[Juno-66] ARP issues [SOLVED]
Moderators: Kent, tubbutec
somberreptile
1-Post Wiggler
Post by somberreptile » Tue Aug 04, 2020 1:56 am
[This issue was solved]
Hello,
So I've recently had the Juno 66 Mod Installed in my Juno 6 and I'm really enjoying it so far! I have only came across one issue, I get no sound from the keys when I turn on the arp in internal clock mode. I've gone and made sure the settings where properly set as well as performing a factory reset both with no luck. I have used the midi clock and both the original arp and super arp modes work with no issues when I have it in that mode.
Any ideas possibly?
Last edited by somberreptile on Tue Oct 27, 2020 3:47 pm, edited 2 times in total.
tubbutec
Re: Juno 66 ARP issues
Post by tubbutec » Tue Aug 04, 2020 2:52 am
Hi Elijah,
please get in touch: support @ tubbutec.de
Cheers,
Tobias
Gauthier65
Re: [SOLVED] Juno 66 ARP issues
Post by Gauthier65 » Sun Jan 17, 2021 10:44 am
Hello,
I recently got my juno modified by professionals -Audiotronic Bordeaux (France)- to install the Tubbutec kit.
I have the same problem than the one indicated above: ARP doesn’t work anymore.
Any advises would be welcomed !
Best regards,
Gauthier
tubbutec
Post by tubbutec » Sun Jan 17, 2021 10:50 am
Hi Gauthier,
maybe the arp clock source is set to something else instead of "internal". In the config menu, please perform a firmware reset to be sure.
Gauthier65
Post by Gauthier65 » Sun Jan 17, 2021 2:58 pm
Okay it works ! Thank you very much !!
Best regards
Return to “Tubbutec”
