Fast Envelope besides Cwejman
franzschuier
fart box afficinado
Post by franzschuier »
I searched a bit but couldnt find a definite answer to this.
Is there another really fast envelope besides the cwejman
adsr? - meaning lower than 0.5ms attack time?
e-grad
Post by e-grad »
Don't know the specs but the A140 is fast.
franzschuier
fart box afficinado
hmm.. i have two but there not fast enough for me :twisted:
D/A A/D
glorious dissonance
Post by D/A A/D »
M10 and Maths both do this really well...
Please call me Alex...
D/A A/D
More coming soon...
e-grad
Post by e-grad »
franzschuier wrote:hmm.. i have two but there not fast enough for me :twisted:
:despair: I had two of them and with the right setting of the range switch they were unusable for most musical applications unless you're doing clicks and cuts.
With the range switch to LOW it should go below 100µsec.
Somatic
choleric wiggler
Post by Somatic »
Module A-140 has available a three-position toggle switch to select one of three time ranges. The envelope duration ranges from about 50us (microseconds) up to several minutes.
baboo
Post by baboo »
I think that ASOL EG01 can go up to audio rate in the repeat mode so it should be pretty fast, couldn't find exact specs tho
Navs
Post by Navs »
e-grad wrote:Don't know the specs but the A140 is fast.
It is bloody fast, but speed ain't everything ;)
Seriously, how fast do you want them to be? :despair:
We had a long discussion about envelopes & speed over at sequencer.de a while ago. IMO what marks the Cwejman out is its response curves, dynamic range and stability. The A-140 sounded linear and lifeless to my ears and that is why I sold mine. But, I certainly wouldn't describe the Doepfer as sluggish.
e-grad
Post by e-grad »
Navs wrote:The A-140 sounded linear and lifeless to my ears and that is why I sold mine.
I'm sure the vast majority of ADSRs commercially available are linear.
franzschuier
fart box afficinado
hmmmh. Ok maybe the vca I use it with is the problem.
I have a cwejman Vm1 where the a is 0,5ms in fastest position and
it sounds faster to me than another osc into Doepfer VCA controlled by A140.
Yohda
Post by Yohda »
I'm not sure, but I think the majority of ADSR have Log attack and expo decay and release. :)
It may be a part of the problem, yes, you need a good VCA like the Cwejman with very fast enveloppe.
Navs
Post by Navs »
franzschuier wrote:hmmmh. Ok maybe the vca I use it with is the problem.
This could be it. Which Doepfer VCA do you have linear or exponential?
The Cwejman VCAs are semi-log (even when it says lin) or exp.
Flipping my VCA-2P to exp. has a radical effect on the sound, making it much snappier.
chinard
Post by chinard »
MATHS!!! :guinness:
I also use the Doepfer A-143-2 quad adsr when i need super fast envelopes.
here's the transient times taken from the doepfer website:
time ranges: A D/R
position
range switch: min. max. min. max.
l ~ 0,2 ms ~ 0,2 s ~ 0,5 ms ~ 0,5 s
m ~ 5 ms ~ 5 s ~ 15 ms ~ 10 s
h ~ 30 ms ~ 2 min ~ 100 ms ~ 5 min
e-grad
Post by e-grad »
Just did my homework: You're right. I'm sorry!
Mr White
always folding something...
Post by Mr White »
definitely +1 :razz:
franzschuier
fart box afficinado
Okey.. So whats a good vca that is affordable?
bar|none
Post by bar|none »
What about the MFB Dual ADSR?
I have one to unload as well if you are looking used. I have the cwejman ADSR and now the cwejman CTG-VC so covered.
VCAs
A-132-3 is a board favorite.
I like the MFB VCA especially as a first since allows for some nice mixing options.
Don't forget that the QMMG while not cheap double as a bank of VCAs so helps get bang for buck.
e-grad
Post by e-grad »
bar|none wrote:Don't forget that the QMMG while not cheap double as a bank of VCAs so helps get bang for buck.
He's got a fetish for speed thus a vactrol based VCA would be too sluggish. :cloud:
consumed
Post by consumed »
a fast vactrol module is not totally out of place in this conversation
i believe that the perception of speed/snappy is the core of this topic, not envelope specs
vactrols can feel very fast even with the ringing
Mr White
Post by Mr White »
afaik vactrols opens very quick.
the ringing have to do only on the release stage, so they ARE snappy.
franzschuier
fart box afficinado
A new Vca then - ill go for vcma 4mx then.. that will give me some room to.. thnx..
may have to sell the vm-1 to finance it though.. duh
bar|none
Post by bar|none »
that is a good choice....I just thought you were looking for a cheap one. ;)
Jari Jokinen
Sensible Wiggler
Post by Jari Jokinen »
Navs wrote:The Cwejman VCAs are semi-log (even when it says lin) or exp.
My VCA-2P "lin" is linear. DC to signal input, LFO saw to CV input => no curve.
Navs
Post by Navs »
I just checked my VCA-2P again - you are right Jari.
Thanks for correcting me and sorry for spreading untruths :oops:
I was unsure about this because in my tests with Silent Way's CV Recover plug-in I could not get accurate results with the VCA-2P in linear mode, whereas using the VCO-2RM's DC-coupled ring mod worked perfectly.
Any ideas why?
Reptil
In space no one can hear you wiggle
Post by Reptil »
FYI here's the doepfer page with (easy) mods for faster envelopes. (or slower)
I kept one a-140 just for modding and testing. there's nothing wrong with it AFAIK. The doepfer VCA a-130 and a-131 are not so good, but I'm positive that exchanging the TL062 for some better IC will result in a marked improvement. Very simple circuits, even for a dumbass like me.
An INS-2mx is on the way here, and a MOTM 190 VCA. That'll take care of the "snappy VCA" bit. :party:
