Braids, DPO work nicely with an ES-3 and SW Voice Controller
Moderators: Kent, os
mkndr
Post by mkndr » Wed Apr 16, 2014 12:50 am
In case anyone is just perusing this forum (or searching for this), I bought an ES-3 two weeks ago, and fairly easily got both a braids and a dpo to work fine with it. These aren't listed as modules that have been tested but they work perfectly fine for me.
This is relevant because the SW software requires you to calibrate your osc so you don't have to tune it yourself, which is frankly incredibly handy.
With the DPO, the secret is to not calibrate on the final channel. It seems to be confusing. Just tune on the sine or square of osc b.
For the Braids, you can easily calibrate on the CSAW setting.
Hope this helps anyone else out there who is on the fence about the ES-3 & Braids/DPO. It really is a game-changing module and is well worth it.
os
Post by os » Wed Apr 16, 2014 3:23 am
Thanks, I'll update the compatibility list.
Return to “Expert Sleepers”
