DISCONTINUED! This version is discontinued, there is a new SMD version in the works, in testing now.
Not sure why muffwiggler inverted this, but here is a pic comparing the 2.
Changes:
Still fits the same panel!
Thonkiconn jacks.
SMD (easy build, just 805 and SOIC)
Seperate op amps for output, pwm sub out, and v/oct input.
No more protection diodes, used 3v MCP600x Opamps instead.
Transistor gate/reset input
Power and heat saving option to use a switching 7805 replacement, with anti noise CLC Pi filter.
“Both ways” psi power.
component values marked, i built it without a BOM!
Got rid of 3v and -3v op amp contraption, aref is powered by ADP 150.
3v does not come up until teensy has booted and pin 13 LED comes on.
When its time ill make a new thread for smd build.
https://github.com/jakplugg/neutron-sound
finally a manual (new improved manual by gliched01 nov 28 '15)
http://www.neutron-sound.com/PDFs/Orgon ... 0Guide.pdf
The boards and panels for my MK20 (teensy 3.1/3.2) based oscillator are:
The purchasing buttons are at the bottom of http://neutron-sound.com/noa.html
(DIY boards and panels temporarily out of stock.)
Now available with options for jacks, knobs, pots, teensy etc from Thonk:
http://www.thonk.co.uk/shop/orgone-accumulator/
Also kits at synthcube:
http://synthcube.com/cart/index.php?rou ... uct_id=597
Fully built module at synthcube:
http://synthcube.com/cart/index.php?rou ... uct_id=596
here is the mouser cart: note, this does not include pots and knobs, please see BOM on site.
http://www.mouser.com/ProjectManager/Pr ... a505f701a8
Here is build guide:
http://neutron-sound.com/PDFs/NOA_build_manual.pdf
anyone who jumped the gun and ordered from my beta BOM, Sorry but i have changed a couple of things since you last looked. the vref driver IC is cheaper TLE2062 and the diodes were changed to BAT42. those diodes i had on the BOM were completely wrong, (the legs wont even fit the holes)
Shipping is usually on Tuesdays.
[soundcloud url="https://api.soundcloud.com/playlists/21554458" params="color=ff5500&auto_play=false&hide_related=false&show_comments=true&show_user=true&show_reposts=false" width="100%" height="450" iframe="true" /]
