The most valuable 4hp money can buy! soundmachines LS1
Support and discussion for soundmachines products.
Moderators: Kent, soundmachines
soundmachines
Post by soundmachines »
Paranormal Patroler wrote:
boramx wrote:i went berzerk and ordered 5 of these.
one for each digit on the right limb, the station at the rightmost part of the skiff.
Ok, so technically if you mult these and output them on an ADDAC VCFilterbank you get that fancy EQ module from Buchla. You know, the one that records EQ fader movements. :lol:
ya ya!!!!!!! still at a fraction of the price :)
soundmachines
we play synthesizers !
www.sound-machines.it
stainers
mopoetrytion
Post by stainers »
please excuse me if it's been stated but does the LS1 retain its memory after a power cycle?
auxren
Post by auxren »
Considering replacing my LP1 with multiple LS1s. Or just replacing it completely. It just doesn't get much use.
brandonlogic
Post by brandonlogic »
i just put two lightstrips in my case and i'm having a weird issue with my pitts waveforms. when i patch an output of the pitts, say the triangle, directly out of my rack to listen to, with no other patch cables in my system it sounds fine if the lightstrips are off/in their lowest cv position, but as soon as i start bringing the level up on the lightstrips i get a bad interference in my pitts waveforms, and it gets worse the higher (the more led lit) the lightstrips are. it sounds like the triangle, or sine gets more and more dirty/crackly the more i push the lightstirps. i'm using a 104 pitts move case and i'm not even using half of the power the case is rated at. if anyone has any ideas, i would much appreciate it.
erstlaub
Post by erstlaub »
stainers wrote:please excuse me if it's been stated but does the LS1 retain its memory after a power cycle?
No, it always turns on in standard mode with an empty buffer on mine anyway. It's not dreadful though, it'll take you no time atall to have it doing whatever you wanted it to.
I've got a little query about the gate out, when I put a meter on it today, I noticed I was getting about 4.9v.
I can't seem to get it work as the trigger for sample and holding with either Disting and Doepfer A148 as this would be an awesome way of 'playing' oscs.
I don't suppose there is any way of sneakily pushing another 0.10 v out of the gate is there (magic trimmer/bypassing a resistor or somesuch)?
EDIT: OK, even weirder, the gate is strong enough to trigger and hold onto samples from other voltage sources but not the CV out from the LS1.
Can someone with a sample and hold test this out and see if it works for you, I can't fathom this one out at all.
I guess it could be that there's a delay between the voltage happening and the gate sending out its signal although I can't get it to change the voltage through the sample and hold atall so possibly not?
mikeh
Post by mikeh »
brandonlogic wrote:i just put two lightstrips in my case and i'm having a weird issue with my pitts waveforms. when i patch an output of the pitts, say the triangle, directly out of my rack to listen to, with no other patch cables in my system it sounds fine if the lightstrips are off/in their lowest cv position, but as soon as i start bringing the level up on the lightstrips i get a bad interference in my pitts waveforms, and it gets worse the higher (the more led lit) the lightstrips are. it sounds like the triangle, or sine gets more and more dirty/crackly the more i push the lightstirps. i'm using a 104 pitts move case and i'm not even using half of the power the case is rated at. if anyone has any ideas, i would much appreciate it.
This sounds like not enough power issue for me.
Manual says it draws up to about 100mA on 12V rail when all LEDs are lit.
http://www.sound-machines.it/wp-content ... ep2013.pdf
robotopsy
Post by robotopsy »
LS1Lightstrip Tutorial
Wanted to have some fun with this tutorial and give some useful infos.
robotopsy
Post by robotopsy »
morphic
Post by morphic »
@robotopsy awesome video
My Mind is a Tangled Knot I Can No Longer Untie
masterofstuff124
Post by masterofstuff124 »
no more on the website?
http://www.sound-machines.it/product/ls1lightstrip/
maybe switching to diy?
curious how they work. is it accurate enough to use for VCO slide synth style play.
soundmachines
masterofstuff124 wrote:no more on the website?
In production right now! Should receive the batch in few weeks.
It seems that everyone wants some of those... :)
Have a look at some of our resellers, they may have some in stock!
David
e
soundmachines
Huhhmmmok
1-Post Wiggler
Re: The most valuable 4hp money can buy! soundmachines LS1
Post by Huhhmmmok »
Are these still in production? I'm trying to find one. Thanks!
sir stony
Post by sir stony »
I would think so, I got a pair of them this summer...
Kattefjaes
Post by Kattefjaes »
It's hard to be sure- their own support forums seem to be a graveyard where spam goes to die now- lights are on, but no-one's home... Davide Mancini hasn't posted there since last November.
lordymosh
Post by lordymosh »
Huhhmmmok wrote: Fri Aug 21, 2020 3:56 pm Are these still in production? I'm trying to find one. Thanks!
I purchased one a few days ago through their website. Doesn't seem to be available at any retailers.
sir stony
Post by sir stony »
How can there be 20 pcs of single LS1 in stock, but the triple LS1 bundles "out of stock"? :foul:
erstlaub
Post by erstlaub »
They're too busy shilling their electronic recorders as http://www.artinoise.com/ to give a shit about their fickle eurorack customers who expect things like finished 'products'.
Caveat: LS1 is actually alright but as one of the many people who handed over a large lump of money for the garbage half baked Arches only to be fully abandoned I'll always take the opportunity to state how dogdirt this company is.
thebrotherspus
Post by thebrotherspus »
erstlaub wrote: Fri Mar 05, 2021 8:07 am They're too busy shilling their electronic recorders as http://www.artinoise.com/ to give a shit about their fickle eurorack customers who expect things like finished 'products'.
Yep. Disappointed Arches owner here too. It's a piece of trash.
scottmoon
Post by scottmoon »
thebrotherspus wrote: Fri Mar 05, 2021 8:16 am Yep. Disappointed Arches owner here too. It's a piece of trash.
Sad :waah: It could have been great. Glad I never pulled the trigger.
"If you think this world is bad, you should see some of the others" - PKD
My band's noise https://soundcloud.com/lunarasylum
thebrotherspus
scottmoon wrote: Mon Apr 12, 2021 7:27 pm
Yes, it's too bad. Especially since it seems like it wouldn't really take much for it to be great. The hardware seems more or less fine. It's just an extremely buggy firmware. If the bugs were fixed, it would be fantastic.
1n
Post by 1n »
I'm getting a lot of use out the LS1 that arrived today. I got it to play STS and Morphagene, and it's doing fine. I'll test it a few more days and will probably get another.
Probably not a lot of point waiting around for T-Quadstrip https://www.modulargrid.net/e/soundmachines-t-quadstrip
Mr. Aloud
Post by Mr. Aloud »
There are many posts that are a few years old by now... Are you guys still having fun using the strips or did you move on?
It would seem that still, after all these years, perception is essentially thought to be a passive process.
robotopsy
Post by robotopsy »
I'm still using my LS1. I have 6 but only 3 are in the case right now.
Mr. Aloud wrote: Thu Sep 30, 2021 9:51 am There are many posts that are a few years old by now... Are you guys still having fun using the strips or did you move on?
Mr. Aloud
Post by Mr. Aloud »
Thanks, I´ll give it a try then.
Return to “soundmachines”
