Dinsync Modseq mod for audio rate
jgb
Post by jgb »
Dinsync Modseq, what a lovely module!
But... clocking it at rates > 200Hz... nope. Could not do. Unless... connect a resistor (I used a 100KOhm) from pin 15 (reset) to pin 8 (ground) on the counter chip (CD4017) and voila, no problem clocking it at least up to 1700Hz (have not tested higher frequencies).
Obvious usage is using it as suboscillator or similar. :) Sounds great!
(I have talked to phono1337/Paul Barker) regarding this mod, he could not see any problem with it)
phono1337
2SK30A-O
Post by phono1337 »
nice mod :tu:
