ADDAC102 VC FM RADIO are now available!
Moderators: Kent, __ag
lfomod
1-Post Wiggler
Post by lfomod » Sun Jun 10, 2012 6:44 pm
This module looks amazing and I have been wanting to try it for a while now.
I am curious if Andre or anyone might answer this or be up for the challenge:
Would it be possible to make a eurorack module that can transmit FM?! even at a small range of 50-300 ft. That would be awesome to be able to broadcast your euro sounds...
DoctorDoolittle
Post by DoctorDoolittle » Fri Jun 29, 2012 1:27 pm
I got an fm transmit device, looks like a hockey puck with an antenna. Ican route a signal into the puck and receive it with my addac module. When the puck is near the receiver, the signal come es through a few bands, making it possible to send triggers and move back and forth between differing signal degradation.
thebrotherspus
Post by thebrotherspus » Mon Aug 27, 2012 7:54 am
just wondering if there would ever be any chance of an expansion module for the vc fm radio. i'd love to be able to save certain stations into a bank so that i could call them up at any point. i always find a few stations with great textural noise but then end up losing them and it can sometimes be difficult finding them again.
anyway, i just thought it would be cool to be able to save 10 or so stations to memory or something.
j.precursor
Post by j.precursor » Sun Jan 06, 2013 4:12 am
just wondering, does the fm radio work outside US and EU ?
VC_Wiggular
Post by VC_Wiggular » Tue Apr 23, 2013 3:42 pm
j.precursor wrote:just wondering, does the fm radio work outside US and EU ?
Not sure how this works but I live in London UK and I could only get 2 stations on it, for which I took 20 minutes to find. Sometimes I barely found one. Had to sell :sadbanana:
Modular + Cats + ???? = Profit
painlessparker
Post by painlessparker » Tue Jun 03, 2014 9:53 am
Anyone else in the UK tried this module and had better results?
Edit: Scratch that, nation isn't likely to be an issue at all… Could it instead be that certain power supplies cause more interference than others? Or the proximity of this module to the power supply?
jenz
Voltage Controlled Corpse
Post by jenz » Thu Jan 15, 2015 8:27 am
I live mine but I have to boost the volume with another module is it normal?
Bumply
Post by Bumply » Tue Jan 27, 2015 1:57 am
great module! What kind of level/volume are you all getting out of yours? Mine is quite low, and I have to apply a lot of gain to match euro levels.
I don’t know...
jenz
Post by jenz » Tue Jan 27, 2015 2:04 am
Same here... Not so loud...
Matos
Modular masturbator
Post by Matos » Tue Jan 27, 2015 2:10 am
Yeah. It's quiet as heck. I have to run it into a ssf ptg to use it.
jenz
Post by jenz » Tue Jan 27, 2015 2:11 am
I live in Canada in the province of Quebec and I pickup a few radio stations... Well enough to have a lot of fun... My unit is close to the power supply...
Got to reset the unit to a couple of times
22tape
Post by 22tape » Thu Feb 19, 2015 5:08 pm
About to pull the trigger on one of these. Before I do--
Is it really that quiet?
Are you guys not getting any stations because of weak local radio signals, or is it the module that's not picking them up?
Label-- TheseKidsAreNice
Lit Rag-- The SissyFuss
jenz
Post by jenz » Thu Feb 19, 2015 5:33 pm
Getting a lot of stations even in my basement...
Super quiet tho
jenz
Post by jenz » Thu Feb 19, 2015 7:04 pm
The volume knob dosen't do anything and I tried with an offset in the volume cv but no luck... When I use the addac radio I use the tube disto from trogotronic(177) to boost the volume. It adds a nice saturation too!
22tape
Post by 22tape » Sat Feb 21, 2015 4:52 am
Great, thanks for the headsup. I'm interested just in case anyone is looking to unload :guinness:
ClausF
Post by ClausF » Sun Feb 22, 2015 5:31 am
Nice module (as all ADDACs I use), but same experiences than other users here: I find more stations with a cheap transistor radio (with antenna) at the same place. So maybe a bigger antenna would help? This thing must have one, so I would like to make it longer with a wire...maybe that helps
A photo which shows the point where to connect this would help... Andre, maybe you can help?
monads
Post by monads » Sat Mar 07, 2015 3:27 am
ClausF wrote:... Andre, maybe you can help?
Andre??? Kinda would like to pick this up. But the antenna range worries me, plus no AM options :waah: :waah: :waah:
ClausF
Post by ClausF » Sat Mar 28, 2015 9:42 am
Still no answer... :cry:
But there must be an antenna somewhere... a short answer would be nice
monads
Post by monads » Sat Jun 27, 2015 1:19 am
Still no answer...this sucks! What gives :despair: :despair: :despair:
ClausF
Post by ClausF » Thu Jul 09, 2015 7:02 am
Agree. I really like their modules, sometimes not the design (white letters on golden ground is horror, only white on white would be unclearer).
This is a simple question, and if this is for some reason impossible, an explanation would be nice. I use a 5€ transistor Radio from flee market or the Radio Music Player (great!) now, both work better than the 102. Ok, no CV in at the transistor Radio, but what does this help if I have no stations?
I still use a few ADDACs (bought used) which are great, but if I get the same functions from another company I prefer that.... :guinness:
ClausF
Post by ClausF » Sat Jul 25, 2015 7:24 am
So, back into this. Still no answer, wow, that's what I call a service! But if nobody helps you, help yourself! So I decided to take a deeper look into this (as it is) worthless module to bring it to something useful.
Ok, what's inside? Let's see if we can find the antenna. I do not upload photos, because it's pretty simple. This thing is a few PCBs, three black and a little red. The interesting is the little red one. This is connected with the next (black) PCB via a row of pins and a (big) triangle of pins. And if you read how the pins on the black PCB are labeled, you find ANT at one of the triangle pins. Ok, that seems to be the Antenna. Just putting a croco cable to that pin increases the quality of radio reception dramatically, and I get a lot of stations now.
The red PCB btw is the SparkFun FM Tuner Evaluation Board - Si4703. Everything about this is on the web. And so the triangle pins get demystified: At this place normally is a 3,5mm audio jack for earphones. And the earphone cable serves as antenna. That's it, without earphone cable no antenna.
Buenos dias muchachos... :guinness:
Mosiej
Post by Mosiej » Fri Sep 16, 2016 5:52 pm
would be sick to have an input/output FM trancmitter as well! :hail:
22tape
Post by 22tape » Mon Jan 29, 2018 2:42 am
So many unhappy users, yet nobody wants to sell me theirs?? :hihi:
PM if you're looking to unload one. Thanks! :guinness:
tumblz
Re: ADDAC102 VC FM RADIO are now available!
Post by tumblz » Wed Feb 19, 2020 4:23 pm
I was considering this module, but I'm starting to think that running an external radio, line-in, would make more sense. As others have pointed out, if this thing is quiet, then it requires a second module to boost the signal (putting the price at ~$500 USD). And it appears to have reception issues (not the least of which is lack of AM tuning).
All of this leads to the fundamental question: Is CV control of seek/search worth the high price?
Even if you are heavy on artsy random generative stuff, I'm not sure putting a mod on seek/search is really going to be that big of an improvement over simply hitting the seek/search button manually on an external radio device.
Anyway, I don't mean to deflate the ADDAC102. Considering the limitations, it probably does an admirable job. There are only a few radio modules out there. And obviously, it is highly portable. I'm just seeing if there might be better strategies out there for bringing radio into modular.
monads
Post by monads » Sat Feb 29, 2020 12:09 am
The ADDAC102 VC FM needs an update. You're honestly better off looking at the following:
1. Small AM/FM stereo radio;
2. Bluetooth transmitter for above;
3. ADDAC806 Bluetooth Audio.
The above combo works perfect!!! Sure you don't have VC over some features with an 102 so you'll have to decide what you want ;)
Return to “ADDAC System”
