Polysix Filter Problem
Moderators: Kent, tubbutec
pdub
Post by pdub » Tue Nov 13, 2018 5:03 pm
Hi
I have been having a problem with my Modypoly setup.
When I bring the filter cutoff down I hear what sounds like fast triangle modulation even with no modulation active.
I have set all CC controllers to zero and the Modypoly Triangle speed and depth has no control of the modulation. It also isn't related to the speed of the arp or internal MG.
I have reset the unit, re-flashed the firmware but nothing has helped.
Any help would be greatly appreciated.
pdub
Post by pdub » Thu Nov 15, 2018 8:26 pm
So when I disconnect the orange CV option cable from R51 the problem goes away.
Any ideas why this would be happening?
tubbutec
Post by tubbutec » Thu Nov 22, 2018 6:15 am
Hi there,
some Polysix seem to have this issue, most do not. It comes from improper filtering of the filter CV signal in the Polysix circuitry, maybe there are differences between various Polysix versions.
There is a simple fix to this though:
add a 1k resistor in series to the orange filter wire. And a 100nF cap to ground like so:
pdub
Post by pdub » Thu Nov 22, 2018 12:43 pm
Thank you!
bujbot1
Re: Polysix Filter Problem
Post by bujbot1 » Sun Apr 12, 2020 11:38 am
Sorry to revive an old thread but I was pulling my hair out trying to figure out why my filter sounded terrible after the ModyPoly install.
I should have come to muffwiggler. Thanks tubbutec for posting the solution to my issue and for making the ModyPoly!
tubbutec
Post by tubbutec » Thu Apr 16, 2020 3:19 am
Thank you very much for the report. We will now put this in the installation manual and add the components to the kits.
Return to “Tubbutec”
