I'm trying to wire up this batboy to the mains and I am wondering what "COM" means on this thing?
What you labelled GND is actually the mains earth connection and is absolutely vital for safe operation. For security reasons COM/0V should also be tied to earth, preferably at the point of distribution.NS4W wrote:Ah ok, that's what I thought. But what is the difference between 0V and GND? I assumed that was the same.
The PSU in my monorockets does not have the COM wiring post.
And I am very careful, that is why this has been taking forever to finish up...
So what you are saying is that I should have a cable going from COM to earth(what I labelled GND)?roglok wrote: What you labelled GND is actually the mains earth connection and is absolutely vital for safe operation. For security reasons COM/0V should also be tied to earth, preferably at the point of distribution.
yes, you must connect them together at one point, preferably at your busboard/distribution point. search the forum by posts by Graham Hinton, he knows a thing or two about power supplies and safetyNS4W wrote: I am still unsure what you meant though Roglok. Should I also wire earth and COM together?
i wasn't referrring to a specific thread. graham posts occasionally about the subject of grounding and safety and it's always valuable advice. here's what i found doing a quick search:NS4W wrote:Ok. I cannot find the thread you are referring to, but I will pass a wire from the COM post to the mains earth.
No, roglok just told you the correct way to do it and you missed the most important point: "preferably at your busboard/distribution point".NS4W wrote:Ok. I cannot find the thread you are referring to, but I will pass a wire from the COM post to the mains earth.
You will bypass it, but it is only there to bypass hf noise when the PSU is floating.Siri wrote: I didn't do it on mine, as I was looking at the schematic in the data sheet and you can see a capacitor between COM et GND so I thought if I connect them together it will bypass the capacitor, right?
You can ask Tony what he thinks he is doing as he is on this forum. Do not worry about "earth loops", that is just voodoo talk. You can get mains hums and eddy currents, but not just by creating a loop and on a modular system you create loops every time you plug in a patchlead. It is better to ask why there are different voltages in 0Vs and why current is flowing.I also read Oakleysound's PSU manual (here:http://www.oakleysound.com/psu3-um.pdf) and he has an elaborate system about having several grounds (to prevent earth loops?)
Common 0V always needs to be connected to mains Earth at one place, but there is a finite limit to how far you can maintain this. A couple of adjacent rack units may be done with very heavy wiring or busbars, but wallpaper systems require a different approach.so in my head it looked like COM/0V doesn't need to be connected to main's earth.
That is the problem. If you want to build something as complex as a synthesizer you need some background in electronics theory, otherwise you are just soldering. Everything that I have explained is a simple application of Ohms's Law and Kirchoff's Law which are the very first things you learn in electronics. You can read about them on web pages, but you really need some tutoring and to follow exercises to get the feel of them. They are the foundation that everything is built on so to it is worth investing some time in learning them properly.There should be a sticky about it, as a lot of people building synth here are self-taught without electrical background.
I am preparing some new reference pages covering this on my web site.It would be nice to have a detailed post about grounding, sharing ground, and ground loops, with nice illustrations!
I guess 98% on these forums are naive amateurs like me knowing only the very basics and understanding even less about it. Still I have managed to build several DIY modules just by following instructions and getting help on this forum, maybe I'm just soldering as you put it but in the end no one is thinking about that when they hear the sounds coming out of it.Graham Hinton wrote: That is the problem. If you want to build something as complex as a synthesizer you need some background in electronics theory, otherwise you are just soldering. Everything that I have explained is a simple application of Ohms's Law and Kirchoff's Law which are the very first things you learn in electronics. You can read about them on web pages, but you really need some tutoring and to follow exercises to get the feel of them. They are the foundation that everything is built on so to it is worth investing some time in learning them properly.
Like this?Graham Hinton wrote: No, roglok just told you the correct way to do it and you missed the most important point: "preferably at your busboard/distribution point".
Connect your mains earth to the Gnd connection on the PSU, this is to earth the PSU chassis parts for safety.
Do not put a wire between Gnd and Com on the terminal strip, instead connect the PSU to your distribution board and the mains Earth to your distribution board and join the Com there.
Graham,Graham Hinton wrote: Connect your mains earth to the Gnd connection on the PSU, this is to earth the PSU chassis parts for safety.
Almost. Don't use the PSU terminal as a junction. The mains Earth should go to a big post where it enters your system, if you have a mains inlet on a chassis it should be right next to the inlet. From there wires should go out separately to each place that needs to be earthed.NS4W wrote: Like this?
Yes, there is no difference here between a digital and a linear PSU. Both have floating outputs that need to be anchored to a reference so that the 0V common is not altered.Stewart Pye wrote:Is this what you would recommend when using a linear power supply also?
Not to the PSU output terminals, but it may need Earth for its chassis and maybe mains filtering.Say you have a 3A linear power supply and 6 busboards. Do suggest not connecting mains GND to a 0V terminal on the PSU PCB, but directly to the chassis,
Yes, but it becomes difficult to maintain a 0V common between separate bus cards when you have that sort of current flowing, especially if the rails have unequal loads because the difference will be flowing in the 0V. It becomes even more difficult when there are multiple PSUs. You can never have thick enough wire which is why I'm now building busbars and I'm using up to eight 32/0.2 wires to connect to them.and from that point to each of the busboards, and also connecting 0V of power supply to oV on busboards with thick wire???
Even with a wire going from the COM to the Earth pin of the power entry, which seemingly shorts out that capacitor, that cap will in fact still pass some high frequencies.Siri wrote:Interesting thread! I didn't do it on mine, as I was looking at the schematic in the data sheet and you can see a capacitor between COM et GND so I thought if I connect them together it will bypass the capacitor, right? I'm far from an expert, just a muffwiggler self-taught.![]()
Your drawing is basically correct, but a lot depends on the physical layout and resistances of the wires involved.acilator wrote:can somebody please check this and confirm or this is the wright way to go, or please give me some tips how it's better..
It can never be thick enough. Two 32/0.2s fit in a blue crimp terminal, five in a yellow. If you are carrying 2A or more you'll find that even eight or ten wires paralleled still produce a noticeable voltage drop.acilator wrote: I wanted to use even a thicker wire for everything between the main power inlet and the PSU/main Earth, it's 1.5mm2 instead of your recommended 1.0mm2 (32/0.2). For the wiring between the PSU and the busboards I'm probably going to use the 24/0.2 (0.75mm2). Or is it better to use the thicker wire 32/0.2?
