[Back again] Adjustable +/- PSU for TTSH/Others
Altitude909
Post by Altitude909 »
New Run!
New routing, simplified design. 115V ONLY
https://michigansynthworks.com/products ... u-pcb-only
BOM
Since this involves wiring mains, I am not supporting this beyond the BOM and PCBs, if you dont know exactly what's involved and how to wire it up safely, this is not for you.
limpmeat
Post by limpmeat »
I'm interested!
Altitude909
Luka
Post by Luka »
how is this going? any eta for the release?
if it is going to happen soon-ish is it possible to get a technical diagram of the board so i can add the mounting locations into a case design.
Altitude909
Soon. I have a spare prototype board if you're in a rush..
Luka
Post by Luka »
i wouldn't say im in a rush but id like to get this case fabbed in a couple of months time and i'd like all mounting holes set.
Jack Gull
Post by Jack Gull »
I might be interested but... 0,8A per rail max?
latigid on
Post by latigid on »
Tentatively signed up, might look at another solution providing a 5 V out though.
Altitude909
Jack Gull wrote:I might be interested but... 0,8A per rail max?
No, I wasnt clear on that, sorry. 50VA Trafo = 2 x 15V 1666 mA. vRegs are 1.5A max each
roglok
Post by roglok »
are the heat sinks effective enough for these specs?
Altitude909
Should be, those are the 40mm ones but taller ones can be used. I am in the process of load testing and will report back if there are any issues.
LED-man
Post by LED-man »
When is the closing date of the groupbuy?
i need the pcbs around mid march.
https://www.DSL-man.de
Stewart Pye
Post by Stewart Pye »
Actually 925mA is the maximum DC output current for 1666mA secondary current...
mOBiTh
Post by mOBiTh »
I've signed up for three depending on cost.
Altitude909
Prices are up. Invoices going out
sduck
experimental use of gravity
Post by sduck »
Any chance you could post a list of who's ordered? I can't remember if I did or not, but would like a few.
ultravox
Post by ultravox »
Can it be adjusted to other voltage levels i.e. +/-12V to +/-19V?
Altitude909
ultravox wrote:Can it be adjusted to other voltage levels i.e. +/-12V to +/-19V?
9-15V DC on either rail
ultravox
Post by ultravox »
Ok thanks. Was going to use it in the crOwBX but it takes 19V.
Altitude909
ultravox wrote:Ok thanks. Was going to use it in the crOwBX but it takes 19V.
TBH, I haven't done the math on what the max is with a ~20V DC input but you should be able to go higher by tweaking some resistor values and by going to a high voltage transformer
ultravox
Post by ultravox »
I'm thinking along the same lines. Oldcrow tweaked the HAA15-0.8-A to give 19 volts so I'm guessing your linear PSU can be modded in this fashion too. :tu:
Altitude909
Well the LM317 can go from 2.5 to 37V but I focused on the common range of 9-15V DC and the transformer is geared toward that. they make an 18-0-18 that would give you 24V DC on the input of the vReg which should be plenty for a regulated +/- 19V
ultravox
Post by ultravox »
Cool, so I'll build one for 15V DC and one for 19V DC. Thanks for the tip on the 18-0-18 transformer.
sduck
Post by sduck »
edit: never mind, got my invoice. Thanks!
Benjamin AM
Post by Benjamin AM »
What are the dimensions of the completed board??
