high/low CV distance increases and gets more "random" the further he turns the knob to the right.
klangbauer
Logistic Equation
LogGleichung or LogEquation is an algorythm borrowed from Biolocy. It describes up and downs of two populations. See diagram from flx, it is called "Feigenbaum diagramm".
It has a limit and unpredictable phases. The random part we use for our module. Becaus it is chaotic it produces selfsimilar results. I call it melodies, because it is not radically random.
At the moment we are developing a real analog version, with more live inside. Because it is a module that calculates, it is an "Analog Computer" device with a real S/H for feeback.
See Doepfer´s page and look at patch samples. You can try to patch it in your system also, luck.
best klangbaukoeln
best klangbaukoeln
Re: Logistic Equation
http://www.doepfer.de/a100_man/a100_patch.htmklangbauer wrote:[...]See Doepfer´s page and look at patch samples. You can try to patch it in your system also, luck.
Look for "Chaos Patch"
That sounds interesting! Any idea when that might be done?klangbauer wrote:At the moment we are developing a real analog version, with more live inside. Because it is a module that calculates, it is an "Analog Computer" device with a real S/H for feeback.
Just to mention that the Quantermain app in the Ornaments and Crime module includes a quad channel logistic map (logistic equation) implementation, with or without quantisation, with voltage control over the r (distribution) parameter. See https://github.com/mxmxmx/O_C/wiki/Orna ... uantermain
stonegrizzly
- Learning to Wiggle
klangbauer
klangbauer
Logistic Equation - The moudle
After Sines and Squares 2016 in Manchester the Logistic Map module build fully analog - as an analog computer - is ready.
It produces a rich variety of CV´s. Every module is a bit different because it is depentent of parts and other external parametes. I think that is great. It works in a loop with my new developed "true S/H" on board.
It has a Trigger in, CV in and Chaos out. It reproduces a "Feigenbaum Diagramm" on the scope, if a synced ramp from the scope controlles CVin.
If you are intereseted please ask me for further details.
Re: Logistic Equation - The moudle
How does the output differ from the previous version? It being analog is very interesting but I am primarily interested in the resulting CV/triggers...klangbauer wrote:If you are intereseted please ask me for further details.
Also a picture of the module would be cool!
You are saying it is available? What is the price?
err... klangbauer posted a picture of the module just one post above101010oxo wrote:
Sorry, must be me but I don't see one above... Link please?novotnik wrote:err... klangbauer posted a picture of the module just one post above101010oxo wrote:
klangbauer
Details of Logistic Map
After designing a double or true S/H is it possible to build an analog version of my LogGl. It is a real and small analog computer. Because of its instable nature every module runs a bit individual. It creates a rich variety of CV textures that changes over time. To find a stabel or peridoic part is a challenge. CV input is implemented. CV-input pot works as a magnifier if nothing is connected.
No random - chaotic, and analog !
- Paranormal Patroler
Weirdly enough the results on the videos sound very different to what I get when I patch the Logistic Equation using the doepfer patch. I get repeating patterns in a large range of the k/r constant, always between 3.57 and 4.
The patterns might be large in length, but they repeat.
klangbauer, are these available anymore?
Iam Curious about this as well.
Does the cv output of the digital and analog version differ?
Klangbauer wrote that there is more live in the analog version ... what does that mean?
I also noticed that the analog version has a cv in for the distibution wich the digital version of the log gl modulrs doesn't have...too bad.
Re:
I got a reply from klangbau and they say that the digital version is available as a single module or as a combo module with the trigger delay...
- flx
Nice! I have got their trigger delay as a separate module. It’s really useful together with the digital LogFn for feedback though, so a combo module makes sense.
thanks for your reply.
i saw that you also have/ had the analog logGl module.
is there a difference to the digital version despite the missing cv in for the distibution and the trigger out?
also i wonder if the distibution cv-in makes sense for you? or did you rather set distibution by hand?
