I wanted a serious monosynth that would play nicely along side my monster portable.
DETAILS
Both this case and my other portable used the same piece of Bubinga wood and I still have a little left that I might do more with! The original piece of Bubinga was 14' x 19"!
I had to remove and replace the original resistor chain on the keybed as the original was calibrated for Volts/Hertz as opposed to 1V per octave.
I used MFOS 1V per octave PCB and I must say, Ray was extremely helpful with getting performance dialed in tight!
I used the original steel bottom pan and keybed with modulation wheel and switch. That is the only original parts that I used from the original Korg.
From the original dimensions I extended an additional 1 and a half inches toward the back to accommodate my PSU and the space needed to make my design on top functional.
The handle has several functions. First when not being carried it can fold down in front to protect the keybed. Second it can fold down in back to support the case.
The rest of the case is made out of .060 aluminum, making it very light, yet strong. ProOne PSU has plenty of power. Synthrotek flying bus boards and customized bus boards for the Erthenvar 1U tiles.
Filled it with several of my own custom modules too
I will be bringing this to the Denver Synth Meet!
_______________________________________________________________________________________
