I know there's a massive thread on the Frames - mainly concerning its availability (LOL), but I thought I'd start this one for patch ideas.
I only just got the Frames in the rack yesterday and already pretty blown away with it. Here's what I've come up with so far (apart from the really obvious) - No sounds or videos as yet - I have been too busy playing and wiggling….
Sorry this is quite long…..
1/ Use the metropolis pitch output to drive the Frames - going into the FRAME input. This means that you get discreet (no glide) movement of the output Frames CV's. Read on if you thinking "why he do dat?".
Well… if you take the Frames CV 1 output into your oscillator 1v/oct …. you do the following on the Frames: Turn fully left, add a keyframe at minimum voltage. Turn fully right, add a keyframe at maximum voltage. Now hit play on your sequencer. Fully left on the Frames knob and you have your sequence. At this point you can tune your oscillator to taste!
Turn the Frame knob and it all goes up in pitch. Go to 12 o'clock with that knob. So far so simple. Adjust the modulation knob from fully clock wise to fully anti-clockwise
OK, not quite done with this yet. Now patch output 2 to your Metropolis Aux Inputs (for example). Set up your keyframes for output 2. Now you can have your root note **or whatever** change depending on the position of the sequence
Still not quite done… patch output 3 to your pulse wave modulation, set up and now your pulse width depends on what note is output by the sequencer.
One left… set output 4 to your VCF cut of with loads of resonance ( I used the dual Borg)
This is crazy… now wiggle the big knob and adjust the Frames modulation amount and polarity. Joy
Let's have your ideas
