Still problems with ADDAC207 Quantizer
Moderators: Kent, __ag
maudibe
Post by maudibe » Mon May 26, 2014 7:29 pm
Hi there guys… yes, I'm having the same issue with the gate inputs. Gate input one is fine, but putting anything into gate input 2,3 or 4 just freezes or responds spasmodically.
Obviously, that makes three inputs virtually redundant… a waste of panel space and features.
Any chance this is being looked at or a fix made available Andre? It's not a game changer for me, but would be nice to have it working.
maudibe
Post by maudibe » Sat May 31, 2014 9:35 am
Hi Hirsbro - any news from Andre on this issue yet?
__ag
Post by __ag » Mon Jun 02, 2014 8:48 am
Hello Everyone,
I hope this post helps sort out all Quantizer issues!
Being such an intricate module there were some programming details that were not right in the first units. First users started reporting these and we've fixed them on the big batch, after a while we've got some new reports that we weren't aware of and after going through all of them, including this thread and others, we've fixed all issues and all latest modules were shipped with the corrected firmware.
So at the moment there may be some users with different firmware versions.
Now we want to make this right and update all older modules, we're trying to see what's the best option to make it easier for everyone.
In order to identify if your quantizer needs upgrade check the serial number on the back, if below #73 drop us an email!
we've created a special email for this issue:
207@addacsystem.com
And while we're at it and to clarify the issues reported, the problem lies in the way gates in and out were working. In more complex patches using different gate inputs they do not behave like they were supposed to.
i hope this brings a light on this matter while clarifying all questions that have arise here.
We're terribly sorry for these issues and can only hope for your understanding.
all the very best*
andre
flo
Space Jack
Post by flo » Mon Jun 02, 2014 9:50 am
:hail:
Now I can finally buy it :hihi:
Thanks Addac! :yay: :guinness:
__ag
Post by __ag » Thu Jun 19, 2014 5:40 pm
Hello,
Posting regarding new updates on the quantizer firmware update,
we now reached a solution that we believe will be the easiest for everyone, just finished a detailed pdf guide that i'm now sharing here before making the official release.
The solution is that everyone can do it at their own homes without the need to ship the module anywhere. Instead each user will need to acquire an USB to Serial adapter (they are selling on ebay for about $4 including shipping) so the update comes at a lower cost than if the module needed to be shipped elsewhere.
We could do this process in very different manners, but this proven to be the easiest and cheapest way to do it, it will also allow easiness on further updates of the quantizer or other ADDAC System modules.
Currently we're waiting for some ebay adapters to arrive so that we can test them and recommend a specific one, until then if you already have such a device try going through the upgrade process and let us know if all works as expected. It should be a fairly straight forward process but let us know if we shall we go more in depth, more explanations, pictures, etc...
Also planning a video step-through.
Here's the pdf guide:
http://addacsystem.com/firmwares/ADDAC2 ... eGuide.pdf
all the very best
andre
__ag
Post by __ag » Fri Jul 25, 2014 10:28 am
Hello!
Here's an update on the Firmware Upgrade process,
For those with a PC the process will still be the same, it's a straight forward process and there's just no simpler way to do it.
For those on a Mac, after some further research, i finished an App that will take care of everything for you, just install the Arduino App first, follow the guide to connect the Usb-serial adapter pins to the module and run the App, it will guide you through the rest of the process.
This avoids all the Terminal "scary" steps!
You can download the App from here:
http://www.addacsystem.com/firmwares/AD ... RMWARE.zip
Regarding USB-Serial adapters, we just got this one the other day, took a few weeks to arrive but it works perfectly:
http://www.ebay.co.uk/itm/251336804760? ... 1439.l2649
if in a hurry these ship from the US:
https://www.sparkfun.com/products/9716
And these in the EU:
http://www.inmotion.pt/store/ftdi-basic-breakout-5v
We're also planning in stocking these at low cost in a near future!
Hope this makes it easier for the Mac users!
all the very best
andre
Sinamsis
Post by Sinamsis » Fri Apr 22, 2016 1:48 pm
Just bumping this thread to see if there is any way to do a factory reset on this module. I was tinkering with the submenus, and I think I go lost a little. My modules acting a little bonkers now. So is there an easy way to just reset it instead of sifting through it and trying to figure out what moronic thing I did? Honestly, I probably need to re-RTFM. But any insight would be much appreciated.
Jimmy
Summa
Post by Summa » Wed Apr 27, 2016 4:20 pm
Sinamsis wrote:Just bumping this thread to see if there is any way to do a factory reset on this module. I was tinkering with the submenus, and I think I go lost a little. My modules acting a little bonkers now. So is there an easy way to just reset it instead of sifting through it and trying to figure out what moronic thing I did? Honestly, I probably need to re-RTFM. But any insight would be much appreciated.
Jimmy
Well if it's the tuning you want to reset just press and hold the "set key" for five seconds, but yes reading the manual is a good idea.
Sinamsis
Post by Sinamsis » Wed Apr 27, 2016 5:02 pm
Ha that was reread TFM. I've read it a few times. Anyways I sorted my situation. It seems a little finicky with the gates that it receives. Which has been reported elsewhere.
Also, didn't see this in the manual, but I believe I read that powering off for 60 seconds will clear the settings if they aren't saved to a preset. Either way. Seems to be working ok for me.
Musicartgeek
Addac 207 Quantizer
Post by Musicartgeek » Sat Oct 14, 2017 11:19 am
Having a lot of problems with it.
Tuning was terrible, but fine using a buff mult on the output. This worries me - I don't know why this should be, and I have three other quantizers (2HP, Intellijel, and O+C) that don't exhibit this kind of behaviour.
Took a while but I got the tuning instructions from Addac through an FB message. In the middle of doing the tuning, which while a little complicated seemed to be working, something happened - wrong keystroke? I don't know - and now there are no voltages output in Keyboard mode or quantizing mode - in the latter mode, the lights flash as notes are being selected, but there are no voltage changes at the output. Can anyone help with this?
ADDAC System
Re: Addac 207 Quantizer
Post by ADDAC System » Mon Oct 16, 2017 4:33 pm
Musicartgeek wrote:Having a lot of problems with it.
The tuning reset procedure does not affect the user's saved settings unless it is saved by the user. Did you save, did you restart? Can you give a bit more details? We'll help you out for sure, don't worry.
ADDAC System
Post by ADDAC System » Thu Nov 02, 2017 2:21 pm
Hey Musicartgeek, a really simple and general solution to your problem is to reupload the firmware for the ADDAC207 again. It's a great way to "reboot" your module that way. Just thought I'd followup in case you haven't figured out what went wrong. Let us know if you need more help!
orenhag
Post by orenhag » Sat Feb 10, 2018 8:47 am
I having issues too. serial #237.
CV wont "mirror" to ch2/3/4 only. when i plug cv into each channel it works ok. Also, key/octav knob doesnt do anything.
I it a fault? am i missing anything?
ADDAC System
Post by ADDAC System » Sun Feb 11, 2018 2:35 pm
Have you tried updated to the latest firmware?
http://www.addacsystem.com/news/new-fir ... ose-method
Musicartgeek
ADDAC 207 - Re-oad firmware and all good!
Post by Musicartgeek » Fri Mar 02, 2018 8:01 am
ADDAC System wrote:Hey Musicartgeek, a really simple and general solution to your problem is to reupload the firmware for the ADDAC207 again. It's a great way to "reboot" your module that way. Just thought I'd followup in case you haven't figured out what went wrong. Let us know if you need more help!
This worked. I now have two ADDAC 207s working perfectly. Thank you
Musicartgeek
Post by Musicartgeek » Fri Mar 02, 2018 8:02 am
orenhag wrote:I having issues too. serial #237.
Reloading the firmware worked for me.
damase
Post by damase » Tue Mar 06, 2018 4:25 pm
Looking at getting a used 207 at the moment.
Is there any danger of getting an older unit, hardware-wise? I realize i will need to update the firmware to current but if that is done correctly will it still function as well as a new unit?
Paranormal Patroler
Post by Paranormal Patroler » Thu Mar 08, 2018 12:47 am
To the best of my knowledge the hardware is the same on all modules. Firmware update ought to get you were you want to be.
damase
Post by damase » Tue Mar 20, 2018 6:31 pm
Thank you! Although i think I will just get new anyway since i missed my chance on a used one
Paranormal Patroler
Post by Paranormal Patroler » Sat Mar 24, 2018 4:36 am
damase wrote:Thank you! Although i think I will just get new anyway since i missed my chance on a used one
You can order directly from ADDAC. I think they ship abroad :hmm: (you guys are so lucky you don't get VAT added at customs).
MatMillion
Post by MatMillion » Sun Sep 16, 2018 2:40 pm
Problem with latest firmware (L3) upgrade... and a solution.
Just in case somebody runs into the same trouble:
After the latest firmware upgrade my 207 stopped working properly.
quantization was triggering the lights but the outputs stayed at 0V.
I tried reapplying the older firmware with no success.
Finally I was able to fix this by basically touching any parameter one time and also resetting the CV-scaling by pressing set for 5 sec.
Most important was changing the CV-scaling one time for all four voices. (holding button 10, then0 selcting the voice with buttons 1-4, then changing scale with button 11 or 12).
Also saving the fine tune setting with a long hold of button 10 in the tuning menu is important to not lose the setting after a restart.
Seems that the preset memory was corrupted somehow.
groovar
Post by groovar » Tue Jan 29, 2019 12:47 am
I’m having an issue with a brand new unit, aside from everything coming out sounding flat, the key / octave knob isn’t changing the scale. Instead, when I turn it and press the set button, it seems to be going to a “preset” of key positions. Very frustrating and I have been through the manual until I’m crosseyed. Anyone know what’s this means
groovar
Post by groovar » Mon Feb 04, 2019 7:40 pm
well i think it seems to be doing mostly what it is supposed to, aside from the rare freezes, i am still trying to find something interesting. any patch ideas for 3 vcos sure is welcome!
Return to “ADDAC System”
