uTune microtonal midi through
Moderators: Kent, tubbutec
over7
u tune: tuned midi to midi - how?
Post by over7 » Sun Dec 15, 2019 7:25 am
hello
I have two tubbutec modules in my modular rack to tune 4 modular synth with the sequencer (stillson hammer) . Works great!
But I can´t manage to adresss my Behringer Model D via MIDI.
Firmware 1.12. Elektron sequencer. Or Keystep.
Midi passes thru but isn't affected by the microtonal scales.
Can anyone please give me a step by step configuration help ?!
thank you
tubbutec
Post by tubbutec » Tue Dec 17, 2019 6:19 am
The following steps need to be taken to allow midi to microtonal midi conversion.
This is how to do it with firmware 1.12 and might differ in later versions.
1) In the midi router you can select normal midi routing (an 90° arrow) and microtonal routing (an arrow + µ). If you want to translate midi, use the µ-version.
2) In order to configure the kind of midi translation, currently the settings from midi out config are used. This will probably change in later versions.
In MIDI OUT CONFIG select Mode sysex (if supported by your synth) or pitch bend.
over7
Post by over7 » Tue Dec 17, 2019 11:41 am
Thank you for the fast reply!!!
These ware the settings I tried it : didn't work and still does not.
When updating to firmware 1.12 in the installation process a message showed up something like "corrupted data ...." I could not read because it disappeared too fast.
CV to CV works.
What files have to be in the root folder besides the firmware (and Scala files)?
In the INFO window incoming midi values are not shown.
But Midi is passed through to the synth.
tubbutec
Post by tubbutec » Wed Dec 18, 2019 9:27 am
'corrupted data' display is normal after an update to 1.12, nothing to worry about.
I tried this again and it works flawlessly. What are your settings in
CONF->Midi->Output Config -> CH1, Mode?
You need to choose Sysex or Bend here
Nothing
Then maybe Midi in is not routed to CV? Otherwise you won't see anything here
Del
Re: uTune microtonal midi through
Post by Del » Sun Jan 03, 2021 12:01 am
[posted in the wrong thread]
Return to “Tubbutec”
