Miniwave question
Discussion and support for Wiard Products
Moderators: Kent, grantrichter, carygrace
jamb
Miniwave question
Post by jamb » Thu Aug 28, 2014 10:07 am
Are there any known mods for the blacet miniwave to add an on-board oscillator for self-driving, like the modcan version does?
drumsofd00m
Post by drumsofd00m » Thu Aug 28, 2014 10:12 am
I guess if you go with Blacet's standard perpendicular PCB mounting, you can stuff in a VCO board next to the Miniwave board, drill the appropriate new holes in the faceplate and... wait's, that's called a Wiard Waveform City! ;-)
tron23
Post by tron23 » Sat Aug 30, 2014 12:17 pm
drumsofd00m wrote:I guess if you go with Blacet's standard perpendicular PCB mounting, you can stuff in a VCO board next to the Miniwave board, drill the appropriate new holes in the faceplate and... wait's, that's called a Wiard Waveform City! ;-)
Do these sound identical? I have heard some, claim the Waveform city sounds different. If it does, could you explain in what way?
drumsofd00m
Post by drumsofd00m » Sat Aug 30, 2014 2:34 pm
I've read that; it's bull. Calibration of the waveshaper, and shape, amplitude and dc offset of the input are the only factors. I can tell with certainty because I have WFCs made with MiniWave boards.
tron23
Post by tron23 » Tue Sep 02, 2014 1:38 pm
Thanks for your insight, I will have both soon and will do the audio tests!
Where are you buying your ROM's?
Return to “Wiard”
