ADDAC 206 - Step input? gates or triggers or what?
Moderators: Kent, __ag
soundslikejoe
Post by soundslikejoe » Fri May 05, 2017 5:59 am
Just received a ADDAC206 this month. Each day is an experiment and I love it... but found an oddity yesterday.
I'm experimenting with 1:4 distribution of Gate signals. I plug the Gate CV source into "Out" on ADDAC206 and send the 1/2/3/4 to different percussion modules. This sort-of works... but outputs will "double trigger" as the steps change?
In other words... I send Clock into Step CV input, and 206 will change steps... but while changing from Step 1 to Step2... the module connected to "1" on the 206 will trigger for both step 1 and step 2 instead of just when step 1 is active. It's like the change of "step position" on the 206 causes the module to fire a second time.
Any ideas how this is working or what's causing the module to fire twice?
Paranormal Patroler
Post by Paranormal Patroler » Mon May 08, 2017 6:21 pm
Gate cut in half means both targets get half a gate, first one gets the proper gate attack, second one gets a false attack caused by the switching. I guess. Try a) timing your switches appropriately b) sending gates of lower pulse width.
Not sure if the 206 clicks. I never had problems with mine. Have you tried switching without actually sending gates at the same time? See if that fires up your modules anyway.
ignatius
Post by ignatius » Mon May 08, 2017 6:47 pm
can you narrow the pulsewidth of the gates? or just use triggers?
Paranormal Patroler
Post by Paranormal Patroler » Thu May 18, 2017 12:05 pm
Hey soundslikejoe, did you find a solution to your query? :hmm: Just curious.
soundslikejoe
Post by soundslikejoe » Thu May 18, 2017 9:15 pm
Work picked up (crazy busy) and not been able to revisit this experiment. Will do it soon, and will make a video to help illustrate the phenomenon.
Return to “ADDAC System”
