[IN STOCK] L-1 Basic VCO. Eurorack. [Mouser cart p.4]
L-1
Post by L-1 »
http://l-1.su/BasicVCO.html
Finally I had time to work on the VCO. I finished the second prototype and prepared docs for ordering a final prototype.
This is basic VCO because has only basic functions.
Triangle core with sync possibility based on the THAT2180 and OPA2604 chips. Regular TL07* opamp doesn't work here because of high wave amplitude. Limiting wave with diodes as were suggested gives problem with sync. So, only OPA2604 in the core.
VCO range is from 8 Hz to 14 kHz. VCO/LFO switch between timing capacitors. I used 100p and 10n 1% polystyrenes. So LFO range is 100 times slower than VCO.
No expo converter here because THAT2180 has expo responce. CV circuit is tempereture compensated with two 2K tempco resistors.
I used BCM847BC matched pair for sinewave circuit.
I used LM4040 precise voltage source for offset voltages to minimize pitch flow. I tested during 4 hours - pitch was stable in range +- one cent.
I installed Schmitt trigger on the sync input. So any wave is good for sync.
I was able to achieve cent-by-cent tracking as on the first prototype.
The VCO - left board the core, right board - saw, sine, PWM circuits:
djpasica
Post by djpasica »
why :despair:
i think there is a lot of basic modules (osc)
IMHO
if it will not cost :75:
andrewF
Post by andrewF »
djpasica wrote:why :despair:
The joy & satisfaction of DIYing his own VCO and seeing it work :love:
L-1
Post by L-1 »
IMHO
What for example? For DIY Euro, not digital, without timers or logic. Classic analog design.
1. 258J from Thonk.
2... :hmm:
Randy
Post by Randy »
I could see this being handy for smaller systems or adding polyphony. Make it 4hp and I'll buy it!
Randy
andrewF
Post by andrewF »
IMHO
1. 258J from Thonk.
2... :hmm:
2... this one? :razz:
CJ Miller
Post by CJ Miller »
This seems to be an interesting design! I hope I can buy a few boards eventually.
L-1
Post by L-1 »
Yes andrewF.
The second reason why I make this - it's local musicians. They require from me a complete system.
andrewF
Post by andrewF »
L-1 wrote:Yes andrewF.
Pretty lucky DIYers in your town 8_) .
the locals here in P-town have to endure my half-assed insanity :spin:
livefreela
Post by livefreela »
i would frame that proto photograph for my wall EDIT now it's my computer desktop. awesome. l-1, way to be man, way to be!
Reality Checkpoint
Confused By Electricity
Post by Reality Checkpoint »
Well I very much like it and applaud the classic analog design.
And I will no doubt end up with one or two in my system.
bkbirge
Post by bkbirge »
Don't sell yourself short man, there's nothing half-assed about your insanity.
:bacon:
Modular & Dork Rock:
https://bkbirge.bandcamp.com/
Racks:
https://www.modulargrid.net/e/racks/view/88730
https://www.modulargrid.net/e/racks/view/89177
https://www.modulargrid.net/e/racks/view/379579
"The person who says it cannot be done should not interrupt the person doing it." ~ Puck, 1903
cane creek
Post by cane creek »
I'm in for one of these :tu:
horstronic
Post by horstronic »
Very nice!
makers
Post by makers »
I would also like to build two of these!
Barcode
Post by Barcode »
Single PCB? No wiring? Awesome in my book!
stereonoss
Post by stereonoss »
+1
I have Quad VCA/Mixer and Tube VCA from you ) it sounds perfectly and i will buy system complete from L-1 Corporation )))
stereonoss
+1
euromorcego
Post by euromorcego »
As do we! :hihi:
Stides
Post by Stides »
Looks nice to me. Reasonable size to feature ratio, and seems to have a minimal component count. Always comes to price and availability, but your stuff always is reasonable.
synthcube
you will be assimilated
Post by synthcube »
Can't wait for this one!,
Facebook: www.facebook.com/2SynthCube
Small Bear Webstore: www.smallbear-electronics.mybigcommerce.com/
synthCube Webstore www.synthcube.com/cart
Music From Outer Space: www.musicfromouterspace.com
Blacet Research: www.blacet.com
sonicwarrior
Post by sonicwarrior »
Would have been nice to an attenuator for the PWM input. I always need an attenuator plus offset there.
FM is linear I hope?
Only 3 trimmers look like fun to calibrate. I'm always intimidated by the many trimmers on most VCO PCBs. :oops:
Edit: Does it run with +/- 15 V? Would be fun to squeeze this into a single width MU panel although it would mean panel wiring.
Soundcloud
L-1
Post by L-1 »
sonicwarrior wrote:Would have been nice to an attenuator for the PWM input. I always need an attenuator plus offset there.
No place for PWM attenuator sorry.
No linear FM, only exp. 2180 chip has exp response, and needs another matched transistors pair for linear.
About 15V. It can I think but some resistors changes will need. There is 10V source for offset voltages.
I plan to make more advanced dual osc later. I will include there lin FM and many other possibilities.
L-1
Post by L-1 »
synthcube wrote:Can't wait for this one!,
I already prdered boards for a prototype!
L-1
Post by L-1 »
Only 3 trimmers look like fun to calibrate. I'm always intimidated by the many trimmers on most VCO PCBs. oops
Really I added fourth. Will be:
- v/oct
- offset
- saw symmetry
- sine symmetry
