Time for some Homebrew Vactrols !!
Would you be interested in making your own Vactrols from Generic parts ?
Yes , i want to make some Vactrols !
124
97%
No , i'd rather pay for them from an established producer.
4
3%
Total votes: 128
cleaninglady
Post by cleaninglady »
First of all , i want to pay for respect to samuraipizzacat29 and valis for all their time and effort on the whole subject of Vactrols in the past week or so.
It is these kind of selfless , often time consuming gestures from fellow Wigglers that makes this place such a joy to be involved with and makes me want to give something back. :hail: :hail: :hail:
With all of the rising prices and supply problems , i think it is high time for some Homebrew Vactrols !
I'd be really interested to know if anyone has any experience in making them.
It would be great to have some Homebrew Vactrol experiment results available similar to those found on the datasheets for Excelitas Vactrols.
If we could get some LED / LDR combination close to that of the VTL5C3 , it would save alot of people alot of time , money and pains in the arse.
Is someone here in contact with any of the elder pioneers of synth module production ?
Perhaps some of those guys and gals could shed some light on this magical component that seems to be shrouded in mystery and black shrinkwrap ?
Has anyone ever cut a VTL5C3 open ? It would be great to see what the combination of components was inside and exactly how the light sheilding was most effectively achieved.
All i can do at present is ask questions but hopefully , if the combined knowledge of the Forum is posted here ; we may end up with something.
This is obviously not the first thread on this subject.
Great links have been posted by dmitri , decaying.sine , bleeps , Luka , fluxmonkey and many others here :
I'll put links posted in this thread and whatever i can find from other threads right here :
Building Vactrols
Measurements and build pics.
Grant Richter's Hairball using Modelling Clay
Great Japanese page with indepth test results on many parameters.
A picture of exposed Vactrols on a Buchla 261e board.
Look close at the Red LED's laying on their side facing some LDR's , that's them.
valis
aliens killed bigfoot
Re: Time for some Homebrew Vactrols !!
Post by valis »
cleaninglady wrote:First of all , i want to pay for respect to samuraipizzacat29 and valis for all their time and effort on the whole subject of Vactrols in the past week or so.
Thank you for saying that. If I can give back a little to this community that has given so much to me than I'm happy.
Anyway, here's Scott Stites tutorial on optoisolator rolling
http://web.archive.org/web/200904142352 ... a52a376625
And don't forget about this thread
viewtopic.php?p=756093&sid=e3d6a61e48b4 ... 1fc8b964eb
Orbless
Post by Orbless »
holy shit that site is impossible to read anything on!
valis
Post by valis »
lol. You kind of have to highlight it. There's some good info if you do.
cleaninglady
Cheers valis !
Maybe i should contact Scott Stites and see what he has to say.
Keep 'em comin' people , this could be a really great thread...
Orbless
Post by Orbless »
even highlighted I was struggling. Maybe the combo of the background color, almost matching text color and small size. It was gibing me a headache.
I think I will copy and paste the text into something else so my eyes don't explode
cleaninglady
Orbless wrote:even highlighted I was struggling. Maybe the combo of the background color, almost matching text color and small size. It was gibing me a headache.
If you click on the first and larger header that says 'Rolling Your Own Optoisolator' it takes you to a page with easier to read text.
I agree that first page is brain-splittingly difficult to make out. :zombie:
andrewF
Post by andrewF »
one good page on diy vactrol is by Motohiko Takeda
http://www.aleph.co.jp/~takeda/radio/phaser/indexE.html
cleaninglady
Cheers Andrew , copied and pasted up top. :sb:
ersatzplanet
Synthwerks Design
Post by ersatzplanet »
I am interested more in the 5-legged variety of Vactrol that act just like a pot (all three legs). The data sheet for the VTL5C4/2 mentioned in the eye-exploding website article is one of these type. The Build your own version shown uses two LDRs sharing one leg and being lit from one LED. I can't see hoe this would work unless one LDR has resistance high with light and the other has resistance low with light. Am I missing some face-palm moment here? with the same type LDR wouldn't light just affect both LDRs the same way lowering the resistance to both "outer" legs?
-James
DGTom
Post by DGTom »
I don't think the dual vactrols act like pots tho do they? If they did then you wouldn't be able to use either / or in designs like the Buchla LPG.
For example, if you compare the Easel LPG to the 292 they are quite similar but the former uses 2 single vactrols & the latter uses a dual & I'm pretty sure the Fonik / TW variants spec either.
I've built one of Foniks boards using 2 LDRs & an LED. . . no cover, leaks like a machine gunned colander but it works & if you put it in a case with lots of blinken (sequencer) modules you don't even need to plug a CV into it :omg:
toppobrillo
Post by toppobrillo »
yes, it's just 2 LDRs connected in series, with the "center tap" available as the middle lead
ersatzplanet
Synthwerks Design
Well this diagram from the data sheet is very misleading. It shows a circuit exactly like a pot with a wiper and two outside taps - not to resistors in series with a center tap. I have one of these in a box somewhere and I will have to test it out.
-James
toppobrillo
yeah, that is indeed a misleading diagram.
bleeps
Post by bleeps »
With any luck they'll have a dual...
toppobrillo
^like!
clarke68
Making DIY modulars look cool since 2011
Post by clarke68 »
Arrite...here's my first homebrew vactrol:
I had to fill a Tayda order up to the $5 minimum, so I got some of their LDRs and ultra-bright LEDs and wrapped 'em in a little shrink-wrap tubing.
What do I do now?
DIY Euro synth panels: Synthcube
clarkerobinson.com - music, video, synth panels, and more!
Isaiah
Post by Isaiah »
Last week I ordered LEDs, two types of LDRs and some black epoxy from Farnell.
I will report back when I've experimented...
snufkin
Post by snufkin »
if we can come up with a sandard led ldr combo with quick reaction/decay time that could effectivly solve our problem you may have to build a few at a time
really it's the speed thats the issue here
WTB: any Digisound80 / Digisound 80 faceplates/pcbs/kits.
Jarno
Post by Jarno »
I don't think light leakage is that big an issue, bit of heatshrink and you're done, specially for something that's residing somewhere in an enclosure. IIRC, in my Joe Meek MQ3, the LDR just sits on the board, with a led looking at it, no shielding whatsoever.
The big thing is response, all those LDR's you can buy have such a wide variation on several parameters, that you'd have to buy an aweful lot of them and do binning yourself. IMHO, that's what you pay for if you buy a readymade one, you don't pay for the LED, the LDR or the nice light shielding but the fact the supplier makes 10million LDR's, and takes the time to do elaborate binning (resistance on and off, speed on and off) of each LDR. Possibly, all the loose piece LDR's you can buy for little money are simply ones that don't fit in a solid category, and are hopeless to match yourself (although that's just guesswork). You never seem to find any specs for them, the nice ones you can get at Rapid are an exception, but at 1GBP each, not exactly cheap.
Paradigm X
Post by Paradigm X »
Out of interest if youre using firefox, go to view, then page style and choose no page style and itll be standard formatting. :bacon:
cleaninglady
It will be great to hear any results from either Clarke68 or Isaiah ; scientific or otherwise , it's all progress towards some sort of idea of what fits our purposes.
I will get some LDR's in my next run of ordering but it might be a few weeks before i can do any putting together of Homebrew Vactrols.
I was thinking that i might try to contact Motohiko Takeda (...thanks andrewF ) and see if he can shed any light on LDR values to achieve VTL5C3 specs.
I think collectively as a starting point , this is what we are after ; am i right ?
Paradigm X
Im liking this thread tho. Even moar DIY than DIY!
cleaninglady
:cloud: Just trying to give a little back to these excellent dudes.
mckenic
Post by mckenic »
This stuff might be useful...
http://www.plastidip.com/home_solutions/Plasti_Dip
Got some when I was reading the Collins DIY book - to my shame, Ive not opened it yet!
