Roland CR-800
Moderators: Kent, tubbutec
torismad
Roland CR-800
Post by torismad » Fri May 22, 2020 11:00 am
Hi, I have a Roland CR-800 and I was wondering if the Uni-Pulse midi kit for the CR-78 would work on this machine as well ?
Any help would be greatly appreciated.
https://encyclotronic.com/drum-machines ... r-800-r72/
tubbutec
Re: Roland CR-800
Post by tubbutec » Sun May 24, 2020 1:34 am
You will definitely be able to trigger sounds. However without schematics it is hard to say from here. A synth tech would definitively be able to find the trigger points and install uniPulse.
Quite likely the CR-800 uses the same sound board as the CR-68. If you can post some pictures of the board inside, I can probably help better.
torismad
Re: Roland CR-800
Post by torismad » Fri Jun 12, 2020 7:04 pm
Here is a few pics
tubbutec
Re: Roland CR-800
Post by tubbutec » Wed Jun 24, 2020 9:31 am
I believe this is in fact the Cr-78 voice board. You can compare it to the pictures on page 6 and 7 in out installation manual:
https://tubbutec.de/files/uniPulseConfi ... lation.pdf
You should be able to connect uniPulse at the very same points and trigger the sounds.
Return to “Tubbutec”
