Animal Factory Amplification
Lexicon MPX 500 has DC-coupled analog outputs
Moderators: Kent, os, Kent, os
sine
Post by sine »
My MOTU 2408 (original model) does not have DC-coupled analog outs. It does, however, have S/PDIF out which I connected to my Lexicon MPX 500 S/PDIF in. To my astonishment, the Lexicon analog outs not only pass calibration, I'm getting 7 octaves of pitch CV!
sine
Post by sine »
I pulled my Akai DR4 out of storage and tested it too. It has AES, S/PDIF, and analog I/O. I connected the MOTU 1224 AES out to DR4 AES in. The DR4 analog fails. It got me wondering though what other gadgets like the MPX 500 are out there with digital in and DC-coupled analog output. Since most all DAW interfaces have some type of digital output it'd be useful to know what inexpensive gear might partner with them. I think I read somewhere that the Behringer ADA8000 does not work.
os
Post by os »
Great information, thanks!
I think you're right about the ADA8000.
tutenchamun
1-Post Wiggler
Lexicon MX400 DC-coupled how-to
Post by tutenchamun »
this forum has info about using MPX500 DC-coupled as Cv source.
I want to try this with my MX400 (Lexicon clearly states that MX400 has an dc-coupled output as well) maybe together with ExperSleepers plugin
but I simply fail to understand the signal chain comcept.
Any idea or explanation would help
on how I would need to hook it all togather
(expert sleper, usb to Mx400 ? or analog into MX400, and then how would I hook up which output of the MX into my analog gear ? and which comfig would I need to make , or would this all then just magically work ?)
thx. for feedback
epiphanius
Post by epiphanius »
Any chance at all that the MX200 also has dc-coupled outputs? I have looked briefly at the service manuals for both MX200 and MX400, and the stated specs look similar for the analog outs.
andybizarre
Re: Lexicon MX400 DC-coupled how-to
Post by andybizarre »
tutenchamun wrote:this forum has info about using MPX500 DC-coupled as Cv source.
thx. for feedback
I will try to describe the signal chain, from computer to modular. This is what you need: :popcorn:
1. Software putting out CV as audio channels. Examples, which will do that directly are Reaktor, Max, VCV Rack and the likes. For a start, I would recommend VCV for its immediacy. Ignacios CV Toolkit or OSs Silentway work great too, of course.
2. Route audio channels carrying your CV to audio interface. Set all levels to maximum.
3. Find the balanced analogue outputs on your Lexicon. DC-coupling will not work with unbalanced cable lines! If the 6.3mm jack is balanced, you can use a regular insert cable (1xTRS to 2xTS). If only XLR out is balanced, you`ll need to find the respective cable, or solder. One TS jack will carry positive voltage from 0 to 5 or 7 Volts, the other jack will carry an inverted copy (-5V to 0V).
4. Enjoy. The magic should happen now. :zen: Feel free to ask again if something isn`t working as expected.
Return to “Expert Sleepers”
