backup here: http://electro-music.com/forum/viewtopi ... 150#407150 and on my website
General TTSH postings like Availability and more here:
viewtopic.php?t=82997
TTSH Ver.2 (7.1 on pcb)
Released: 5.January 2015
Release Info:
Changes between first Version and rev.2:
• Powersection, two 1 inch voltage converter, embedded powerregulator like nordcores v1 addon pcb, 3x SMD inductors/chokes and more
• Amplifier : new design without cooling, other Amplifier Transistors and some other parts in this section
• LED Driver redesign
• multiples on pcb
• speaker holes
• switches: you get with the pcb kit few small pcbs with - this are used like a washer for the switches, in result switch mounting is easier as in TTSH rev.1 (pics on my website)
• some minor fixes
______________________________________
Schematic v2 (7.1)
http://thehumancomparator.net/wordpress ... matics.pdf
________________________________________________
Jon /Zthees Buidling guide (26.Jan.2015 uncomplete)
http://build.thehumancomparator.net/
my own Building guide for Users with good experiences in DIY
https://www.dsl-man.de/display/DSO/TTSH ... ling+Guide
_________________________________________________________
Mainboard BOM
http://thehumancomparator.net/wordpress ... hv2BOM.pdf
dont worry if you miss 2x 100K resisitors and 1x 1M , TL071 - thats only needed when you complete the TL071 section on frontpanel pcb side
1x 10K resistor left
add 4x 4n7 c0g instead of 4x 4n7 from BOM - (wrong partnumber)
(correct nr. partnumber 810-FK28C0G1H472J )
add 2x 12k resistor instead of one
add 32x 1uF electrolyte cap instead of 31
VCO Sub pcbs BOM
http://thehumancomparator.net/wordpress ... 7v2BOM.pdf
please add: 6x 100nF SMT c0g caps in size 805
mouser part 100nF 77-VJ0805Y104JXXPBC instead of the 6x normal caps.
10nF works fine too (its only a decoupling cap)
3x Timing cap 680pF needs a polypropylene, polystyrene or silva mica (7.5mm footprint)
mouser: 80-PHE450HK3680JR05
notice: the usage of 1k87 3300ppm instead of 3500ppm works fine too.
you can try the usage instead of SMT inductors/chokes this:
http://www.reichelt.de/index.html?ACTIO ... HBCC%20100
(add enough soldercore to the pcb pads, bent the leads and solder this to the pads)
DIFF from Version 1to version2 (first TTSH from early2014 to second from early 2015)
http://thehumancomparator.net/wordpress ... rences.pdf
rare partkit: http://www.thonk.co.uk/?s=ttsh&submit.x ... pe=product
full partkits, cases: http://www.synthcube.com/cart
matched pairs and some other parts from my groupbuy left, ask me.
____________________________________________________________
Studio/Roadcase Cases opt. Tolex https://www.dsl-man.de/display/DSO/TTSH+Case
synthcube.com plans to offer cases too
_____________________________________________________________
known Issues and more
1.
You dont need TTSHv1. Bugfixes in rev.2 to get a working TTSH
all known Issues are fixed in rev.2, except the Noise gain/distorted - for my usage its the default good https://www.dsl-man.de/display/DSO/TTSH ... ssues-3fix
2.
Measurement of DC Regulator output:
use for measurement the TP 15V to ground and TP -15V to ground (not TP1 or TP3 )
THATS very important to measure -15/+15V
otherwise you risk expensive damages or blown caps. (safe your eyes)
3.
if you plan to add the VCO Sync option, dont cut the legs from all VCO subboards too short (see VCO sync option here)
please pm me, if you want to add/correct here some Infos
4.
mount the mhe172/mj1182 with letters in position to pcb inside not to the outside. (pics later)
5. picture of matched pairs here:
Modifications (no bugfixes)
AR Envelope:
https://www.dsl-man.de/display/DSO/TTSH+Mod+AR+Envelope
VCO Sync:
https://www.dsl-man.de/display/DSO/TTSH+Mod+Sync+Option
Reverb Op-amp:
https://www.dsl-man.de/display/DSO/TTSH ... Driver+Mod
Gatebooster:
https://www.dsl-man.de/display/DSO/TTSH+Gatebooster
