Introducing ADDAC405 VC Relabi Generator
Moderators: Kent, __ag
Raymond
Re: Introducing ADDAC405 VC Relabi Generator
Post by Raymond » Wed Mar 17, 2021 11:22 am
Can someone who has the module can make a video or some other sound demos of it ? The concept appears really interesting but hard to get.
Links to the music -->
https://linktr.ee/soundofraymond
Hari Seldon
Post by Hari Seldon » Mon Mar 29, 2021 5:40 am
+1 on that.
Would love to see a bit more, especially some simple patches or 'scope visuals.
I make similar clock patches with lfos and comparators, but I would like know what the 405 actually puts out and what happens when you tweak it etc. I suspect this could be a lovely module for me.
aragorn23
Post by aragorn23 » Mon Mar 29, 2021 10:49 am
Another +1 to this. I really feel like a Divkid or Chris Meyer style overview would work wonders here!
Triscus
Post by Triscus » Tue Mar 30, 2021 8:29 am
I have the module for about 2 weeks or so, unfortunately I'm not able to make a DivKid style video, sorry but I can give a short textual review:
The essay of John Berndt is quite philosophical I was confused about it at first, but, to my understanding, the realisation of ADDAC is actually quiet simple: There are 4 bipolar sine LFO mixed together and two thresholds can be set. There are gates generated when the thresholds are crossed, but the direction in which the crossing occurs is taken into account. So each threshold is able to generate two gates when the relabi wave is crossing from above or below. So it's a comparator in combination with a slope detector which is fed by the 4 mixed LFO.
The 4 LFOs can be switched on or off individually, can be locked to the frequency of LFO 1 and the frequencies of LFO 1 and 2 can be modulated as well as the thresholds and the gate length. One can feed external CV /LFO instead of using the internal LFO1 and there is an output of the mixed LFOs (the Relabi Wave) and a trigger output which puts out a trigger each time a gate is generated. Its also possible to pause and reset the Relabi wave.
It's really a compact complex modulation source. With a couple of modules and some logic one could yield the same result, but it would need some patching and much more HP.
One thing I missed was the function of the 'Gain' control. I assumed this controls how much the LFO influences the Relabi wave but it apparently doesn't do anything. I already wrote ADDAC about this as I think I missed something.
Hari Seldon
Post by Hari Seldon » Tue Mar 30, 2021 5:54 pm
Thanks! Much appreciated!
What does the Relabi wave output? Is that just 4 sine waves mixed together? Or is it possible to get more chaotic results?
And, 'pausing' the wave means sample and 'hold' it?
Triscus
Post by Triscus » Wed Mar 31, 2021 2:30 pm
I have the module for about 2 weeks or so, ...
The Relabi wave is 'just' the 4 Sine waves mixed together. But of course you can use a more complex signal instead of the LFO1 and go crazy with it
Yes, I think pausing can be seen as a sample and hold, it just pauses the generator.
Raymond
Post by Raymond » Fri Apr 23, 2021 3:16 am
Yes came back to look at this thread. Thanks for the precise description!
daphnid
Post by daphnid » Mon Jul 12, 2021 4:57 pm
I'm considering ditching Marbles for one of these, I need the space and over time Marbles has been relegated to being used for off-grid trigs for the most part.
But I did have a Compare 2 for a while and and it seems like the Relabi is basically a group of sine lfos fed into a window comparator, which did not really give me the control I wanted over over just how random the gates I got were. I love the way Marbles lets you continuously dial in total chaos to completely locked in.
Is anyone that's using the Relabi able to get these kind of teetering-on-the-edge-of-rhythm pulses that Marbles is good at? There's just not enough demos of this thing for how esoteric it is, which is a constant issue with ADDAC stuff.
Return to “ADDAC System”
