Introducing ADDAC Portable Modular Frames
Moderators: Kent, __ag
monads
Post by monads » Mon May 07, 2018 10:53 pm
Looks pretty sweet! Check the website for further details.
Paranormal Patroler
Post by Paranormal Patroler » Thu May 10, 2018 8:53 am
I've been breaking down my larger setup into performance based 6Us. These fit the bill perfectly!
According to their site:
ADDAC901PS
Single 6U Portable Frame with Lid
link
Lightweight Eurorack Format 6U Frame
Foldable stands for 17º desktop positioning
Plug n'Play
85HP per Row
170HP Total
Made in Aluminium with sidings in 19mm Poplar Plywood with Wengue Veneer
Dimensions:
- Width: 45 cm
- Height: 27 cm
- Depth: 18 cm
Maximum module depth: 6cm (~2.4 inch)
Weight: 3.5kg
Power Specifications:
- Input: 110v to 220v
- Output: ±12V
- Current: 1500mA per Rail.
Custom Options:
Per request we can also install our +5v Busboards instead of the standard ones.
and
ADDAC901PD
Dual 12U Portable Frame
link
Lightweight Eurorack Format 12U Frame
Plug n'Play
85HP per Row
170HP Total
Dimensions:
- Width: 45 cm
- Height: 27 cm
- Depth: 22.5 cm
Weight: 4.5kg
Bottom row : 7.5cm (~3 inch)
Top row: 10cm (~4 inch)
- Output: ±12V
- Current per Frame: 1500mA per Rail.
hdd
Post by hdd » Tue May 22, 2018 2:51 am
Does 1500mA per Rail means 750mA for 12v and 750mA for -12V ?
monads
Post by monads » Tue May 22, 2018 10:41 am
hdd wrote:Does 1500mA per Rail means 750mA for 12v and 750mA for -12V ?
No. It means:
1500mA for 12v rail
1500mA for -12v rail
You can request installation of +5v busboards, which will then draw from your 12v rail.
revoltcrews
Post by revoltcrews » Tue May 22, 2018 4:11 pm
wow these look amazing.. love to hear some field reports when available. :bananaguitar: :tu:
hdd
Post by hdd » Wed May 23, 2018 2:57 am
that's look pretty rad.
I think i'll go with one dual in the next couple of months
BTG
Post by BTG » Tue Jul 03, 2018 8:56 pm
Anyone try any of these yet?
richie
Post by richie » Thu Jul 26, 2018 6:33 am
Anyone try these out?
Paranormal Patroler
Post by Paranormal Patroler » Thu Jul 26, 2018 7:55 am
I'm about to order one of these
and take advantage of the free ahipping during July! The case is the exact type of spacecase I like for live setups.
revoltcrews
Post by revoltcrews » Sun Feb 24, 2019 3:16 pm
Paranormal Patroler wrote:I'm about to order one of these
Hi there, i'm super curious about this case's power supply. Is that small dual brick in the middle the PSU thats connecting to the 2 bus boards? and how small is it actually ?
the pic doesn't do a great job of showing that.
Can you post a better pic of the power system in these ?
if its that small and providing 1.5A per row. thats pretty cool! which begs the question of buying it separately from the case for custom jobs.
monads
Post by monads » Mon Feb 25, 2019 9:30 pm
Agreed it isn't really clear on the pics. It does look like an internal PSU though. You might also want to also upgrade the bus boards to include the +5V adapter.
Return to “ADDAC System”
