next up from SynthTech: E620 USB Host/Device Midi/CV Thingy
paults
mice nuts
Post by paults »
Panel too narrow to put that long name on it. I call it the USB Thingy for short.
a) Have the prototype pc boards running test code.
b) dual channels of 16bit DAC -2V to +8V range
c) dual GATE/trig outs of 10V
d) CV outs can also be set to trigger outs
e) 4HP wide, only 1.8in (4.6cm) deep
f) supports either Host or Device mode (not both at once). As Host, can supply full 500ma @+5V current per USB spec
g) FLASH storage of setup
h) Class Compliant: no drivers needed!
When available? Depends on how long the code takes. We are pretty picky about testing all the USB issues that might crop up. The MIDI code itself is 90% running and debugged.
Cost? I am striving from $249 or less retail. $229 would be nice I think.
More detail later. Yes, I will need beta testers. No, please don't PM me now, I will have a post when ready (maybe around Thanksgiving).
revoltcrews
Post by revoltcrews »
Nice !
is this CV to Midi
or
Midi to CV ?
waveglider
Post by waveglider »
Host mode with class complaint MIDI controllers will be awesome!
:sb:
paults
mice nuts
Post by paults »
USB MIDI data in. CV/Gates/Triggers out.
exper
Post by exper »
Very, very cool. Just when I was thinking of getting a qunexus. Is there mode options? Like the ability to turn the outputs into pitch cv, gate, cc and perhaps clock?
paults
mice nuts
Post by paults »
Yes, it's not trying to be as extensive as a Yarns, but it will have multiple modes. In fact, please suggest say your top 5 MUST HAVE modes here in this thread. In order to keep cost down, using a 64K MCU. The USB stack is around 19K so we still have some room to have lots of modes. Just not 117 :sadbanana:
ether
Post by ether »
I need this.
Other than maybe a wider version with 4 CV/gate outs for some polyphonic goodness I can't think of much else I'd need.
paults
mice nuts
Post by paults »
Well, this is 2 note polyphonic goodness. So buy 3 and get 6 voices in about the same width as a Yarns. And a $20 USB hub :nana:
ether
Post by ether »
USB hubs are evil and not to be trusted :twisted:
I'd rather live with a simplified duophonic setup with one cable, rather than have a rats nets of USB alongside the modular.
On another note, have you seen the USB-ified Monome euro modules?
http://monome.org/modular/
logicgate
Post by logicgate »
more infos pleeeease!! :hail:
sempervirent
Post by sempervirent »
I'd been wondering when this would surface.
Added to ModularGrid:
http://www.modulargrid.net/e/synthesis- ... ost-device
tikami
Post by tikami »
Not good news for my CVpal!
Device hosting is awesome!
I hate being bipolar. It's Awesome!
tikami
Post by tikami »
paults wrote:Well, this is 2 note polyphonic goodness. So buy 3 and get 6 voices in about the same width as a Yarns. And a $20 USB hub :nana:
Any chance of being able to daisy chain multiple units by USB? (i.e., no hub)
Stealing an idea from MI, but I love CVpal's mode where the second gate can output a square wave. If it were possible to daisy chain multiple units and output square waves at the same time then we'd have a very simple polyphonic ability.
Please shoot me if I'm being stupid. :hmm:
spacessound
Post by spacessound »
That's smart. Always a pain to power a little midi device from an ipad when there is no computer around or on.
I guess that's the prime benefit or?
paults
mice nuts
Post by paults »
a) A prime benefit (besides the fact it's a SynthTech product) is yes: it can power (up to 500ma) any MIDI USB class-compliant device. And it's small. And it's cheap. And it's a SynthTech product.
b) there is no "chaining" in the USB spec
c) this is primarily to generate CVs, but things like Silent Way software can be used to make LFOs, EGs, all that good stuff.
spacessound
got it. ta.. :tu:
The Disquiet
Post by The Disquiet »
EDIT: never mind, deleted
karmadelic
Post by karmadelic »
:yay: :yay: :yay:
mick
Post by mick »
Do I understand it correct when I think you can plug in an midi-over-usb device in the usb port, and it will generate CV?
Twitter | MickBenjamins.com
It's 2023, can we please stop making modules that are mono?
insula
Post by insula »
don't forget the clock!!! :hail: :hail:
logicgate
Post by logicgate »
mick wrote:Do I understand it correct when I think you can plug in an midi-over-usb device in the usb port, and it will generate CV?
I wonder that, too. Would like to know the difference between host and device mode.
I thought that, in order to send MIDI over USB, we needed some kind of software (similar to the ones you have install to make the MIDI keyboard controllers to work with your DAW)
alamandra
Post by alamandra »
I'd have thought this module has some sort of software inside it's computery bits to sort that out.
Anyway Paults great module as ever, a question if I may though. Are you able to run audio from an ipad for example through one of the cv outputs, potential idiot question from me there lol. I only understand the difference in cv and audio so far as go low enough in audio it becomes lfo.
Shiney metal module shirt
tikami
Post by tikami »
paults wrote: b) there is no "chaining" in the USB spec
So no concept of "MIDI thru" where USB is concerned? (I'm no expert)
You can still shoot me for being stupid, or I'll do it myself :russian:
os
Post by os »
Gah. This is the third time this month that someone's announced a product that I had on the drawing board.
Good work, sir.
paults
mice nuts
Post by paults »
Answering questions below.
Yes, this is the point of the module. :sb:
You can either (just NOT at the same time!):
a) plug into your PC/DAW/IPAD. The E620 is a Device, the PC side is the Host.
b) Plug a MIDI USB keyboard into the E620. The E620 is the Host and powers the Device.
Note: a Monome is NOT a Class Compliant device. You have to buy the White Whale modules for it.
No, that is a different USB Class (the Audio Class). And that class is pretty restrictive in terms of sample rates/bit lengths. Which is why MOST USB audio interfaces use their own custom drivers.
This is what a USB hub is for in Host mode. The PC (Host) sends 1 USB MIDI stream out it's USB port to the hub. The hub (usually 4 ports) then sends it out the 4 ports (like a mult). So there is no need for 'Thru'
This is USB terminology not a MIDI term. A Host can provide power to the Device. The Host is usually a PC/DAW. The Device is like a USB mouse, thumb drive or in our SPECIFIC case, a MIDI thing (like my M-Audio keyboard).
Either Host or Device can send and receive USB data.
It depends if the USB Host/Device is 'Class Compliant' or not. Again, an official USB term.
The USB spec has pre-defined Classes. The intent is that these devices need no additional driver. All the messages are pre-defined, you cannot add to them. The E620 is such a device, the 'drivers' are executing inside the PIC microcontroller. This means that we cannot add to the USB commands for the MIDI class.
Now, if your Host application has it's own "MIDI driver" for say sending MIDI, what does the E620 do in this case?
The messages added to the MIDI portion are ignored. However, the MIDI class is pretty much the entire MIDI spec so I doubt any functions are 'lost'. The added drivers are usually for the Audio side of things.
Official spec is here: http://www.usb.org/developers/docs/devclass_docs/
