realistic TR-909 Font for free!
AssistiveListening
Post by AssistiveListening » Sun Feb 16, 2014 3:54 pm
So.. I vectorised the TR-909 Logo for a friend's DIY... decided to do the "rhythm composer".. and finally added some more character and made a font.
All the missing characters are interpreted. (Thanks to some help from you guys I was able to find most of the letters.)
The fonts are available for desktop & web (ttf, otf, svg, eot, woff)
Download it from dafont.com or use the attachment in this post (includes web-fonts)
PREVIEW:
PBIO-bold.zip
(53.3 KiB) Downloaded 236 times
Last edited by AssistiveListening on Fri Feb 28, 2014 9:17 am, edited 8 times in total.
Roland TR-909 Font: find it here
Plop
Post by Plop » Sun Feb 16, 2014 4:07 pm
Neat! I have the other one but this one looks indeed better. Downloading now, thanks :sb:
Here is a screenshot with the other one for comparison, yours is definitely better:
Paradigm X
Post by Paradigm X » Mon Feb 17, 2014 6:35 am
very cool sir!
many thank for sharing your hard work!
horstronic
Post by horstronic » Mon Feb 17, 2014 3:41 pm
That's awesome!
nicolas
Post by nicolas » Mon Feb 17, 2014 4:02 pm
Cool, thanks for sharing!!
scriptstyle
Post by scriptstyle » Mon Feb 17, 2014 4:06 pm
:sb:
emdot_ambient
Post by emdot_ambient » Mon Feb 17, 2014 9:20 pm
Anyone know what font is used on this: http://1.bp.blogspot.com/_yNA62hgcWDg/T ... /Zeta1.jpg
I've been toying with doing a single oscillator mono synth called Zeta One. Really would like to use that font.
Plop
Post by Plop » Mon Feb 17, 2014 9:53 pm
emdot_ambient wrote::tu:
I have to identify fonts quite a lot so I gave it a go and found it :goo:
Amelia typeface
emdot_ambient
Post by emdot_ambient » Mon Feb 17, 2014 10:02 pm
Plop wrote:I have to identify fonts quite a lot so I gave it a go and found it :goo:
Amelia typeface
Sweet! Thanks!
dougt
Post by dougt » Mon Feb 17, 2014 11:25 pm
Plop wrote:Neat! I have the other one but this one looks indeed better. Downloading now, thanks :sb:
The other one (on the bottom) is closer to the original font Roland used if anyone cares... .
AssistiveListening
Post by AssistiveListening » Wed Feb 19, 2014 1:50 pm
@dougt if you think the bottom one is closer, what are your reasons?
The "Y" and the "S" are completely different than the orignal, so you can't even write "rythm composer" in the correct "optic".
I actually traced the original letters so you could create an almost perfect copy of the logo with my set.
anyways, I'm always open to criticism.
BTW. I'm already working on a second version. maybe if you give some feedback, I can change some stuff.
emdot_ambient
Post by emdot_ambient » Wed Feb 19, 2014 2:27 pm
AssistiveListening wrote:...you can't even write "rythm composer" in the correct "optic"...
Wasn't this font only used on the "TR-909" and "Rythm Composer" text on the original?
If so, all the other letters are up for interpretation. The biggest difference between the two are the handling of the letter "A". Big difference there, but neither one of them are more or less correct unless there's a place where Roland actually used that letter.
consumed
Post by consumed » Wed Feb 19, 2014 7:42 pm
thanks for the fonts!
for reference:
gwaidan
Post by gwaidan » Wed Feb 19, 2014 8:18 pm
Hey awesome work!
Just wanted to say, there are other devices from about the same period using the same font that could fill in gaps-the one that sprang to mind was the SBX-80 Sync Box.....possibly the GR-700 and GR-77B as well, but the MSQ700 seems to use an earlier revision of the font.
Lotsa good pics here http://www.rvgm.site90.net/
emdot_ambient
Post by emdot_ambient » Wed Feb 19, 2014 9:42 pm
gwaidan wrote:Just wanted to say, there are other devices from about the same period using the same font that could fill in gaps-the one that sprang to mind was the SBX-80 Sync Box.....possibly the GR-700 and GR-77B
Good call! And the "A" is closer to the bottom one.
AssistiveListening
Post by AssistiveListening » Thu Feb 20, 2014 5:19 am
Thx @gwaidan. That helps a lot. I will try to find all the letters (already found a lot more thx to the link)
Paradigm X
Post by Paradigm X » Thu Feb 20, 2014 6:47 am
gives you a 7!
oh and a 2;
This article has links to all the products roland released all years, a goldmineof googlopportunityâ„¢.
http://www.soundonsound.com/sos/dec04/a ... roland.htm
AssistiveListening
Post by AssistiveListening » Thu Feb 20, 2014 6:09 pm
So there seem to be different fonts used. A slimmer font (very similar to the "other"-roland font) and a bold one (the one I copied) and a normal weight font (also similar to mine).
Yet none of them seem consistent
I found quite a few manuals that use the slimmer font and I gotta say "the other font" is a pretty good copy.
I wonder why the fonts are so different ("Y" and "S" are nothing alike in the thin and bold font)
In general I have found 4 different "A"s. Two in the slim and two in the bold version.
Screen Shot 2014-02-21 at 00.03.08.png (36.54 KiB) Viewed 1083 times
Screen Shot 2014-02-21 at 00.05.06.png (37.73 KiB) Viewed 1082 times
Screen Shot 2014-02-21 at 00.05.57.png (28.51 KiB) Viewed 1086 times
Screen Shot 2014-02-21 at 00.06.46.png (23.15 KiB) Viewed 1087 times
gwaidan
Post by gwaidan » Thu Feb 20, 2014 7:41 pm
I would say, given the pre-desktop publishing era, that some of these could have been hand-drawn by graphic designers to order, hence slight irregularities. It's also possible that the typeface could have gradually evolved-the lighter weight typeface looks more late 80s/D-50 era to me.
Just had a another thought-if you want to stick closely to the typeface circa 1983/4 a good source would be the early MKS rack modules and their programmers....
AssistiveListening
Post by AssistiveListening » Thu Feb 20, 2014 8:45 pm
So I found all letters except for the
"W"
"V"
"K"
Since I only found the "Q" together with the 1983/4's "A" (the rounded one) I will probably use that one.
I already did a 2nd version of the font (only missing x,y,z) but I guess I'll have to redo some of them.
I filtered them after a comparison. The ones in the image are the ones that I guess are really legit. So down to 13 again ;). This time with a few good sources. :tu:
grentel
Post by grentel » Thu Feb 20, 2014 9:11 pm
Glad you found some different A's.
Paradigm X
Post by Paradigm X » Fri Feb 21, 2014 4:27 am
Whats the Actualy 'Roland' Font, and also the 'R' logo,
I was thinking of making a clone with 'Fauxland' on the back :zen:
great thread ta
AssistiveListening
Post by AssistiveListening » Fri Feb 21, 2014 8:58 am
V2 is almost done
Still missing following letters: K V W
Still missing following numbers: 4 5 6
So if anybody finds those letters/numbers it would be awesome if you could post an image or a link.
Preview
(Numbers not redone yet)
Last edited by AssistiveListening on Fri Feb 21, 2014 10:55 am, edited 1 time in total.
emdot_ambient
Post by emdot_ambient » Fri Feb 21, 2014 9:45 am
Wow, that's looking really good :tu:
AssistiveListening
Post by AssistiveListening » Fri Feb 21, 2014 11:26 am
new numbers
So only missing: 4 5 6 K V W
