Animal Factory Amplification
Crowminius in Euro
oldcrow
Crowminius in Euro
Post by oldcrow »
Heya folks,
Suit & Tie Guy asked for a module that was the filter/envelope/amp portion of my Crowminius. So, I made what I call "Module B." I am designing module A (osc bank & mod) while waiting for the module B front panel to arrive. I might make these pre-assembled in the future but crOwBX Euro comes first. :sb: :goo: :guinness:
More later,
Crow
cutterfiltoff
Post by cutterfiltoff »
Nice! :yay:
also known as Ritzy Sheens
sinemod
Post by sinemod »
WOW
So are you going to see those preassembled +panel ?
jdkee
Post by jdkee »
Must have Crow modules soon, Tor. Tor come out of the spaceship. Tor you can't take Santa.'
portobellovcs3
Post by portobellovcs3 »
My goodness! I will buy both modules as soon as they are available. Pre-assembled with panel please and thank you Crow! :sb: :goo: :party:
DonKartofflo
The knob-twisting Hive Mind
Post by DonKartofflo »
amazing! if you need help with doing preassembled modules, why not cooperate with suit&tie?
Nelson Baboon wrote:Beware of people who tell you to smile.
FS:
Mutable Instruments Tides 1 120€
Addac sys 12U powered frame 200€
oldcrow
Post by oldcrow »
Got module A's layouts done. Module A is the oscillator bank/modulation half of Crowminius. It is also a bit more complex than module B. :sb:
oldcrow
Post by oldcrow »
A couple notes:
I tried to provide additional input and output signals as befits the modular environment. On module B, each EG has output jacks, and the filter has a spare external mod CV input w/attenuator in addition to the usual 1V/Oct jack (with jack switchover from the pitch CV that can be provided from module A).
Module B has "MIXER B," which has four inputs, the external audio input with its own gain block and overload soft clipper for line level (or lower) signals, and three inputs for modular-sized signals, topping out at around 8V-pp.
Module A connects to module B with a short "module buss" 2x8 ribbon cable so gates and CVs are common to the module set, as well as the audio signal buss from the three oscillators and noise source. This means "MIXER A" found on module A mixes the oscs and noise signals into the common mixer buss alongside MIXER B when connected. Thus you have a 8-channel mixer: three onboard oscs, noise, external input and the three
8V-pp max. modular signal inputs. Module B has an "OSC BUSS enable" switch so you can disconnect the osc side if needed.
Module A has output jacks for each signal source that are under fader control. These same signals are always sent to the module buss header so as to not need to patch the outputs to the inputs--though if that is what you want to do, go for it. ;)
Module A has two sample/hold circuits: one for the LFO S/H mode, and one for implementing a gated or floating glide action. a gated glide stops moving the moment all keys are released while the floating glide continues until it reaches the released key's actual voltage value.
Module A also has external CV input for pitch and mod "wheel" controls, and local controls to act as pitch and mod (though not as "table-saw wheels").
Finally, module A has the two PWM LFOs, one for OSC1 and one for OSC2. OSC3 has an LFOCV input jack. Due to the tight panel constraints of module A, the modulation output CV for modmix (LFO, noise mod) is in fact on module B, although LFO waveforms except for S/H clocking are also accessible from the OSC3 output jack.
All of this is of course on my single-board Crowminius too, I just did a logical split of the synthesizer into two modules, and did a second logical split between the host (panel control) boards and the actual voice circuit boards. I did not include a local MIDICV as in a modular setting you should have one already. I will have a 10HP 4-channel MIDICV module out after this however, designed to work with both crOwBX Euro and Crowminius Euro.
Cheers,
Crow :guinness: :guinness:
portobellovcs3
salivating! :goo: :party: :banana:
oldcrow
Post by oldcrow »
Initial front panels,
portobellovcs3
Wow! You have crammed a lot into those panel layouts. I like the layout and am very excited to once again have a Minimoog but in a more compact package and the added PWM is a huge plus.
oldcrow
Post by oldcrow »
Module B all finished. Taking a turkey week break while module A stuff gets sent to me. :sb: :guinness: :party:
wahee
Post by wahee »
very nice
Crystalline Stricture now on
tonnrecordings.com
oldcrow
Post by oldcrow »
Time to build module A.
oldcrow
Post by oldcrow »
Module A host board finished.
LetTheDeedShaw
Post by LetTheDeedShaw »
Wow! Very impressive build pics! :banana:
solidstatedisaster
Post by solidstatedisaster »
I am excited to hear this completed!
oldcrow
Post by oldcrow »
Oscillator board with all SMT soldered. Just 3 connectors and 15 trimmers to add, and ready for testing and calibration.
oldcrow
Post by oldcrow »
That moment you realize you ordered top-adjust 10K multiturn trimmers instead of side-adjust. :guinness: :guinness: :ripbanana:
oldcrow
Post by oldcrow »
Today saw the arrival of the module A panel. Here is how it is all going to go together, once the 10K side-adjust (3296Z) trimpots arrive. Everything is close-fitting, but that is Euro format for you. :goo: :goo: The host board is tested and the voice board powers up and the supply rails trim, so I expect no issues.
Host board and panel, the connector on the back is the "module buss" to module B. This is NOT a power connector, although applying power here by mistake is harmless. I will doubtless catch flak for using the same header in two different places, but the idea is to reduce the number of line items in the manufacturing BoM.
Voice board (three oscs and noise+S/H), just need those six 10K trimmers (and the 2N3392 noise source):
The boards stack up like this. The camera angle makes the voice board look larger than the host, but they are the same corner dimension.
It should be all ready to go on Thursday. :sb: :sb: :sb:
--Crow
nickster
Post by nickster »
These look really good. Fantastic work you have done bringing these into life. :banana: How do you plan to sell these? Through your web shop or through distribution, or both? One last thing any idea of the price yet?
oldcrow
Post by oldcrow »
I intend to offer the modules assembled and calibrated. The first batch will be exclusive to my web shop but subsequent batches I will open up to a number of places that have expressed interest. I need to iron out the logistics of production on this first series, which is why the web shop gets them first.
In the pipe ahead of Crowminius Euro is crOwBX Euro, however. I am trying to rig production of all of the above at once as they use a common set of parts. Price is not quite known yet. I am estimating US$450 for Module A and US$350~$400 for module B. It really depends on the pricing I can get for the panels and mechanical hardware as those are the bulk of the cost.
--Crow
nickster wrote:These look really good. Fantastic work you have done bringing these into life. :banana: How do you plan to sell these? Through your web shop or through distribution, or both? One last thing any idea of the price yet?
oldcrow
Post by oldcrow »
A demo of the fully assembled system. The only thing I did not make myself is the case. Quick audio demo at the link below, a basic tuned interval lead that uses MIDI aftertouch to apply vibrato. I used my vintage Lexicon PCM unit for a touch of reverb. Other demos will by dry mixes to show specific features.
Crowminius Euro Demo #1
aquatarkus
Post by aquatarkus »
Is that a new Old Crow MIDI to CV module I spy (Corwmidius??). Will that be for sale on CS80.com either as a finished module or DIY in the near future?
oldcrow
Post by oldcrow »
I will probably offer bare boards for that. I made it mainly for testing things, but it is a pretty good (12-bit) 4-channel MIDICV. crowbx and crowminius batch builds come first, however.
aquatarkus wrote:Is that a new Old Crow MIDI to CV module I spy (Corwmidius??). Will that be for sale on CS80.com either as a finished module or DIY in the near future?
