Introducing ADDAC403 VC Time Signature Clock Sources
Moderators: Kent, __ag
propertyof
Re: Introducing ADDAC403 VC Time Signature Clock Sources
Post by propertyof » Thu Jan 28, 2021 9:06 am
dropthedyle wrote:
Thu Jan 28, 2021 8:08 am
The module has landed in my rack ! Expect some demos (next week) !
Sweet! Did you order it directly from ADDAC?
dropthedyle
Post by dropthedyle » Thu Jan 28, 2021 9:09 am
Yes ... 4 years ago 8-)
more seriously they are effective with their direct sale but it is done by email
Alexander Kuznetsov
Post by Alexander Kuznetsov » Fri Jan 29, 2021 6:59 am
Has anyone received an email with a tracking number?
soundslikejoe
Post by soundslikejoe » Fri Jan 29, 2021 8:05 am
Didn't receive any info...
dropthedyle
Post by dropthedyle » Fri Jan 29, 2021 11:16 am
For me, no tracking number received before the delivery by dhl
soundslikejoe
Post by soundslikejoe » Fri Jan 29, 2021 8:20 pm
Same! Surprised to find this at the house today! Welcome little dude.
chaosium
Post by chaosium » Wed Feb 03, 2021 10:19 pm
Waiting patiently for mine (and a Relabi) to be shipped by them.
chaosium
Post by chaosium » Fri Feb 12, 2021 10:07 pm
I got mine! Now uh, does it need to be master clock? I was hoping to have my multiclock output simultaneously to the 403 and Pam's.
soundslikejoe
Post by soundslikejoe » Sat Feb 13, 2021 1:25 pm
<deleted, not 403 related>
monads
Post by monads » Wed Feb 17, 2021 11:59 am
I don't believe needs to be master, take a look at the "Tap/Ping" input which is for syncing to external clocks!
chaosium
Post by chaosium » Wed Feb 17, 2021 12:06 pm
That’s what i thought, it seemed like the bpm wasn’t being properly detected from the multiclock, possibly because TRS cable in? It worked a bit better TS in from PNW, but possibly placebo effect ;)
I’ll keep playing to see what it likes best.
Jaypee
Post by Jaypee » Thu May 20, 2021 4:20 pm
How does the module react with ext. trigger (sync)?
Happy to finally see it released!
"Those aren't your daddy's waveforms " Cynthia Webster
soundslikejoe
Post by soundslikejoe » Thu May 20, 2021 5:18 pm
It prefers to be the master clock. But the firmware is still evolving.
noisewreck
Post by noisewreck » Sat May 29, 2021 2:28 pm
Arneb wrote:
Fri Dec 18, 2020 8:02 am
soundslikejoe wrote:
Thu Dec 17, 2020 9:04 pm
Nah... you're thinking in "sequencer clocks" but this is thinking in Meter. BPM is not the same as time signature. Ex... If you have 120BPM and a Time Signature of 4|4, then you generate 120 quarter notes in 60 seconds. If your PPQN is 4ppqn in this scenario, you would have 4X120 pulses in 60 seconds.
So... My assumption based on music theory and the layout of this module... If you set the BPM to 120 and the Time Signature to 4|4 and the BEATS/bar to 16... then you will have a super fast stream of 16th notes.
250BPM in 4|4 = 250 Quarter Notes per minute. At 4PPQN (aka 16 Beats/bar) you have 1000 clock triggers in 60 seconds.
The problem is that, as far as I can tell from the manual, those two bolded notions aren't distinct in the ADDAC403 - a time signature of 4/4 means Beats/Bar=4 and Beat Unit=4, and thus a 1ppqn Beats output. This is also reflected in the 5/4 time signature example on page 3.
From a music theory vantage point, I'd guess that the idea is to use ADDAC403 with an external clock multiplier. However, clock multipliers don't work all that well in the real world. They glitch when the input tempo changes, which I'm afraid would take the fun out of ADDAC403's metric modulation CV inputs (pun intended).
I see where the confusion is. I don’t have the unit, but looking at the panel layout, if you mentally substitute “tuplet” with “subdivision of beat” things will become clearer.
So, in the case of 4/4, “bar” output will send out one trigger per 4 quarter notes, “beat” out will send a trigger out per each quarter note, and if you want 16th notes, then you’ll set “tuplet” to 4 thus subdividing each 1/4 note to 4 pulses, which translates to 16th notes.
Tuplet would be a subdivision of whatever the beat is set to. So if your beat is 8 (meaning 8th notes), then setting tuplet to 2 will yield 16th notes from the tuplet output.
BPM is should still be calculated based on the rate of quarter notes per minute, unless ADDAC has gotten “creative”. This is certainly how it is in DAWs.
chaosium
Post by chaosium » Sat Jul 17, 2021 4:05 pm
Is there another one in progress a bit further along with connecting to other clocks? I don’t know if i’ve spotted it yet.
Multi Grooves
Post by Multi Grooves » Fri Aug 13, 2021 9:49 am
This really needs a video breakdown. Wow it's been a log time coming.
FS: SSF Entity
monads
Post by monads » Thu Aug 26, 2021 12:56 pm
Make sure to FW update! I recently noticed I had the old original and just updated last night to the latest "E_O".
E_0, May, 27th, 2021
E_0 Changes Log:
* IMPROVED: Ping detection
* FIXED: Tap tempo startup initialization bug
C_9 Changes Log:
* IMPROVED: Pot reaction display now showing correct values
* ADDED: Now showing firmware revision at startup
ee_
Post by ee_ » Thu Aug 26, 2021 3:38 pm
Almost bought one of these today. Just a little too pricey. Looks great though, still considering it as a master clocking source down the road.
EE / edwardewald.com
clwilla
Post by clwilla » Thu Sep 09, 2021 11:34 am
Definitely looking in to this module as odd times are, for one reason or another, difficult in Eurorack.
But some sort of video manual is in order. This thing is cryptic.
texturerama
Post by texturerama » Fri Sep 10, 2021 6:01 pm
Can anyone who owns this module comment on what is possible with the 403 that isn't possible with a standard clock (PNW, for example) and a clock divider w/ logic (like, say, the Shakmat Time Wizard)?
soundslikejoe
Post by soundslikejoe » Fri Sep 10, 2021 8:39 pm
Easy to dial in meter downbeat resets.... 15/8, 7/4, etc.
Easier to phase clocks.
Many other features are duplicate clock features found in things like QCD. Triplet, swing, divisions, etc.
clwilla
Post by clwilla » Sat Sep 11, 2021 11:42 am
Should I take this to suggest that perhaps the most useful aspect of this module for those wanting to play odd times is to set up the time signature (7/8 or whatever), and use the “Bar” trigger as a reset for modules like Batumi or PNW or a sequencer in order to facilitate odd times across the synth (better invest in a mult or 2, lol)?
Odd times shouldn’t be difficult. They’ve been a function of music as long as there’s been music. If even this simple function is made easy, this module is a no brainer for a guy like me.
This module needs a video, bad. I want to buy one, but I need to see how it works.
TumeniKnobs
Post by TumeniKnobs » Sat Sep 11, 2021 2:58 pm
+1. This looks very interesting but I’d really love to see someone dissect this and give it a good demo. Aside from the video posted in this thread can anyone point me to some recordings? I was weaned on Rush, Yes, King Crimson and odd time sigs are in my blood. I’d love to have something that will spark creativity in odd times.
bronzebygold
Post by bronzebygold » Fri Sep 17, 2021 10:04 pm
I just purchased a 403, so I'm still wrapping my head around it, but the ability to sync everything to odd time signatures, and especially the ability to pull out just the bars and odd/even beats (and the ability to CV bar length), are certainly some of the most unusual features.
I've also been using the "tuplets" feature quite a bit as well. At first glance it seems just like a clock multiplier, but this is a mistake. If you check the manual, you'll see that tuplets is divided into two functions: "TYPE" and "LENGTH." Type is the number of pulses in the tuplet, and "length" is the number of beats spanned by the tuplet. (If you're familiar with contemporary music notation, you can think of these as the numerator and denominator in a "ratio" tuplet notation, a la Elliot Carter.) In other words, you can have a quintuplet that fits within a single beat. Or you can have a quintuplet that spans two, three, four, etc. beats. (So 5 in the space of 1; 5 in the space of 2; 5 in the space of 3; etc.) And of course all of this is CV-able as well. This is quite interesting to me on both a mathematical and structural/compositional level and is pretty hard to patch without the 403.
Overall, I really like the module. I think about rhythm more in terms of arithmetic and logic than I do cycles and patterns, so ADDAC403 appealed to me more than the (I think more popular) Heuristic Rhythm Generator. I'm convinced it offers a set of features that aren't really available anywhere else at the moment.
Return to “ADDAC System”
