Finished building my first arcade button earlier this evening.
[Available!] horstronic Buffmult 2.0
- horstronic
All paid orders are shipped now.
horstronic DIY projects:
Eurorack Joystick // Arcade // Waveslicer // Buffered Multiple // Eurorack Cable Tester
- Morphology
Hi, I was just building this, and just wanted to check something.
At this point on the circuit board, there is a 300 overlaid with what appears to be 1N5819. I am presuming it's a 300R resistor, and the 1N5819 is just some text left on the Silk Screen layer, but I just wanted to check?
Plus are there any calibration instructions? Do you just feed a voltage in, and adjust the trimmers until the output equals the input?
Does the order of the trimmers on the board match the order of the output sockets?
Morph
Morph
There are only 10 different types of people: Those who understand binary, and those who don't
- Morphology
In answer to my second question - yes, they do.Morphology wrote:Plus are there any calibration instructions? Do you just feed a voltage in, and adjust the trimmers until the output equals the input?
In answer to my first question: I fed in a known, measured, voltage to the top input socket, then measured each of the 6 outputs and adjusted the corresponding trimmer until I measured exactly the same output voltage. I presume the calibration process is that simple,
Klangtueftler
- Learning to Wiggle
- horstronic
Sorry, I didn't see your post until now.Morphology wrote:Hi, I was just building this, and just wanted to check something.
Oops, sorry about that. You're right, it's a 300R resistor. Somehow the 1N5819 got two labels, and one happened to go over the resistor label.Morphology wrote: At this point on the circuit board, there is a 300 overlaid with what appears to be 1N5819. I am presuming it's a 300R resistor, and the 1N5819 is just some text left on the Silk Screen layer, but I just wanted to check?
About the calibration: Yes, you did it right. If you want to go really crazy you can also put 0V into the input, measure the outputs then to get the offset voltage and take that into account at the calibration process. The TL074 always has an offset of a few mV, so if you want to have a very precise Buffmult, you can do that.
Another way to make it really precise is this:
Connect the Buffmult input to a voltage source. Connect one lead of your multimeter to the voltage source too, connect the other one to the Buffmult output you want to calibrate. Your multimeter now shows the difference between the input and the output. You want to reduce that difference as much as you can of course. So you can now turn the trimmer until the difference is at 0V or just a few mV. Now start to change the input voltage. You can use a range of about -5V to +5V. The difference between the input and output should stay at the same voltage over the whole range, use the trimmer to achieve this.
This is how I calibrate it. It sounds a bit complicated and it's pretty hard to explain but once you get it, it's the most accurate and fastest method (as far as I know).
- horstronic
Don't worry, it's still available.Klangtueftler wrote:I am late to the showbut are Buffed Mult 2.0 still available ?
Just write me an email to horstronic ät icloud dot com.
Please let me know your forum name and the country you live in so I can send you a PayPal invoice.
- diablojoy
built all 4 - working good
I built 2 with the new boards and used 2 pin bicolor leds
in those
was wondering if there is a schematic available for the new version
as I was thinking of adding a small strip board for my 2 older boards
to add leds to them as well. no biggie though I can work it out if I have to.
in those
It probably wont happen today but if it does it definitely wont go smoothly.
- horstronic
Here's a quick render out of my PCB program.diablojoy wrote:built all 4 - working good![]()
in those
- diablojoy
I bought some off evilbay but synthrotek looks like they have themDoes anybody has a good source for the bicolor leds? Because these are bicolor leds with two legs?
http://store.synthrotek.com/3mm-LED--BiColor_p_491.html
- horstronic
I'm always using these:diablojoy wrote:I bought some off evilbay but synthrotek looks like they have themDoes anybody has a good source for the bicolor leds? Because these are bicolor leds with two legs?
https://www.reichelt.de/LEDs-Blink-Mult ... &OFFSET=16&
It used to be available at mouser too here:
http://www.mouser.de/ProductDetail/King ... 4VoYhAE%3d
Seems like it's obsolete now, but there are other color combinations still available.
Schlumpfhut
- diablojoy
you are good to go actuallyIs it possible to adapt the PCB to an MOTM-style PSU?
position for 4 pin MOTM power is there already
if you look at the pic of the board it uses the four larger holes overlaid on the
euro power header position
Schlumpfhut
Re: [Available!] horstronic Buffmult 2.0
Hello all! I am taking the plunge into building my first module and wanted to start with this buffered mult!
Are there any step-by-step walk-thrus I can study to reference on the way?
- rsholmes
There isn't, or at least none that I could find when I went to build mine.
It's pretty straightforward if you've built similar stuff before, but for your first module build, I'd definitely recommend considering something else. AI Synthesis has some very beginner friendly modules.
By the way, the current version of this PCB is designed to use either through hole or surface mount resistors and capacitors (vertically mounted through hole resistors). The Synthcube kit, for whatever reason, includes surface mount resistors and through hole capacitors. Not what I was expecting. I returned it and sourced the through hole parts myself.
Thanks for the reply rsholmes! I may start with something easier then. It looks like there are components missing according to the BOM that were not shipped to me. I will likely start with something else in the meantime and try to source the resistors and other items.
- rsholmes
Oh yeah, that was another thing with the SynthCube kit. There were parts added in the newer version of the module but they weren't included, basically it looks like they went by the old BOM with the new board. That was about a year ago and sounds like they still haven't fixed it.
Pfft. Guess I'll just set my money on fire.
Schlumpfhut
