Moderators: Kent , luketeaford , Joe.
phono1337
2SK30A-O
Posts: 1223 Joined: Sun Nov 29, 2009 5:10 am
Post
by phono1337 » Wed Nov 05, 2014 2:39 pm
EDIT 23rd OCT:
If you are on the waiting list you should have a mail today, if you didn't get the mail please check your spam folder or drop me a message so we can see what happened. As usual whats left from this batch after the waiting list is done will go to first come first served.
Meanwhile if you want to get on the waiting list for the next batch (as usual no obligation) drop me a mail on
info@dinsync.info and I'll let you know when they are ready.
and just to jog your memory
http://www.dinsync.info/2014/11/modseq- ... -here.html
[video]
VIDEO [/video]
phono1337 on Fri Oct 23, 2015 3:01 am, edited 9 times in total.
tikami
Posts: 152 Joined: Wed May 19, 2010 1:47 am
Post
by tikami » Wed Nov 05, 2014 6:41 pm
That's certainly a comprehensive build guide you've authored there. Nice work!
I hate being bipolar. It's Awesome!
mrtweed
Posts: 370 Joined: Thu Feb 27, 2014 9:18 am
Post
by mrtweed » Wed Nov 05, 2014 8:28 pm
email sent
phono1337
2SK30A-O
Post
by phono1337 » Thu Nov 06, 2014 3:47 am
tikami wrote: That's certainly a comprehensive build guide you've authored there. Nice work!
thanks, really tried to make it as simple as possible, of course this makes it longer but better to have all the info
phono1337
2SK30A-O
Post
mrtweed wrote: email sent
stabilt
Posts: 256 Joined: Wed May 09, 2012 12:12 pm
Post
by stabilt » Thu Nov 06, 2014 9:58 am
The super manual with hi res photos and one step per page.
Great work!:tu:
banalytic
Posts: 162 Joined: Mon Sep 12, 2011 12:06 pm
Post
by banalytic » Thu Nov 06, 2014 5:56 pm
email sent 8_)
phono1337
2SK30A-O
Post
by phono1337 » Tue Nov 11, 2014 9:02 am
we are about halfway thru the pre packed kits, so there's still time
reodjectz
Posts: 665 Joined: Tue Apr 08, 2014 12:13 pm
Post
by reodjectz » Tue Nov 11, 2014 12:40 pm
Ordered.
I wonder how much muff's
graphics influences euro prices. Hmmmm.
phono1337
2SK30A-O
Post
by phono1337 » Mon Nov 17, 2014 6:25 pm
just had a quick look and there are only 20 kits left
ilya.n
Posts: 142 Joined: Wed Oct 01, 2014 7:57 pm
Post
by ilya.n » Tue Nov 18, 2014 3:49 am
Emailed... Would look good next to my Sara.
phono1337
2SK30A-O
Post
by phono1337 » Mon Nov 24, 2014 4:43 am
If anyone stll wants one we still have a small amount left and will be putting a few more kits together this week.
jgb
Posts: 414 Joined: Sun Nov 07, 2010 5:47 am
Post
by jgb » Tue Dec 02, 2014 3:23 am
Mod for audio rate clocking:
viewtopic.php?t=126619
Works a charm!
phono1337
2SK30A-O
Post
by phono1337 » Tue Dec 09, 2014 12:26 pm
just put together 10 more kits, this is the last of them
Abraxis
Posts: 624 Joined: Sat Feb 23, 2013 6:19 pm
Post
by Abraxis » Tue Dec 09, 2014 12:34 pm
phono1337 wrote: tikami wrote: That's certainly a comprehensive build guide you've authored there. Nice work!
You sir, are a euro hero.
mazzazza
Posts: 40 Joined: Sun Nov 16, 2014 2:43 pm
Post
by mazzazza » Tue Dec 09, 2014 12:41 pm
Built the first of my 2 modseqs a few weeks ago - loving it, keep up the good work :-)
ilya.n
Post
by ilya.n » Sat Dec 20, 2014 10:03 am
Looks like the output CV in the rightmost position of the pot is 4.5V, not 5V as specified in the manual. Is this OK or I made a mistake when building a kit?
Thanks.
phono1337
2SK30A-O
Post
by phono1337 » Sat Dec 20, 2014 10:13 am
it should be 5v or very close to it, can you double check that there are no shorts on the potentiometer pins. If you have a magnifying glass it might be good to use that to examine them closely.
Otherwise drop me a line on
info@dinsync.info and we'll figure out whats going on here
ilya.n
Post
by ilya.n » Sat Dec 20, 2014 10:30 am
well, I can't see any obvious shorts... Just checked, it's 4.5V max on all pots.
EDIT: Problem solved, had nothing to do with the module. Turned out I had lower than 12V on the positive rail which was in turn caused by a wrong setting on a power brick.
Thanks Paul for the advice and prompt response!
masru
Posts: 54 Joined: Thu Jun 04, 2015 1:40 pm
Post
by masru » Thu Jul 16, 2015 2:33 am
Any chance we see these kits again some time?
phono1337
2SK30A-O
Post
by phono1337 » Thu Sep 24, 2015 4:06 am
more modseqs incoming
jgb
Post
by jgb » Thu Sep 24, 2015 4:22 am
Incorporating the audio rate mod?
I have been playing with the thougt of having a step select output signal, ie eight trigger outputs. Could be used for setting sequence length or just triggers for something else.
phono1337
2SK30A-O
Post
by phono1337 » Thu Sep 24, 2015 4:24 am
jgb wrote: Incorporating the audio rate mod?
nothing has changed, so its still your mod
nice idea
a773
Posts: 1945 Joined: Fri Jan 30, 2015 8:21 am
Post
by a773 » Thu Sep 24, 2015 5:54 am
phono1337 wrote: more modseqs incoming
Kits? Where? Price? Amount?
phono1337
2SK30A-O
Post
by phono1337 » Thu Oct 08, 2015 8:36 am
bump for the first post edit, partial kits incoming
