Preorder the ADDAC506 VC Stohastic Function Generator!
Moderators: Kent, __ag
ADDAC System
Post by ADDAC System » Wed Sep 05, 2018 3:20 pm
We've been quietly developing the ADDAC506 modules for the past months. It's inspired and officially licensed from TEIA's Stochastic Function Generator which was introduced in 2013 and is no longer available. We started with the original concept and then completely rebuilt and reprogrammed its MCU to a fully featured 4 voice / 2 stage envelope and slew generator!
This new module and its expansion is our take on a very different envelope/slew generator. It's a fully featured Quad Analogue Core Envelope Generator and Slew Processor with digital control which also incorporates built in random generators to control the Rise and Fall times.
Covering the full range from short sharp notes to long slow sweeps of up to 6 minutes. Together with the random generators it excels when used for drone soundscapes. Used as a Slew Processor the random generators act as dynamic modulation sources affecting the rise and fall slew speed. Fully featured outputs act as encouragement to self-patching creating interdependent envelopes acting in sync.
  • -Four independent Rise / Fall generators with individual timing controls.
    -Built in random generators for Rise and Fall Time each with Minimum and Maximum controls.
    -Three gate/trigger outputs per channel: End of Rise, End of Fall plus the standard Rise Gate output.
    -Two extra CV outputs with the Sum and the Average of all 4 voices cv outputs.
    -Four trigger inputs for the random engine (via the expansion)
    -Four CV random outputs from the random engine (via the expansion)
    -Dedicated attenuverters for amplitude and offset of each voice CV output.
We finished all development a month ago! Meanwhile already received all parts for the first batch and almost finished the PCBs assembly. Panels just arrived and we are now focused into finishing the first batch which shouldn't take more than a few weeks to be tested and out the door!
We plan to start shipping the Early Birds' batches of 20 by the end of September. Main batch will follow by the end of October.
>>> Help us bring this powerful module to your hands. <<<
eremitalf
Post by eremitalf » Thu Sep 06, 2018 4:27 pm
Amazing module! I've been lucky to beta test it on the last few months. Super..
Paranormal Patroler
Post by Paranormal Patroler » Sat Sep 15, 2018 2:23 am
I own the original small module. How does this compare other than it being quad?
lisa
Post by lisa » Sat Sep 15, 2018 2:48 am
I was told it’s too slow to work as an envelope follower for audio. I guess that’s due to the digital control of the module. Can you confirm this, eremitalf?
Eurorack, Una Corda and cello. 🎛️🎹🎻
OlivierWah
Post by OlivierWah » Sun Sep 16, 2018 12:44 pm
lisa wrote:I was told it’s too slow to work as an envelope follower for audio. I guess that’s due to the digital control of the module. Can you confirm this, eremitalf?
I cant answer but if I read the manual, it seems that only the random generation is digital but all other functions are analog.
lisa
Post by lisa » Mon Sep 17, 2018 1:48 am
Nah, the CV-inputs goes through the MCU too.
EDIT: Hm, CV input and Signal input are two different things so I’m wrong about this.
Paranormal Patroler
Post by Paranormal Patroler » Tue Sep 18, 2018 1:33 pm
According to their instagram the module now also recalls memory on startup!!
OlivierWah
Post by OlivierWah » Tue Sep 18, 2018 2:23 pm
lisa wrote:Nah, the CV-inputs goes through the MCU too.
I have the confirmation that ADDAC506 is slow to work with audio. I am not specialist so I dont know why, by the way when I read the manual it's seems that ADDAC506 is really shaped to work well with CV.
As I understand, the main idea is to provide a complex random CV (lfo and enveloppes) generator more than go in the realm of audio (it works at audio rate, but 1 khz is not so high).
vincitytaymodaimo
Hi
Post by vincitytaymodaimo » Fri Oct 12, 2018 7:19 am
I dont think so
groovar
Post by groovar » Tue Mar 26, 2019 7:31 am
Anyone out there using one of these? I can’t seem to get mine to do anything envelope related
lisa
Post by lisa » Thu Mar 28, 2019 2:02 am
groovar, huh? Can you share a quick video or explain how you set up your patch?
groovar
Post by groovar » Thu Mar 28, 2019 2:38 pm
I can’t seem it to do anything but it behaves when I send a gate in, and spits a gate out. The loop switch I assumed would cycle an envelope loop etc but there is no character coming from the envelope out at all. Like I thought this would have lots of personality and it’s so nothing I think it’s not functioning
Paranormal Patroler
Post by Paranormal Patroler » Sat Mar 30, 2019 2:59 am
Sounds like there's something wrong. I know it might sound stupid but are you sure you're plugging the right output? It sounds like you're plugging the Gate out instead of the Envelope out. I doubt that's the case, but it's worth making sure, it has a lot of outputs!
groovar
Post by groovar » Mon Apr 01, 2019 12:29 pm
yeah i have checked every possible thing ever before i started righting. looks like another shipment to portugal
ecstaticquiet
Locking Issue
Post by ecstaticquiet » Sun Nov 10, 2019 2:00 pm
I recently purchased this module and I love it!
But for some reason channels 3 and 4 do not respond to changes in the rise and fall times when unlocked and in the LFO mode (trigger and Loop engaged)
Channel 3 will respond to changes in the rise and fall times when channel 1 is unlocked and channel 4 will respond when channel 2 is unlocked, even when channels 3 and 4 are in locked position!
From the manual my assumption is that each channel can be changed independently. Is there something that I'm missing here, or is my module not functioning as it should?
monads
Post by monads » Sun Nov 10, 2019 5:23 pm
Another user reported something similar (pg.9 near bottom) with locking and not sure it was ever resolved.
viewtopic.php?t=79374&start=200
ecstaticquiet
Post by ecstaticquiet » Sun Nov 10, 2019 11:22 pm
monads wrote:Another user reported something similar (pg.9 near bottom) with locking and not sure it was ever resolved.
Hey man!
Thanks so much for that - I will check it out!
MarreM
1-Post Wiggler
Re: Preorder the ADDAC506 VC Stohastic Function Generator!
Post by MarreM » Wed Aug 05, 2020 12:38 pm
Hello everybody!
I got a question about the attenuation of a channel when it’s in “slew” mode.
If you set the rise/fall time to it’s minimum value (so the slew doesn’t affect the CV) would you be able to attenuate the incoming signal CV just like any other attenuator?
Daisuk
Post by Daisuk » Mon Jul 05, 2021 10:31 am
Edit - nevermind, I found the part in the manual about the expander and figured it out. :)
bronzebygold
Post by bronzebygold » Fri Sep 17, 2021 9:47 pm
I'm a bit confused by the lin/log knob on the 506. It seems that there's no exponential curve available? I'm more used to shape knobs like the one on Joranalogue Contour 1 where linear is in the center, and expo/log are to the left/right. Is there really no exponential response on the 506, or am I missing something?
Return to “ADDAC System”
