What is CV2 and CV3 in the ModyPoly Manual appendix?
mmryspace
Post by mmryspace » Sun Jul 12, 2020 1:56 pm
I have the Mody/Poly installed in a Poly-61 and wondering what CV2 and CV3 are in reference to on the MIDI controller chart?
Is it related to the filter control modification outlined in the installation manual?
https://tubbutec.de/files/ModyPoly-Inst ... Poly61.pdf:
1.6 Solder the CV cables
The red and brown wires are aditional CV outputs. There will be a manual update shortly on how you can use these.
Re: What is CV2 and CV3 in the ModyPoly Manual appendix?
Post by tubbutec » Mon Jul 13, 2020 5:14 am
CV2 will control the CV-out of the red wire, normally used for pitch bend.
CV3 will control the brown wire output.
These are normally not used
mmryspace
Post by mmryspace » Mon Jul 13, 2020 7:24 am
Ok, thank you so much for clarifying. Is there a manual update or instructions on how to use / implement them?
