There is a drum pad station prototype sitting in front to show how size is relative. The idea for the drum pads came from ClimbingTyler, big props to him for a very cool idea. It is used in conjunction with the Erthenvar Ctact 1 tile modules. 12U for eurorack modules, 2 - 1U's for tiles. 100HP.
All fabrication was done in house. Custom cnc aluminum as well as the African Bubinga hardwood ends. No cheap mdf board here!
Working on my own version of the MN bus. Mine goes vertical and there is a small cable connecting both sides. They can be run together or separately as the main jacks are normalled.
Special ventilation notches were cut into both the top and bottom for ventilation. Sometimes at gigs with all of the lights these boxes seem to heat up quick, so I had to do something about that. 2 - 4Amp power supplies are built in so no ugly wall warts. The power supplies are located right next to the vents.
20lbs dry weight. 38 - 40lbs filled with modules. Heavy, but still portable. One inch solid aluminum rod for the handle gives confidence when carrying this around.
Large heavy duty cowhide leather bag has room for ALL cables. You would not need to carry a separate bag for cables. This was another must have.
I gave up some case room for this, but it is well worth it.
Any ideas for more/better options are requested, so let me hear what you think.
