805.VS2
Moderators: Kent, __ag
cloudleft
805.VS2
Post by cloudleft » Sat Oct 24, 2020 9:50 pm
Hi everyone, can the 805.VS2 be used to crossfade between two stereo sources? I can't quite figure this out from just reading about it.
Thanks for your help!
pugix
Re: 805.VS2
Post by pugix » Sat Oct 31, 2020 2:48 pm
Yes it can. Patch one stereo source into inputs 1 and 3, the other into 2 and 4. Patch CV into Left CV in, which normals to Right CV in. Then set both CV attenuators to full (or about the same levels). Set the switches on both cross-faders to Output.
The Master channel is unused, so you have the further option of running the faders through it and getting stereo level control over the output.
Richard
https://www.pugix.com
Return to “ADDAC System”
