6MIX
Support and discussion for Antumbra modules and DIY builds
Moderators: Kent, antumbra
BWBKc6VyUr
6MIX
Post by BWBKc6VyUr » Mon Mar 02, 2020 12:37 pm
I just finished building a batch of 4 Antumbra 6MIX v1.1. Neat little utility module and worth every penny (i.e. virtually none), so I'd like to formally state that I'm rather pleased with it -- thanks for providing this project!
WTB:
Veils (pre-2020)
TipTop stackable cables (cyan/yellow/blue)
FS:
Arturia Beatstep Pro (white) - £150 + shipping
Antumbra 6MIX - £75 + shipping
Kassutronics Slope 2 - £110 + shipping
antumbra
Re: 6MIX
Post by antumbra » Thu Apr 09, 2020 12:09 pm
Yay, I'm glad you like them! :)
www.antumbra.eu
soundcloud.com/monolitmusic
cereyanlimusiki
Re: 6MIX
Post by cereyanlimusiki » Thu Mar 18, 2021 5:11 pm
Hi
What would be subsitute for 595-TL072IDR as mouser has none in stock ?
cordoba899
Re: 6MIX
Post by cordoba899 » Thu Apr 29, 2021 2:34 pm
Hey cereyanlimusiki, did you find a suitable replacement for TL072IDR? I am also looking for one. Thanks in advance!
bman
Re: 6MIX
Post by bman » Mon May 03, 2021 3:50 pm
As far as I can tell TL072CD should be fine. Side by side in mouser every spec is identical. If you look at the data sheet and search for "TL072I" and "TL072C", the only difference I see is that the TL072CD has a wider range of min/max voltage/current for a few pins.
pjbulls
Re: 6MIX
Post by pjbulls » Mon May 03, 2021 3:54 pm
The only difference between the I and C ones is that the former has extended operating temperatures (-40 to 125°C instead of 0 to 70), so unless you'll be running your synth in an oven or are taking it to the Arctics it won't matter.
Return to “Antumbra”
