Turing Machine in 5U?
- Paradigm X
- kindredlost
- 5U skiff friendly
Keep us informed about your progress.fac wrote:I never knew much about the TM. I'm taking a day off from work so maybe I'll try to program something similar for the ardcore.
What I like about the concept of the Turing Machine is the idea of random or a blend of random and set patterns all under voltage control. Also the idea that the steps are selected simultaneously instead of just one at a time in sequential order.
The last thing to give it a little more
My first modular synthesizer had a tiny Rockwell 6500 processor unit which I was able to use John Simonton's "Pink Tunes". The program had this pseudo-random control over aspects of pitch, note duration and octave range and blew me away back in the 1970's/80's. Larry Fast used it on his album "Computer Experiments Vol 1". To be able to touch upon this idea again in some limited way is the reason I have two full TM's in my system today.
Great stuff!
- mumblinstevedubya
- Paradigm X
I've got an expanded Turing Machine part built at the moment in a 3U width MOTM panel. Not wired it as yet and need to repair some PCB tracks I damaged by mistake, but might see if I can finish this off in the next week or so.
Regards
Magman
Regards
Magman
- Paradigm X
- beautyofdecay_
- no maps for this area
- donkey for rent
- beautyofdecay_
- beautyofdecay_
I agree, more blinky lights is good and I do have a drill. But I won't manage a neat enough hole for the 3mm LEDs I'm using and that would definitely annoy me. I might change my mind on that though...sduck wrote:No drill? There's definitely room for those 2 leds. And more blinkenlites is always worth the bother...
BTW, I'm halfway done wiring the panel. See the pic below...
- beautyofdecay_
Here's my finished 5U Turing Machine + Pulses and Dual Volts Expander in action.
And a look behind the scenes...
The Pulses expansion PCB was piggy backed on top of the Turing Machine PCB. The Volts Expanders are connected by flat cables behind the panel.
I made custom Aluminium brackets to mount the PCBs.
- beautyofdecay_
For the panels you mean? The Turing Machine panel was about 69 Euros, the Volts Expanders panel about 58 Euros.Jamnuska wrote:That is super nice. Any ballpark on costs?
You can download the fpd files from my website if you like: http://www.ecalpemos.nl/2017/01/07/musi ... 5u-panels/
You can decrease the cost if you remove the graphic elements.
I wanted to add the extra functionality to my 5U modular and wanted to preserve the look of the original Eurorack panel.
