Introducing ADDAC207 Intuitive Quantizer
Moderators: Kent, __ag
cptnal
Re: Re:
Post by cptnal » Tue Aug 25, 2020 4:21 am
deKaro wrote:
Tue Aug 18, 2020 9:38 pm
behndy wrote:
Mon Jul 15, 2019 3:11 pm
boop boop. got it in, and NIFTY. sitting down to learn my through the cute beasty and it's working different than i understood it would.
i have a melodic line CV going into 01 CV In, 01 CV Out to Rings, 02 CV Out to 2hp Sine. that works fineeeeee. since only the 01 CV In is plugged into, it dupes the quantized CV out to 02 CV Out as well.
but then i have different gate patterns going into 01 Gate In, 02 Gate In and 03 Gate In. and experiencing two things that are different than i expected.
01) i thought with a gate input that channel would only put out the note that was being quantized when that gate hit? like if the melody being put out was C D E F, and a gate was only hitting on when the C and E were going out the CV Out, you wouldn't hear the D and the F? maybe i have too long of a gate going in? but when the VCA for the Sine is open, i get the entire melodic pattern. like if i just trigger it every other beat, i hear the C then slide to the D the E then slide to F. was hoping to have the CV out freeze until the next gate.
02) it doesn't pass through to the Gate Out. on Channel 02 and 03 i was sending a different gate pattern to each, and the out to the envelope going into the VCA. if i stack cable the gate, then the VCA opens when it should, if i send out the Gate Out for that channel it..... some times does? i can't figure out WHEN it's triggering. i thought at first it was cascading like gates were read Channel 01 then 02 then 03 then 01 then 02 then 03 etc. but it's not doing that. just.... occasionally sends a gate.
what am i doing wrong?
Same here. On top of that, sometimes it works like expect and sometimes it doesn't. Sometimes it plays the individual notes and sometimes, when the rests are shorter, it plays the whole sequence of the Turing Machine I work with. :despair:
I will record a video today. I'm going directly from the Turing Machine into the 207 with normal cables (not stackcables).
I thought mine was bust for this reason when I first got it. After corresponding with Andre it seems the 207 needs a 10ms trigger. I get the feeling it may be a bit longer in real life, but haven't measured it. In any case a simple gate conditioner (I've used MI Stages) can work wonders, and can even bring a little "feel" to the rhythm.
What did confuse me though is that having a cable in CV inputs below the first isn't enough to break the normalling. There has to be a voltage present or the CV from inputs above still cascade down. Checking back, it does say that in the manual. :doh:
Is it finished?
Latest Tune:
deKaro
Re: Introducing ADDAC207 Intuitive Quantizer
Post by deKaro » Thu Aug 27, 2020 3:10 pm
Unfortunately that doesn't work with my 207. Is there a way to turn it on and off? Did I miss something?
i̫͚̬͎̻͗̉
R͋̇̒̏͂͋a̫̝̾ͬ̎ͫn̪̪̪͆̽ͧ͑d̾͑̒ͭͮͨͫo̖͉ͧͮmͦͬ̏ ͔͎̭̯̱͙̏͆̄̇ͪ͊w̠͖͈̖ͮ̌̑̑ͨ̌ͮẩ͙͎̩̺̳ͅĺ̰͖͙̒̌͆̇̎k̍̽͂s̹͎̫̆ͥͣͬ̉ ̣͍͕̬͉̲͑̓͗́͗o̿ͪ̑ͦ̏ͫn̒ ̮̘̜̘̪̉ͭn̮̲̼͎͓͎̮͊ͨ̇ͨͮȇ̮̦̻͖͈̇̓̉ͣv̲̬̪̟̟ͬe̿̔̽r̰̹̍̐̀-̬ͨ̿ë́̅̎̿ͯ̋͑n͍͈͎͙͖͋dͅi̫͚̬͎̻͗̉ñ͈̱g̞̯̠̈́̐ͨ̔̈ͩ ̙͙̹͙̠͍ͮ̀̉ͯ̾p̯͖̰̫͉͇͔a͇t̩̜̗͎ͫ͐ͯ̌͐̓ṭ̭͆̃ͩ̓ḛ̫͈͖̠̼͚̑̇̂͐r͓̳͚͗̅ͩ̋̽̀́ṉ̣͚͔̝͓̎̋̂ͅ
https://www.youtube.com/tonydekaro
Triglav
Post by Triglav » Thu Aug 27, 2020 3:51 pm
I've posted about this on the last page. This is either a bug or an undocumented feature. I've made it work again by long pressing button 7 then making sure button 2 is lit.
deKaro
Post by deKaro » Thu Aug 27, 2020 3:53 pm
Many thanks! I will try this! :tu:
i̫͚̬͎̻͗̉
deKaro
Post by deKaro » Thu Aug 27, 2020 4:02 pm
Yeah! It works! Thank you! :hail:
i̫͚̬͎̻͗̉
deKaro
Post by deKaro » Thu Sep 24, 2020 1:56 pm
Is there a version of the User Guide, which is "searchable" with Ctrl+F?
It's a little bit difficult by scrolling 30 pages when I want to look something up. :hmm:
i̫͚̬͎̻͗̉
cisco1984
1-Post Wiggler
Post by cisco1984 » Fri Oct 16, 2020 5:13 pm
I would very much like a new update! i have so many problems with this quantizer.
Del
Post by Del » Sun Dec 27, 2020 2:37 am
Just checking: Does this quantizer quantize chords within a key? For example, if only the IN of the first channel is patched and three outputs are patched to oscillators, if I feed it C, D, F, and I'm in the key of C MAJOR, will it give me a minor chord for D, and major chords for the other two? Thanks.
mr.pink
Post by mr.pink » Fri Jan 15, 2021 12:28 pm
I find this very non-intuitive and confusing too. Moreover it doesn't happen immediately. I have attenuators before the inputs, when I dial it to zero it goes on "normally" for a while, but after some time passes it starts to mirror input 1. Is it really that hard to implement sensing of input cables? Right now I'm using only channels 2, 3 and 4 and ignoring 1 because of this. I don't care about harmonization, I just want 4 equal quantizers.
Also I second the request for a searchable manual. For most of my modules I don't need a manual, the 207 is an exception, and a PITA to find what I'm looking for. And maybe you should consider hiring a technical writer (or better translator), it is not well written and full of the infamous translation "stink" (I'm also not a native speaker, but this is a bit too much).
ranzee
Post by ranzee » Tue Feb 09, 2021 9:12 am
I've made a searchable version of the User Guide (REV3): click here
Cheers,
Ranzee
https://ranzee.com <-- gear, vids, music and blogs
ranzee
Post by ranzee » Tue Feb 09, 2021 9:35 am
OK so I'm really not understanding how to setup the CV assign for TRANSPOSE.
If I use a Keystep and send this a note (set 4+7 and option 1) - it just doesn't do it to the right note - it's all over the shop.
Is there anyone who has a video on this procedure?
Cheers,
Ranzee
mr.pink
Post by mr.pink » Tue Feb 09, 2021 8:06 pm
Thanks Ranzee, downloaded! Sorry I can't help with cv assign. But generally I have the feeling it is so "intuitive" that it has mind of its own and you have to obey... It could have been such a great module, what a firmware... :(
deKaro
Post by deKaro » Mon Mar 01, 2021 9:55 am
Many thanks! Much appreciated :yay:
i̫͚̬͎̻͗̉
gtrmstr53
Post by gtrmstr53 » Wed Mar 24, 2021 11:58 am
i've seen people mention the 207 lets you create tunings/scales with up to 48 notes, but i haven't been able to find this info in the rev3 manual, and the rev2 manual on addac's site won't open for me (it seems to be corrupted?).
any chance one of you could direct me to the right spot in the manual, or to a video/other resource that goes over this feature. i've got a 207 coming in the mail soon, and am wanting to program in 48tet, 24tet, etc tunings to mess with, if that's possible. and if not, it still looks like a great quantizer.
Triglav
Post by Triglav » Wed Mar 24, 2021 1:40 pm
You can't create custom tunings on the 207. However, if you want equal temperament with more than 12 notes, you can just attenuate the quantized output before going into your oscillator.
gtrmstr53
Post by gtrmstr53 » Wed Mar 24, 2021 2:35 pm
ok, this prompted me to look at the manual again and i found what other people were probably referring to (from pg 22):
MICROTONAL SCALES
This setting also opens up the possibility to more than 12 note equal tempered scales.
Bringing down the 1v/octave to 1/2 will set the scale to a 24 note scale, bringing it further down to 1/4 will set it to a 48 note scale or any combination in between.
not sure how i missed this the first time. it looks like the 207 will do precise attenuating for you, but can't do anything more involved than that. i'm guessing that's what this user is describing?
Paranormal Patroler wrote:
Wed Jun 20, 2018 3:08 pm
nomenklature wrote:Does anyone have examples of what the African/Exotic temperament on the ADDAC 207 is like? The manual doesn't contain info about what intervals it is, and I can't seem to find video examples.
I'm trying to decide btwn this and the Ornament & Crime for quantization, and some unusual temperaments would be a big plus for the 207.
thanks,
N
I'm not exactly sure. But if you're looking for unusual temperaments, the 207 manual states you can go from 48 notes per scale to 12 notes per scale. Microtuning is cool!
Triglav
Post by Triglav » Wed Mar 24, 2021 3:22 pm
Well, yes, but that's not really different from just scaling with an attenuator. You wouldn't have control of all the notes separately like you do with 12-tone tunings. (For example if you set up 24tet and you turn off a note, you're actually turning off a pair, limiting your scale options)
I do like the just intonation, well tuned and balafon tunings though.
gtrmstr53
Post by gtrmstr53 » Wed Mar 24, 2021 8:21 pm
that all makes sense. thanks :)
Mr. Pete
Post by Mr. Pete » Sun Apr 11, 2021 10:11 am
Triglav wrote:
Fri Aug 14, 2020 6:07 am
.STARTUP: Leds now show the Firmware version at startup.
- This firmware version M1 blinks as follows:
- M blinks E note (Button 5) also marked M (Mixolydian)
- 1 blinks C note (Button 1)
M1? ¯\_(ツ)_/¯ user guide is rev 3 and I thought I read ADDAC 207 is at a Rev 5(?)
in any case, is this light sequence the latest Firmware ?
(as of April 11, 2021)
You can call me, "PETE"
https://petedako.bandcamp.com/music
@petedako on Twitter/FB/Instagram
Return to “ADDAC System”
