DAY 7: Ultra .WAV Player
Moderators: Kent, __ag
nedrush
Post by nedrush » Sat Aug 26, 2017 4:01 pm
ADDAC System wrote:
nedrush wrote:I've checked the manual. My unit seems a little buggy in places. It may be because it's from a previous owner. Something don't work as described. I wondered if there was a way to reset the firmware or factory settings.
Hi nedrush, would you please be so kind as to send another email to addac@addacsystem.com ? They'll help you out.
Ok. I've sent an email. Thanks.
ADDAC System
Post by ADDAC System » Sun Feb 11, 2018 2:43 pm
We have a new firmware on the loose!And while on these we also offer a significant price drop in BOTH modules!
The pdf below features all info regarding upgrading the ADDAC101 and ADDAC111 Module, including necessary hardware, physical connections and download links.
ADDACSystem .WAV Players Firmware Update Guide:
http://media.addacsystem.com/firmwares/ ... _Guide.pdf
Last update version:
ADDAC111: E0, February 5th, 2018
Changes Log:
.On OSX no need to eject the card through a special App.
- Files still need to be named as before.
.Small correction regarding synchronization when triggering a file.
.ADDAC111 now supports up to 72 files.
groovar
Manual / start point
Post by groovar » Tue Oct 09, 2018 10:43 pm
I’m sorry if my brain is failing I’m having a hard time understanding this line:
“If the loop size is set for 1/4 of the sample, then the start point will only be available from 0 to 3/4 of the file”
Is that supposed to say zero to 1/4 of the file?
groovar
Post by groovar » Mon Oct 15, 2018 1:19 pm
still trying to grok this
tom moody
Post by tom moody » Thu Oct 25, 2018 9:38 pm
Yes, I think they mean 1/4. The loop and start knobs are interdependent, so as you change one you are usually fiddling with the other. Eventually you find a comfort zone for each sound (ideally with the start knob at a zero-crossing point so you avoid pops or clicks).
groovar
Post by groovar » Fri Oct 26, 2018 12:58 am
I think I was able to figure this out (although still wrestling with the SD cards to actual play a sample I can test)
By “start point” they mean specifically the start point of the loop, not the sample. So if the loop is 1/4 the size, the start point of the LOOP can only move down the sample 1-3/4 until it hits the end of the sample (because the loop is 1/4)
I actually had to see this drawn out and animated for it to click, the manual language was just a bit tricky
Still having a very hard time with the card formatting, making progress, hope to have it solved tomorrow
groovar
Re: DAY 7: Ultra .WAV Player
Post by groovar » Tue Jun 02, 2020 5:46 pm
just realized i forgot to post this
1) format card FAT16
2) add files (samples)
3) run program from command prompt:
RmDir /s /q "X:\System Volume Information (with "X" being your SD Card drive letter)
been working pretty solid for a while. every now and then I have to do and do it again (the last part)
Jumbuktu
Post by Jumbuktu » Tue Jun 15, 2021 11:41 pm
Thanks so much for this - solved my problem!
Return to “ADDAC System”
